Did you get your Brimar from that site I gave you, George?
Later production, but still a favorite and priced decent.
Printable View
Mike, I let one of my 1940's Brimar from my stash go.
Gald you are enjoying it George......the Brimar still has the best overall tone. The Bendix 6106 does have slightly tighter bass response.
I still have a Bendix 6106 here w/ your name on it.
I also am probably putting a pair of 1957 RCA 5965 3-mic black plate, square getter up for someone. I bought a quad and only need a pair. Nice, warm tubes.
Just a quick update-- the Dared is sounding very musical and fast--I am however gonna play around with the Obligatto's placement,,as in outboard.The problem is that I can tap on the pre and hear it thru the speakers.I'll re-locate them and update tonight.
George if you are using the 5965's it could be the tubes. For some reason the longer plate tubes tend to be slightly microphonic even though the construction is such that they should be more rugged.
Try a regular pair of 12AT7's/ECC81's (with smaller plates) and see if it still happens.
ok will do.
I admit George the 5965's can be a little troublesome, but because they sound so sweet I just use tube dampers and try not to "rap" on the chassis. The TFK 5965's do the same thing and I've had some 7062's do the same thing. All minor, but puzzling. The Raytheon 6414 3-mica black plates don't have the issue. All the above are long plate versions similar to each other construction-wise.
The only long plate tube I can't use becasuse the microphonics can't be tamed are the GE 5 Star 6829 3-mica. Still trying to figure a way to use those.
George you should offer your skills for money and maybe modify other members tube amps .......... did I mention I had a yaqin mc10l lol
Thanks for the kind words--I'm just an amateur--folks like F1,Scomp, and Face are the big dogs.:wink:
Oops-- and FGTV--these guys know electronics/speakers,,I just try to follow their lead/advice.
A nice glow
Hey George, how's the little Dared performing these days now that you have put some hours on the caps? Just curious if you are still as enamoured with it now as you were when you got it.
Hit me up for some more tubes if you feel like it. I bought a quad of RCA 5965's and I just pulled the trigger on a quad of GE -5 Star long plate 5965's. I don't mind sharing if you are interested. If not, they will stay in my stash :tongue:
I might just hit you up for more tubes sir,,tell you the truth,I have not listened to it for awhile--I'll get my ears on it this weekend,,it will be going to PF with me.:smile:
George, how does the Dared compared to the wright?
Man,, good question,,,I've had to think about this one--the Dared is quicker than the Wright,,given the difference in tubes--I'd say the Wright has a wee tad more bloom,but not by much,,and that is based upon tube preference and the fact that I have nor done too much rolling in the Dared yet--really a very close call between the two,,of course,,that's just my rookie opinion.:smile:
I'll add my .02c, the Dared is very tube rolling friendly. I am amazed at the subtle differences I notice depending on what tube and rectifier combo I'm using.
The sound of the Dared SL-2000A with the stock caps is already awesome, just by changing the stock tubes. I wonder if upgrading the caps would make much difference still.
Thanks George. Are the 4 caps .22uf?
Don't forget how much the rectifier adds to the sound. The stock Chinese and Sovtek aren't that great at all. A Bendix 6106 or Brimar CV1863 (5Z4G equivalent) are superb with some of the older 5Y3's being a step up from the Chinese and Sovtek rectifiers.
