Home Theatre Setup - SPEAKERS - HELP !
Ciao Guys
Audio challenge to set up a Home Theatre System on a budget. This is for a friend who is a composer. He puts music together with Silent films amongst other accomplishments. Right now he has a great video set up with a Sharp projection system and a 10' screen. He uses a HTR-6090 Yamaha receiver and has a Blue Ray player. What recommendations do you guys have for a 16' x 12' room.....probably 5.1 audio to start. Not just POLK...but a budget on a shoe string....under $1000.00 for speakers (mayybe more). Used is the answer....located in Washington DC. He has a dedicated man cave....painted BLACK. Video is fantastic.....audio needs a lot of work.
The screen is almost the full width of the room.......36" to bottom of screen from floor. Maybe a foot on either side of screen for wall mounts. Main seating about 4' from back wall....but adjustable.
Give it your best shot.
Give it your BEST shot. Best "BANG for the Buck"
I am a 2 channel guy. My leftovers fill in for HT>...
He would also like quality sound for 2 channel audio...(separate amps for front speakers). He likes my SDA-Crs's....but not sure how they fit in HT.
Already told him he should go separate amps and pre...but right now not a priority.
