I'd just find a 'sparrow feed' digital tuner. Look at FMTunerinfo for ideas. There are so many good quality digital tuners that end up going for $50 or less on Ebay. Yamaha, Pioneer, Denon, Sony ES, all have good models that go cheap. They also have crappy models too, so do your research.
The reason I'd say go with digital is because most older analog tuners will need an alignment/restoration to give you their full potential. A tuner alignment cannot be done without special equipment and knowledge. I don't care how good of a DIY'er you are, Tuner alignment is a different boat.
On the other hand, most digital tuners from the late 80's/early 90's will be fine without an alignment.
Some recommended models:
Sony ST-S550ES or basically any of the ES tuners. Just beware of the models that have the 'audio current transfer' outputs because they have a special output cable.
Yamaha TX-5xx, or TX-7xx. The 5xx models go pretty cheap and are fine quality.
Pioneer models starting with F (there is a model F-445 on ebay right now that is almost too cheap to pass up)
Or, just about any Onkyo model. There is a T-4017 ending in a few hours that is only bid to $10. I had a T-407 that was fabulous. Stay away from the really low end models though (check FmTunerinfo)
