SRS: Busted a binding post and mounting plate
Twas a sad day yesterday as I was moving my big SRS's into the new bachelor pad with a buddy. They are much heavier than I remembered then being and we discovered while moving them from the old house that sliding them down the stairs (Carpeted. Eased them down.) on their back was the way to go. The first speaker went fine but the second one didn't have all of the binding post caps screwed down so a couple of them extended out the back beyond the plane of the speaker backing. One post broke off and the other just bent enough to crack the mounting plate.
I think I can remove the plate and posts and fix the crack. I was wondering what you guys thought of these Dayton binding posts as replacements:
http://www.partsexpress.com/pe/pshow...umber=091-1250
I've been using the Dayton speaker cable banana plugs and like them mechanically and thought I'd try their binding posts unless someone's experience dictates that this is a bad idea. :) Thanks.
Cary
