SDA CRS + Interconnect Cable
I want to fabricate an interconnect cable for my SDA_CRS which has a blade in blade socket.........
so i think the pdf in this thread:
http://www.polkaudio.com/forums/showthread.php?t=55888
which is labelled SDA CRS + 1986 Sch.pdf is the correct schematic.
I am very green and this is probably a stupid question but here it is:
Does each wire connect to the same width socket blade or does the wide blade of one end go into the narrow blade at the other end?
I normally would assume that a wire would connect the terminals of the same width - but I wanted to make sure......
