Godfather™ 1500 High Performance Subwoofer VERSUS SVS PC13-Ultra SUBWOOFER
http://ecx.images-amazon.com/images/...-L._AA280_.jpg
http://ecx.images-amazon.com/images/...500_AA280_.jpg
Godfather™ Features:
1 Godfather’s “corner table” look was designed
to complement your other home furnishings
2 Available in both left and right corner versions for
symmetrical room placement and optimized sound
3 Elegant, high-lustre real cherrywood veneer enhances
any décor and is color-matched to Eleganza Component
Centers and Sound Systems
4 15" high-power Basso™ driver provides deep powerful, bass
5 Perforated champagne aluminum grille/trim matches
Eleganza StreamLine Towers Surrounds and Center
Channel Sound System trim
6 1000 Watt internal amplifi er provides all the power
you need to accurately reproduce explosive movie
effects and demanding music passages—perfect
for medium to large rooms
7 24k gold-contact binding posts for high-level inputs
8 24k gold-contact RCA connections for line-level
input/output
9 “Phase” (“normal” or “reversed”) and amplifi er
“Mode” (“auto”, “on”, “off ”) controls
10 “Gain” and “Crossover” controls
11 Internally-wired with Monster Cable®
Basso™ Low Frequency Driver:
a. Ultra-rigid aluminum cone for more accurate
bass reproduction
b. High-excursion rubber surround increases range
of motion for higher sound pressure levels
c. Aerodynamically designed, cast-aluminum frame
prevents unwanted resonance and outside noise
d. Dual-balanced spiders provides highly controlled
excursion for more accurate reproduction
e. Finite Element Analysis (FEA) optimized steel magnet
provides a stronger magnetic fi eld and lighter, more
effi cient design
f. Radial neodymium magnets provide a more compact
magnet structure for higher effi ciency
g. Edge-wound aluminum voice coil takes up less space
and delivers higher motor strength
Specifi cations:
Model: MD ELG SW1500L / MD ELG SW1500R
Dimensions: 31" W x 31" D x 23" H
Weight: 222 pounds
http://svsound.com/products/subs/PCU...ight_basic.jpg
SVS designed/built Ultra-13 woofer
Computer Assisted Design (CAD) enclosure
750 watt BASH amp with room compensation
Down-firing woofer with integrated baseplate
Compliant floor mounts
Exclusive 3.5" high-flow porting
Variable tuning (20Hz native) with sealed mode
Magnetically retained, removable grill
CNC cut, braced, and hand assembled cabinet
Architectural-grade black fabric exterior
+/- 3 dB 18 Hz-150 Hz (anechoic) in 20hz mode
Selectable Sealed, 20Hz, 15Hz or 10Hz modes
Size: Approx. 16” diameter x 46" tall
Warranty: 3 year comprehensive coverage
Support: Free 7 day/week customer service
Weight: 90 pounds. (105lbs shipping weight)
Ive demo'd Godfather today!! OMG! its so loud and punchy bass.. Also its so beast.. My wife looked at me amazingly and said oh yea its for you!! However i would like to hear your opinion.
