what sub should i go for it?
Hi
my setup
hu pioneer
amp: sony 200x2 rms @4ohm for MM651
2nd amp for sub: Audiopipe 3002 160x2 rms @4ohm 320x2 rms @2ohm
640x1 rms @4ohm bridge
Front: MM651
music:trance-new edge-jaz
Sub:? maybe MM1240 DVC x2 or MM1040 DVC x2 or 1 SR124-DVC
but my problem is my amp is 640x1 rms @4ohm bridge it cant go 2ohm
so what can i do?
need your help pleas
:smile::smile::smile: hello everyone,
Generally speaking the placement of your subwoofer is irrelevant, because low frequencies are non-directional and therefore unlike high frequencies that need to be 'directed'. Usually people just hide the subwoofer behind a couch or on the side.
Cheap Used Cars
Corners are sometimes favoured as they reflect the sound waves and make it a bit stronger, but as a general rule of thumb, it really doesnt mattter where you put a sub. Just place it where is convenient and where you have space and the sound will be almost identical no matter where that is in the room!
