Originally Posted by
F1nut
All that prep work stuff is a common misconception. I never sand any piece of wood/furniture in my shop past 150 grit, there's no point as the clear coat finish will almost always require rubbing out.
BTW, if you have ripples from a planer start with 80 or 100 grit to level things out quickly, then work up to 150 and stop.
Since you're talking about pigmented wiping stains, sanding wood to 320 or higher will actually inhibit the absorption of the stain. You can see this for yourself by taking a board of say oak and sand half of it to 150 and the other half to the supper-fine sanding sponge thing you do. After hitting it with a tack cloth, apply the stain and wipe off. The 150 half will retain more color because you haven't closed off as many pores as the supper-fine sanding sponge half. Now, apply a clear coat, let cure and rub out. You will not be able to tell from the look/feel of the clear coat finish (other than the color difference) which half was originally sanded to what grit.
