Please unconfuse me. Ok, you see the audiobahn amp I have in my sig. It has the following specs:
50watts RMSX2 @ 4 ohms
100watts RMSX2 @ 2 ohms
200watts RMS bridged ... right now it's bridged for my RF sub
I'm looking to purchase either a MM2084 or a Kicker CompVR CVR8-4. Polk sub is no prob, but I'm confused about the Kicker sub.
The Kicker sub is a 4ohm DVC with 25-200RMS (25-100 per coil). Can I use this sub with my current amp? Does it mean if I wire each coil independently to the amp that I have a combined output of 200watts RMS?
Also, if I independently wire it, I'm assuming that means it will be at 4ohms each coil which won't be compatible with my amp correct?
Last, anyway to wire this sub by leaving my amp bridged?
