The input caps (2) are 0.22uf and the output caps are (4) 1.0uf caps. The output caps have two caps per channel in series with a feedback connection between the first and second cap.
Printable View
Which coupling caps are you talking about? Input or Output? George replaced both on his unit.
(2) .22uF 400v input caps. Some units come stock with Auricaps in that position and you'd be hard pressed to find another cap that sounds as good w/o spending a whole lot more money
(4) 1uF 400v output caps (Yellow square Carli caps)
http://www.polkaudio.com/forums/show...4&postcount=73
Here is a photo of mine and the last pic in this post shows the (2) Auricap input caps and then the (4) Yellow "square" Carli caps for output caps
Hey George or anyone else,
I was thinking of possibly using (4) of these for the output coupling caps replacing the (4) square yellow Carli 1uF 400v caps.
Anyone use these before, thoughts?
http://www.partsconnexion.com/capaci...ndorf_rxf.html
George if you still have the old yellow caps out would you mind doing a quick measure of them physically?
So are there two versions of this preamp?? A USA version??
Dunno,,, mine did not have auricaps,,but I'm pretty happy with it,especially after the cap upgrade.I suspect this thing would respond well to some Jenzen PIO caps,I have 4 Obligatto's that were sent (extra),,so if anyone wants em',, they can have them at cost plus shipping.
There are 3 versions technically and they are all US versions. When Auricaps jumped in cost Dared stopped using them and went with something (I can only assume) cheaper.
They made a version with Auricaps coupling caps; a version with Auricaps and gold PCB and a non-Auricap version non-gold pcb version. All the same pre-amp but just some different parts in those key area's.
I opened up my Dared SL-2000A and found 3 different uf values : 2.2uf, 1uf and .047uf with 3 different colored caps. Would anyone know what caps are these?
pic's please.
not in place of the yellow caps which are pcb mounted,,I had to get creative and mount them on the inside chassis and wire them to the board.H9 had a nice alternative posted above.
I'm using the Dared SL2000A preamp with a Tri 88SE tube integrated amp. Will the Dared render the preamp section of the Tri integrated amp useless? If so would this mean that the NOS tubes installed in the Tri preamp section will have no effect on the overall sonics anymore?
To what extend does the 5Y3 rectifier influence the overall sonic character of the Dared SL-2000A? Is the rectifier as important as the 12AT7 tubes?
Tube buying/rolling will be the death of me. I've found some more that I simply must try.
Can I use 12AU7s in lieu of the Dared SL-2000A's 12AT7 tubes?
NOT RECOMMENDED!
Check out this link and use it as a guide for 12AT7 tubes/variants that are compatible.
http://www.audiotubes.com/12at7.htm
No, but you can use 5965's which are about the same gain wise.
jessie52, there is a plethora of information here about the Dared that I or Kieko or George have written about. Try doing a search to get your learn on. I don't mind answering questions, but so far most of what you keep asking has been covered in depth.
Regards
Hopefully by the end of the day I'll have a new rectifier on the way. Like I said, I just had to bid, win and try these out. I'll post more after the auction ends.
