soundbar 3000 remote help
I just recently purchased the soundbar 3000. The problem I have is that I can't get my tv or directv remote to sync to the soundbar. I tried using the learn feature on the soundbar itself, and I also tried using the codes provided by directv for their remote. I would really like this to sync. I hate having to use so many remotes.
Cannot sync the Surroundbar 6000 with DirectTV remote
I have similar problems trying to use the DirecTV remote to control the Surroundbar 6000.
First, trying to "teach" the TV's remote through the "learn" function only works for the volume up function. Trying to program the volume down function does not work (when "learned," pressing volume down on the remote INCREASES the volume output). Also, there are no instructions given for "learning" on/off or mute control functions.
Next, trying the option for programming the DirecTV remote to control the soundbar on AUD 1 or 2 (thus bypassing the "learn" feature entirely) requires a code to emulate the Polk Surroundbar 6000. Regretfully, none of the PolkAudio codes listed by DirecTV works for this soundbar. Why not? Are there other code[s] that can possibly work?
Failure to sync the volume up and down, mute, and on/off functions would be a fatal flaw for this otherwise fine soundbar! Advise please!!!
