Where I can get replacement for my RT800i's tweeters, and I can not find instruction to replace those.
Thank you : Andre
Printable View
Thank you : Andre
Thank you, I will call tomorrow.:smile:
The price way to high for me:sad:
I would look for a set of used RT35i - they usually go for around $100.00
As a minimum you will have a back up tweeter. I am not sure if the woofers are a different ohm rating or not but at $100 you will have a potential nice selection of parts.
To remove the tweeter, you will remove the baffle, take a flat head screw driver and there is a slot to the right side of the tweeter that you will wedge the screwdriver into and lift upwards. I have posted a video online...
Best of luck!
Thanks for the advice, or can I use my monitor 40's tweeters on my rt800i? Appearance is not really matter for me because I can hide it behind the grill.
