Diy SDA2A interconnect help
Hi, This is my first post, so hi, and thank you for this wonderful resource.
I bought these for $100 with just a few nicks and the missing cable. I hope I did okay.
The question I have is whether to wire the diy cable Big pin to Big pin and small to small, or cross them? I think I may replace them with banana plugs or something similar.
A friend told me that some models are wired big to big and other ones cross them. Is he correct, and if so, which way should mine be?
I also plan to veneer them and recap. Of common mods I have yet to notice any one changing the stuffing or bracing. Any recommendations there?
Thanks in advance,
Jon
