Ok, got a new tweeter for my RT-800i, but how do I remove the tweeter from the trim housing?
Steve K.
Printable View
Steve K.
i saw an rti30 at CC once with the tweeter pushed into the cabinet...im guessin that nothing really holds it in there except for how tightly its fitted in there? but hell i have no idea lol i hope someone else with more expirence helps ya soon
well RT-800i tweeter is installed in the plastic trim on the front.
Removed the plastic trim, but how do I remove the tweeter from the trim?
Help
Steve K.:confused:
I did it.
It must be removed with a screw driver to push the side end of the housing on the low end, while pushing on the tweeter from the front.
I was I little worried about doing this first, but it all worked out.
Thanks.
Steve K.
