Need to repair scratches on tweeter grill
OK, so the grill on one of the tweeters in my Polk component EX2560 set has a few scratches on it, right down to the silver steel underneath. I'd like to touch up the paint.
It does not seem easy to remove the grill for spray painting. But, if I paint it without removing the grill, I can either use brush on paint (which might not match or look splotchy), or spray paint with the grill in place (which will send paint onto the tweeter dome, which I assume is bad).
Any suggestions? Here's an (unscratched) example of the tweeter:
http://www.polkaudio.com/images/car/...ack/ex2500.jpg
