Need advice on subwoofer setup and RCA cables
Guys, any help is appreciated :smile:
I am about to install dual JL Audio Fathom F113 subwoofers for my HT set. Now my Denon AVR-4810ci AV receiver supports parallel connections of 2 subwoofers (it has 2 RCA slots for subwoofer connections). However, when I read my subwoofer's manual, it does include an option for me to make one sub a master and the other one a slave, hence only one RCA cable is needed to run from the master subwoofer to the AV receiver, saving me some money as well as some time running wire.
My first question is: concentrating on sound quality, which option is better? Running parallel subwoofer connections to the AV receiver? Or running both subwoofers to the AV receiver through one connection via master-slave relationship?
My second question is: if I break the cable run into three cables: one from sub to first wall plate, one from first wall plate to second wall plate (this cable will run in-wall), and one from second wall plate to AV receiver, will the sound quality decrease comparing to running a long cable from the sub all the way to the AV receiver?
My third question is: I vaguely remembered either Mark (dorokusai) or some senior member of our CP mentioned previously that Signal Cables will give some discount if I mention CP, so how much discount should I expect from Signal Cables?
