Polk Speakers Hard to Drive ??
THIS IS A QUESTION THAT I POSTED ON ANOTHER FORUM...AND DOWN BELOW IS THE RESPONSE I GOT BACK ABOUT MY POLK SPEAKERS:
Last night I added 2 RT35i as my rear surrounds and changed over from 5.1 to 7.1 --- When I was finished I put in my Gladiator DVD to enjoy the new set-up and it sounded great. Then during a loud battle scene when a catapult shoots a fire-ball, my Sony 4ES completely shut off the sound and gave me the following warning in the display:
"Protecting...Turn Off Power"
I turned off the receiver power, waited 30 seconds, and turned it on again and it played fine...although I didn't go as loud this time.
Does the fact that I added 2 more speakers spread my available power even thinner so that I overloaded the receiver?? I never had this problem before using the 5.1 set-up and it has been played very loud. (Also never had this happen with my older Sony STR-DE945)
I have heard the term "Clipping"....is this what happened and how can I prevent it??
Recv: Sony 4ES
Fronts: Polk RT800i
Center: Polk CS400i
Sides: Polk F/X 500i
Rears: Polk RT35i
Sub: SVS 25-31PCi
AND HERE IS THE RESPONSE:
Polk speakers are infamous for impedance drops. Although they are specified as "8 Ohms nominal" or sometimes even "Compatible with 8 Ohm outputs", they often are not so compatible, with impedance that can drop to below 4 ohms at some frequencies.
I would suspect that the problem is with driving your very difficult polk speakers. Seven may be just too many.
Try flipping the impedance switch on the back panel of the receiver to 4 Ohm instead of 8 Ohm. This will enable the 4ES to drive your array of Polks more easily. You will (theoretically) get a very slight drop in peak power output (less than 1 dB), but the amp will heat up a lot less, and you will probably never get the protection message again.
Does any fellow "Polk Owners" have any input ??
Thanks in advance,
Beski
