MMC6500 and MMC690 in a 2007 Altima, a few questions
I am replacing my factory rear speakers with the MMC690's and I'm replacing the front door speakers with the MMC6500's. I have the base radio, am going to use the factory h/u (with a navone loc) and a 4 channel amp in the 70-100w rms range). My question is, does anybody know if mounting the tweeter high on the door (opposite the side mirror) and the woofer down low in the factory spot will cause me any problems with signal canellation? The only way I can mount them w/in 12" of each other is if I mount the tweeter lower on the door panel, say, near the door handle. Also, I am going to run the MMC6500's off of one channel per side (single mode on the crossover), does anybody see any problems with this? Lastly, what amps are recommended that won't break the bank (in the 70-100w rms range X 4 channels)? Sorry if some of the questions are foolish, but I would like to get it right. I just took delivery of the MMC690/MMC6500 speakers and 50' of 14g speaker wire. I also have the Navone LOC, now I just need the amp, and to hook it all up!
Thanks for the help!
