Is the Kenwood KA-60 a good amp worth getting for vinyl listening with 2 KLH Model 16 speakers and the Polk PSW10
subwoofer?
Printable View
subwoofer?
Sure, if you ditch the POS sub.
The PSW10 doesn't have a very good reputation at all. Pretty much in sound quality, musicality and reliability.
There are far better subs out there for only a hair more money. The PSW505 would be an example and can be had on sale pretty frequently for around $189-$199.
If you bump that budget up a hair and explore the used market, WAY better subs can be had.
Ha, I've been getting that a lot since I've been posting. However, it's my first sub and I got it for $75. Got my turntabe
for free also (AudioTechnica LP-60) and connected everything to an Superscope PAC770 tthat I used for music study brieflyn the late 90's and was about to sell or give away. So, as you can see, as a starter kit I've been able to keep costs way way down, which is the priority right now.
I am hoping a real amp will help enrich the sound of my vinyls, particularly the mids and highs.
KLH 16? I don't know that model - are these vintage KLH or later ones? If vintage, perhaps KLH 6 or 17?
As to the KA-60, I'd consider it slightly past the "golden age" but perfectly serviceable.
http://www.fmtunerinfo.com/newp19-KT-KA-60slim.gif
http://www.fmtunerinfo.com/new-specs-slimlines.gif
oh.
OK
(I'm just guessing anyway...trying to play it off like I knew what I was talking about...) :cheesygrin:
And I was trying to be diplomatic.
Now that my KA-60 is on its way how can I connect the PSW10 to it? I had a pre-out on the Superscope, but all the KA-60 has are
phone, tuner and aux ins and one set of left and right +/- speaker inputs. (My turntable has a built in pre-amp.):
Attachment 82497
Thanks, but I'm not sure how they apply. This is a simple TT to amp to speakers set-up, not home theater. Am I supposed to run my speakers wires straight into the posts on the back of the sub sub then run wires from the sub-out posts to the speaker-in of
the receiver? Or am I supposed to double up both speaker and sub wires to the in posts of the receiver?
It's an integrated amp? It has a volume knob, bass, treble, etc as well as loudness lever.
Here's what one looks like from the front
http://www.ebay.com/itm/Kenwood-Ster...item3ccf7014ca
I'm thinking this will work fine for my turntable...
yes, see the scan I posted earlier; it is a decidedly entry-level, compact footprint integrated amp ca. 1980 or very early 1980s.
Thanks to everyone who replied! I'm looking forward to hearing the difference the Kenwood makes over the Superscope.
Best regards!
