i am purchasing a set of db 6500 6.5" for a 93 grand cherokee front install.can someone give me some feed back on quality and sound please,thanks.
Printable View
Polk Audio makes some of the best speakers around and dollar for dollar you wont find a better speaker.
The Db series is their sophomore offering with the Momo being the top of the line. The Dbs are great sounding speakers. They are very warm sounding with smooth highs. Because of the smoothness they work best with rock and metal or anything with a good heavy guitar in my opinion.
However I would recommend coughing up an extra $100 and snagging a set of the Momo components. Trust me bro, they sound a lot better. They still have the warm, smooth sound of the Db but are much more detailed and can handle a good bit more power. You wont be going wrong by sticking to the Dbs but iof your budget can afford it the Momos will serve you better.
I like the Db's....theyre muy bueno
they blow away everything in their price range
-Cody
