Have sr6500 and I need to fit them in 5-1/4 any ideas on custom build adapters etc?
Printable View
Depends on how much space you got in your doors, between door skin and (plastic) door panel and how your grill is/fits/installs.
I'd look for these anwsers in your car-specific forum.
I have built them with 2 layers of plywood its a 2 piece setup that screws down in the 5" holes and further up it has a mount for the 6" driver
How are you on depth? Are you completely against trimming?
If you have the depth,m a jig saw will make it work. I have put 6x9s in the front doors of a Saturn, and have put 10" woofers in the doors of a F150, and needed nothing more than a jigsaw to make the hole.
