SurroundBar SDA remote programming problems
I just bought the SurroundBar SDA. I am trying to program the remote, but am getting no response at all. I can select 'Remote', the orange light blinks, and I can select one of the buttons, like 'Mute', and the orange light turns steady. But then, no matter what remote I use (I have tried three different ones) or what button on the remote I press, there is no response whatsoever from the SurroundBar SDA. No blinking green, no blinking red, nothing. It stays on the solid orange light. If I press 'Remote' again, the light turns back to solid green.
Am I missing a step here?
Any suggestions would be helpful. Thanks.
SurroundBar SDA remote problems
Got a SurroundBar SDA a couple of days ago. This one came with a credit card size remote control (cute, but not mentioned in the manual) which doesn't work. The programming of other remote controls doesn't work either, just like trbuckley described it.
I emailed Polk tech support but haven't heard from them yet.
Anyone else out there who can help?
Thanks.
