Dual Polk Audio Sr124 enclosure recomendation?
I have two SR124 subs and I had them in a 1.0 cu.ft. enclosure and they were loud even setting off my first car alarm but it wasn't enough. I want them to hit lower and harder. I am guessing I should go with a low tuned ported box. I checked the Sub box info section and it gives you basic dimensions but it doesn't tell me the tuning frequency, if it is a slot port or square, where to put the port. So if anyone has any suggestion that would be good.
System:
Pioneer 5900iB cd player w/ iPod hookup
Jl Audio XR650 components
Jl Audio XR650 rear coaxials
JBL GTO 75.4 at 100rms x 4
2 Polk Sr124 subs
Rockford Fosgate t1500bd
Having a little problem need help.
I have to say Mac and everyone you were right the ported was not any better. I decided to go back to my sealed box. The only problem is that before I blew both of my subs about a month or two in. I had them in a 1 cu.ft. box before displacement and someone had previously mentioned this might be to small. Could this be the reason for them blowing. I did noticed when I first got them that after a couple of hours of listening they would get really hot. Should I get a 1.2 cu.ft box because I noticed on the website it says a 1.2 give competition quality.
