Onkyo SR604 set-up comment and question!
First of all, I would like to thank silvercbr (and Jeff from Polk) for his great advice. The setup of the sub PS10 definitely improved my bass. I've had the surround bar for a couple of weeks and it sounds great. Watching Star wars 3revenge of the Sith, was phenomenal and it definitely pleased the wife with no drilling holes and wires running thru our family room.
I have all the speakers set up at 120hz and subwoofer on (I have direct from sub out of receiver to line in on left at Sub. It works fine. In response to the question about the sub not working, make sure the dvd button in front of the receiver is set for Dolby pro-logic 2 instead of stereo or mono setting, because I noticed it would cancel the sub response if not set right. Also, in the manual, it states to use this setting if you are not using surround back speakers, which the surround bar would not be connected from the color coded wires. Also, my +6db setting for the 2 surround level seems just right and 0db setting for the front, center speaker levels. I did set the subwoofer level at +9 dbs which I think increased the effectiveness of the sub (please let me know if that is wrong).
Now, here are my questions about this 7:1 channel Onkyo receiver: What about the Equalizer setting? I have it off. Also, What about the input channel settings of the following: Multiplex (I have it set on main), Mono input ch., Panorama, Dimension, Cener Width, Center Image, and Listening Angle. Will these settings help increase the surround effect of the Bar. Help is appreciated.
