Pa1200.1 @ 1 ohm w/ 2 mm1240dvc's??
I'd like some input on whether I should go with two dvc subs and run them at 1 ohm (1200 rms) or go with svc subs and give them 2 ohms. (800 rms)
My thinking is this : more power and less gains is always good but I would still be technically overdriving the subs and pushing the amp to its limits (I've not found much into at all on how this amp does at one ohm). Also sound quality is a big concern of mine. On this front people seem to argue night and day, some can hear a difference, some can't.
So what to some of you veteran audio folks suggest?
On a side note, I figure some of you guys must have some experience with the new pa d1000.1. I've tentatively decided against it based on some input from another member in another thread based on the subsonic filter not being detestable. Is it up to par with the older pa stuff?
