Revisiting The Bass Brace!!!
Quote:
Originally Posted by
xoaphexox
I must ask - are you using wall braces for your 1.2TL's, and if not, are you plugging that hole with anything?
DarqueKnight
No braces or spikes. The speakers rest on the original feet which are covered with Teflon caps. I am always moving the speakers around due to tweaking, so bolting them to the wall or spiking them would be inconvenient.
The hole is plugged with the original bolt.
Not any more...the hole is now plugged with a 12" long 1/4" diameter threaded rod.:smile: After xoaphexox's question, I decided to re investigate the use of the Bass Brace. I had tried bracing and spiking my 1.2TL's at my previous house. While I heard a small improvement in bass response with spikes and more improvement with braces, I didn't use either for the reasons cited above. The SDA SRS 1.2TL manual states:
"Low bass response can be enhanced in impact and definition by the use of either the included
Bass Brace or spikes. The Bass Brace, while more permanent, is the more effective of the two.
Spikes are still out of the question since I have hardwood floors. Even with spike cups, I can foresee trying to slide a (180 lb.) speaker out of the way and the spike digging into the floor after it slips out of the cup. Rather than dig the original braces out of their inconveniently accessed location in the attic, it was easier to fabricate a couple of braces from threaded rods and an assortment of nuts and washers sourced from Home Depot.
http://i148.photobucket.com/albums/s...assBrace-s.jpg
Figure 45. The bar code tag was still on because I wasn't sure if I would like this. I liked it...after a while.:smile:
http://i148.photobucket.com/albums/s...Finished-s.jpg
Figure 46. Finished Brace Bass. I know audiophile tweaks are supposed to be outrageously expensive, but this one worked
very well and only cost $4.00!
In the brace's final form, a 1/4" hex nut and three fender washers of increasing size were JB-Welded together. The fender washer end rests snugly against the wall (but not screwed to the wall). The blue tape on the wall in figure 46 serves two purposes:
1. It indicates if the brace shifts out of place.
2. It marks the position of the brace if the speakers need to be moved out of the way.
The plots below show modest improvements in frequency response and small decreases in harmonic distortion (primarily 2nd and 3rd order) after the installation of the braces. There might be more improvements if I were to bolt the braces to the wall, but I'll save that experiment for the future...when I'm more dedicated to audio.
The color coded lines on the harmonic distortion plots represent the following:
Black - frequency response.
Dark blue - sum of 2nd-5th harmonics.
Red - 2nd harmonic.
Purple - 3rd harmonic.
Green - 4th harmonic.
Light blue - 5th harmonic.
It is easier to discern differences in the plots if you save them to your computer and flip through them.
http://i148.photobucket.com/albums/s...wTwGskt2-s.jpg
Figure 47. 1.2TL frequency response prior to installation of bass brace.
http://i148.photobucket.com/albums/s...nalBrace-s.jpg
Figure 48. 1.2TL frequency response after installation of bass brace.
A comparison of figures 47 and 48 shows a general improvement in frequency response after the braces were installed. Both sides (27-30 Hz and 53-85 Hz) of the room resonance peak at 41 Hz are smoother as are the regions 200-350 Hz and 3-8 kHz. The high frequency response beginning at 11 kHz is much smoother with less steep roll off after 15 kHz.
http://i148.photobucket.com/albums/s...wGskt2d2-s.jpg
Figure 49. 1.2TL harmonic distortion prior to installation of bass brace.
Figure 50. 1.2TL harmonic distortion after installation of bass brace.
Adjustments To Speaker Locations
After four days of listening to the braced speakers in their initial locations, I began experimenting with speaker positioning (closer to and farther from each other and closer to and farther from the rear wall). The effects of position changes were evaluated subjectively and with measurements. The initial positions of the speakers were 11" from the rear wall and 6'-7.75" apart (inside edge to inside edge). The best sounding location was 10.5" from the rear wall and 6'-6-1/4" apart. Coincidentally, this was also the location with the best measurements.:smile: Due to the small variations in the hardwood floor's surface, the speakers had to be re-leveled after every move.
Moving the speakers farther apart and closer together adversely affected imaging. Moving the speakers farther from the wall diminished bass response. Moving closer to the wall improved bass weight without muddiness, but beyond a certain point, bass sounds became too prominent. The sound with the speakers 5.5" from the rear wall was exciting to listen to...since I am a bass head...but vocals and solo instruments were diminished in sound level. It was as if the bass guitar and drums behind the singers and soloists were playing a little louder.
Figure 51. 1.2TL frequency response with bass brace and 11" spacing from rear wall.
http://s148.photobucket.com/albums/s...llBraced-s.jpg
Figure 52. 1.2TL frequency response with bass brace and 5.5" spacing from rear wall.
Figure 53. 1.2TL harmonic distortion with bass brace and 11" spacing from rear wall.
http://i148.photobucket.com/albums/s...llBraced-s.jpg
Figure 54. 1.2TL harmonic distortion with bass brace and 5.5" spacing from rear wall.
Figure 55. 1.2TL frequency response prior to installation of bass brace with 11" spacing from rear wall.
Figure 56. 1.2TL frequency response after installation of bass brace with 10.5" spacing from rear wall.
Figure 57. 1.2TL harmonic distortion prior to installation of bass brace with 11" spacing from the rear wall.
Figure 58. 1.2TL harmonic distortion after installation of bass brace with 10.5" spacing from the rear wall.
Bass Brace Sound
The bass was cleaner, tighter, faster and more sharply defined and articulate, but it had to grow on me. Initially, there seemed to be a lack of coherence between bass sounds and the rest of the frequency range. It was as if the bass guitar, drums and other percussion instruments were playing a little bit faster than the rest of the instruments. Also, I was hearing less bass (actually less bass distortion), but, as usual with enhancements to bass accuracy, I was feeling more bass (it just wasn't as heavy in my ears). I initially went back and forth between brace and no brace many times. The only thing I initially liked was the increased body, clarity and definition to male voices.
Although I was getting more bass tactile sensation, I still went through "bass withdrawal". I did not note this level of tactile sensation improvement when I tried the braces years ago. Of course, that was in a different room, in a different house, with different electronics. I also didn't have any of the extensive mechanical vibration abatements and crossover circuit improvements treatments that I now have.
There were some moderate improvements to imaging in a couple of areas. On some recordings, the kick drum, electric bass and acoustic bass moved a little further back. On some recordings where bass guitar and kick drum images were close to each other, there was more of a sense of space between them laterally and depth-wise. On the left side, some percussion instrument images moved forward a couple of feet and had more clarity.
http://i148.photobucket.com/albums/s...Devils/mad.gifIn the future, when you are more dedicated to audio than you are now,
I can envision you getting a really big listening room for your really big speakers.
Yes!! How did you know?~DK
http://i148.photobucket.com/albums/s...Devils/mad.gifI've gotten really, really good at spotting trends in human behavior
and extrapolating outcomes.
Interesting post as always!
I thought the point of the bass brace is to couple the cabinet to the wall.
If the rod is only resting on the wall, it doesn't seem like you're getting the full effect.
I have the bass brace and wall plate, but haven't fooled with it yet.
