First post, greets all!
I have RTiA5's for my main, CSiA6 center (new receiver by weeks end with either 105 or 125w driven per channel depending on which receiver I go with) and Klipsch RW-12D sub and need to add surrounds. Between RTiA1/3 or FXi4/6, I've decided to go with the FX series for my surrounds.
Based on my fronts/center/sub combo, would FXiA4's suffice or, should I go with FXiA6's?? I may have run a cross a good deal on FXiA4's for $200 used in great condition if that helps make a decision. If buying new, question is same......
Thanks,
habe
