Anyone here know Crystal Reports?
May not be too complex for someone else, but here's what I need to do.
I have a set of data I'm grouping on Customer, and am trying to figure out a way to find out if item y appears after item x within that group. The tricky part is that item y can also come before item x, but I only care if it comes after. So here's what my data looks like:
Data within the group is sorted by date)
Customer Number 123
Date Item Y
Date Item X
Date Item Y
Date Item Z
Customer Number 456
Date Item Y
Date Item X
Date Item Z
So for Customer Number 123 I'd want the formula to return a 1 or a yes or whatever, but for Customer Number 456 I wouldn't want anything returned since no Item Y comes after Item X.
Here's what I've done so far. I created a running total to count Item x, have this total in every row of the report and at the group level, total resets itself on each group.
Then I have a formula, on every record, that basically says if the running total (above) is greater than 0 and this row is item y, then stamp eith a 1.
All that works great, and when I unhide the details section I can see it's working correctly. So that leaves one last step, which Crystal apparently does NOT support. I need to know at the group level what the total of that formula I created above is. However, when I go to create a running total at the group, the formula field is NOT one of the fields I can choose to total, likely because it's also based on a total...
So it's the very last piece that I'm stuck on.
Any help is appreciated.
