SurroundBar SDA Instant Home Theater
I am considering buying the SurroundBAR SDA IHT but I have a quick question before doing so. I have a cable HD box, PS3 and Xbox and want to use the surround bar for each unit. Now do I have to unplug the surround bar and plug it into each device i want to use? or can i just plug it into my TV and it will work for all the devices since they are all plugged into the TV? It could get a little inconvenient if i had to unplug it from my cable box and plug it into the PS3 each time i wanted to watch a blu ray movie.
thanks in advance.
Problems with SurroundBar 6000
I sure could use some help. I have a SurroundBar 6000 plugged into a Panasonic Vierra TV. I programmed everything with no problem, brought up the TV menu and turned off the TV speakers. Everything worked great. And then it stopped working. This has happened a few times over the last few weeks. Each time the circumstances are different. Sometimes I can turn the TV speakers back on and at least get sound. Sometimes the bar lights turn Red and cannot be persuaded to turn blue again. Sometimes they are blue but the Bar still does not have sound. Right now when I bring up the TV audio menu I cannot get the Surround option to be On at all.
I do not know if the problem is with the Bar, the TV, the components, the connections. If anyone has any sage advice, I will take it. (I left an email for technical service, but it is New Years Day so it might be awhile).
