Anyone know a cheap way to get this done? Any suggestions?
Printable View
RAD Video Tools
http://www.radgametools.com/
Bink and Smacker is the directory it will install to.
That seems to be the trick, Thanks for your help.
This should work for Mpegs http://www.fxmpegwriter.com/
If you download AVS video converter, I might have a serial code that could work for you.
(I bought it, so don't worry about...jacking stuff.)
I paid $35 for it and I'm not even using it...
That's toeing a legal line...
Not really.
Consider it me giving him my copy of it.
I had a nice reply written up about the DMCA and software licensing etc. but instead I'll just say that if you uninstall it all should be good :)
I've already uninstalled. ;) The code is located in my email. I can't get my DVD burner to work so the program isn't really good for anything after all.
Blueberry287,
Welcome to Polk Forum, I hope you're an audio guy also ;)
Well talking about videos does anyone know how to "Stream" a video? I got the video done which the Windows Media converter worked the only thing that did the source mpg file I say was a bit odd to start with.
