Adding subwoofer to stock car radio?
Hi,
I was wondering how difficult it is to add a sub to a factory car radio? In Home Audio subs can be hooked up with speaker-level connections; can this be done in the same manner with a car audio setup? And if so, would you have to run wires from the door speakers to the sub location, and then another set of wires back to the doors to the speakers?
Thanks!
Adding a sub to factory car radio, speakers
Hi guys, I just got a sub 6" or 8" with a maximum of 160 watts, amp integrated with RCA slots and integrated fuse. So i have a 2008 Mitsubishi Outlander LS, 6 Standard speaker with radio 140 watts. and i already have an auxiliary connection but it can only be used to play music from ipod, phone or any 3.5mm jack to RCA directly to the speakers using the radio as a medium.
Question is:
1. Can I still add the sub to the stock radio?
2. Will that fry my radio?
3. what are the adverse effect this can have on the electronics and warranty?
4. I will need major help if possible to get a diagram as how I can implement that with the stock radio.
5. Do you know if the stock speaker have connection for a Sub?
Your help is greatly appreciated
..by the way, I got this sub free..
thanks,
