Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 31 to 60 of 68
Thread: SDAs unplugged
  1. #31
    Member Sales Rating: (2)
    Join Date
    Sep 2006
    Location
    MA, USA
    Posts
    1,023
    Default
    Quote Originally Posted by heiney9 View Post
    Many think the cable just sends a low level signal from the opposite channel. Not true so you are missing fundamental frequencies and it will cause you to try an compensate with tone controls, etc.
    Can you provide a proper technical description? There've been threads about this in the past, including going over schematics and guys ohming out their speakers with multimeters. Seems like the result is always the same. At least in the big x.x series, the SDA drivers provide no positive signal above the low-frequency crossover point (below which they work in concert with the main drivers, even if the cable isn't connected.)
  2. #32
    Banned
    Member Sales Rating: (14)
    Join Date
    Jul 2006
    Location
    Newark, Delaware
    Posts
    21,321
    Default
    Quote Originally Posted by ben62670 View Post
    Running SDA's without the cable is like having sex with your sister. It is still sex, but it just ain't right.
    I love you Bro, but YOU ain't right!!!:p:D
  3. #33
    Member Sales Rating: (16)
    Join Date
    Mar 2005
    Location
    In A Van Down By The River
    Posts
    20,710
    Default
    Yes, I was generalizing which I normally don;t like to do. My statement pertains to earlier SDA's rather than later. Later models and the big boys are more like you describe.
    http://www.polksda.com/sda1creview.shtml
    Refer to the above link pp 42, left and middle columns.
    P.s. The OP has 2B's which are "later" models. Earlier 2's and 1's are as I described, for confirmation see the above link.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
    Pass Aleph 30; Adcom GFP750/Dared SL2000A; Adcom GDA600; MIT S3/Z Pc; SDA 1C; Squeezebox; Tubes add soul!
  4. #34
    Banned
    Join Date
    Jul 2006
    Location
    Newark, Delaware
    Posts
    21,321
    Default
    I notice the opposite. Tonal balance seems off to me when running w/o the cable. Vocals are recessed, highs are muted and things seem to sound unnatural. Flat, dry, lifeless, uninspiring, flaccid, tepid, vapid, choked, constrained, etc.
    Without the SDA cable you have to toe in the speakers to get the right sound which btw with the pair of SDA/SRS I once owned was a real PITA.
  5. #35
    Member Sales Rating: (13)
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    27,667
    Default
    The SDA drivers work up to 1000Hz, with the cable disconnected they only work up to 100Hz, in concert with the stereo drivers. Therefore, H9 is correct in that you are losing some of the frequency range produced by the SDA drivers.
    'Political Correctness'.........defined
    "A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
  6. #36
    Member Sales Rating: (0)
    Join Date
    May 2006
    Location
    The Seasonally Frozen Wastelands
    Posts
    852
    Default
    Quote Originally Posted by F1nut View Post
    With specific regard to the 1Bs in the first post:
    The + terminal of the dimensional drivers gets EXACTLY the same signal from the crossover as the stereo drivers. Unlike some other SDA models, the dimensional + circuit is a carbon-copy of the Stereo circuit--same resistors, same inductors, same drivers, same cabinet volume. The only things that make the dimensional driver signal different from the stereo driver is that:
    1. The - side of the dimensional drivers has the SDA signal from the other channel; the SDA signal delivered to the crossover is a full-range, full-amplitude version of the opposite-channel signal. This full-range, full amplitude signal is then processed by going through ~185uf of capacitors before being routed to the ground side of the dimensional drivers, and
    2. There's a fairly huge inductor in the ground path of the dimensional drivers. This inductor is in the circuit whether or not the SDA cable is connected; disconnecting the cable doesn't disable the inductor.
    Depending on program material, there is nothing to prevent the dimensional driver from producing essentially the same frequency response as the stereo drivers--except the inductor in the ground path.
    I don't understand how pulling the SDA cable can cut the bandwidth of the dimensional drivers to 1/10 of what it is with the cable connected. Can you explain?
    To my ears, the 1Bs have similar (not identical) response whether or not the cable is connected. The cable dramatically expands the soundstage when connected; but not so much effect on the tonal characteristics. This assumes a true "common ground" amplifier; put some resistance between the negative terminals of the amp and the sound quality of the midrange/vocals will go straight to hell with the SDA cable connected. 20 ohms is unlistenable; I haven't experimented, but I'm going to guess that 10 ohms will be "bad" and 5 ohms is "noticeable". I don't know how little resistance between the negative terminals it takes to be "acceptable". With "0" ohms, having the SDA cable connected or disconnected makes little difference in the tonal balance.
    This then becomes my advice to the original poster: Measure your amp for resistance between the negative terminals. Maybe even build a jumper wire--it's cheap and easy--and see if that "fixes" your midrange issue. The jumper wire was nothing less than a miracle cure for my system!
    Other SDA models are sure to be different. (That's material for another entire thread that I don't have time to start right now--SDA signals are handled in several different ways; and I'm thinking that the "strength" or audibility of the SDA signal is bound to be different depending on the speaker model. So my thread topic will be: which model has the most obvious/strongest/"best" SDA effect???)
  7. #37
    Join Date
    Sep 2006
    Location
    MA, USA
    Posts
    1,023
    Default
    Yes, but at least in the later big boys their 100-1K range is the reversed-phase signal.
  8. #38
    Join Date
    Oct 2007
    Location
    Arkansuck
    Posts
    159
    Default
    WTF MATE???????? That's just wrong. TRUE but ultimately wrong.
    Onkyo TX-SR705 AVR
    Onkyo M-501-Given to my father.
    Onkyo DX-C730 CD Changer
    Onkyo DV-BD507 Blu Ray player
    Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
    Polk Monitor 12's with RDO's and XO's
    Polk CS300 Center
    Polk Monitor Series 4 rears
    EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.
  9. #39
    Join Date
    Sep 2006
    Location
    MA, USA
    Posts
    1,023
    Default
    Quote Originally Posted by jrgoswick View Post
    Depends, are we talking step-sister, half-sister, or real sister?
  10. #40
    Banned
    Join Date
    Jul 2006
    Location
    Newark, Delaware
    Posts
    21,321
    Default
    Quote Originally Posted by John in MA View Post
    Who, how, when, how, where? . . . I don't know but your post has me cracking up. Sick pups!:p:D
    Ben you're still a perv for that one!:p:D
  11. #41
    Join Date
    Dec 2009
    Location
    Canuckistan
    Posts
    2,803
    Default
    Quote Originally Posted by Schurkey View Post
    .... there is nothing to prevent the dimensional driver from producing essentially the same frequency response as the stereo drivers--except the inductor in the ground path...I don't understand how pulling the SDA cable can cut the bandwidth of the dimensional drivers to 1/10 of what it is with the cable connected. Can you explain?
    It appears that the signal from the stereo array(SA) is fed to the dimentional array(DA) through the big inductor.Therefore the signal sent to the DA will be low pass filtered so only the low bass will be shared between the SA and and DA sections.
  12. #42
    Banned
    Join Date
    Jul 2006
    Location
    Newark, Delaware
    Posts
    21,321
    Default
    Fred could you make that a little more clear, I'm finding it hard to understand for some reason? Thanks!
  13. #43
    Member Sales Rating: (43)
    Join Date
    Nov 2006
    Location
    CT
    Posts
    15,924
    Default
    The signal goes to ground through the big inductor to ground so the lower bass doesn't cancel. The signal doesn't pass through except to ground. The mids are what get canceled from about 80hz to 2k or 2.5k via the IC cable.
    Ben
  14. #44
    Join Date
    Dec 2009
    Location
    Canuckistan
    Posts
    2,803
    Default
    Quote Originally Posted by hearingimpared View Post
    The big coil only allows the low bass from the SA section to be sent to the DA section. Does that help Joe?
  15. #45
    Member Sales Rating: (6)
    Join Date
    Sep 2009
    Location
    Alexandria, VA
    Posts
    3,080
    Default
    I noticed on my 2B's (pin/blade) that when the interconnect is not connected they leak a significant amount of air out of the empty sockets when the passive is pressed in.
    2-Channel:
    Source 1: PC/foobar2000/ASIO
    Source 2: Rega Apollo CDP
    USB to SPDIF Converter: Stello U3
    DAC: Audio GD NFB-7
    Preamp: Audio Research LS-15
    Power Amp: BAT VK-500
    Speakers: Magnepan 3.7's
    HT:
    Sources: HTPC, FiOS, Oppo 103
    Pre/Pro: Marantz av8003
    Amp: Rotel RMB-1095
    Speakers: LSiM-703's, 702's, 704c
    Subs: Dual SVS PC12-NSD's
    TV: Panny 55" VT50
  16. #46
    Member Sales Rating: (8)
    Join Date
    Sep 2006
    Location
    Towson, Maryland
    Posts
    2,548
    Default
    I was unplugging my IC the other day while a song was playing and I felt air blowing out of the pin IC receiver in the cabinet.
    For the record I always run with the interconnect connected but I just wanted to hear the difference because the sound stage was just so enveloping on that particular song and I just wanted to see how compressed it was without the interconnect connected.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  17. #47
    Banned
    Join Date
    Jul 2006
    Location
    Newark, Delaware
    Posts
    21,321
    Default
    Quote Originally Posted by FTGV View Post
    Gotcha, I read to much into the first post, thanks guys.
  18. #48
    Join Date
    Nov 2006
    Location
    CT
    Posts
    15,924
    Default
    The big coil lets the bass go to the amps ground. The higher frequencies are sent to the negative of the opposite channels negative canceling the mids in the dimensional array.
    Ben
  19. #49
    Join Date
    Dec 2009
    Location
    Canuckistan
    Posts
    2,803
    Default
    Looking at the schematic for Shurkey's 1B's here's what I see.The DA and SA sections are essentially connected in parallel the only difference being there is a 9.6 mh coil in series with the negative leg of DA section so it will be only recieving low bass .Being that it's an AC signal the coil will function the same whether it be in the negative or positive side of the signal path. (With the IC disconnected the paralleled 50uf and 130uf caps are out of the circuit.)
    An easy test to see if the above is correct would be to try the 1B's
    sans IC and see if the DA section drivers are reproducing low bass only.
  20. #50
    Join Date
    Nov 2006
    Location
    CT
    Posts
    15,924
    Default
    That coil is not in series with any driver on most SDA's. The Blade Blade it is in series in some speakers as in his 1B's.
    Ben
  21. #51
    Join Date
    Mar 2005
    Location
    Posts
    20,710
    Default
    I once asked Nelson Pass about my Aleph 30 and its compatibility with my 1C's. I sent him the schematics as well as a wiring diagram of the SDA 1C's. His response was that the Aleph 30 used a common ground but he mentioned it looked like the SDA's put stress on the negative side of an amplifier because of the interconnect. He also suggested a recommendation of a step down transformer for non-common ground amps like his X series and gave almost the exact spec of the AI-1. Reading between the lines; you need to have a stout amplifier to run the SDA's properly because it can stress the negative side of an amplifier.
  22. #52
    Join Date
    Sep 2009
    Location
    Calera, Al
    Posts
    72
    Default
    Thanks Schurkey, I knew I wasn't imagining this. I checked my amp, I'm getting .9 ohms between the grounds. I checked the MWs, without the cable all four seem to sound the same. I ran the SDA quick test and they passed with flying colors. Now back to some more A-B testing
    Denon PMA-900V
    Linn Axis with Grado Red
    Denon DVD-2500
    Polk SDA-1BTL
  23. #53
    Join Date
    Nov 2006
    Location
    CT
    Posts
    15,924
    Default
    Sorry Fred I didn't realize you were talking about the 1B's.
    Ben
  24. #54
    Member Sales Rating: (11)
    Join Date
    Oct 2008
    Location
    Dixon, IL
    Posts
    6,510
    Default
    Running SDA's without the cable? I've tried it. No thanks.
    The magic disappears.
    As others have mentioned, these speakers are designed to be run WITH the cable in place. They don't simply function as a normal pair of speakers when the cable is unplugged. They work, yes...but they aren't really designed to be run that way.
    The nirvana inducer-
    APC H10 Power Conditioner
    Denon DVD-2910 universal player
    DPA The Little Bit Three DAC
    Yamaha P-300 turntable/TCC TC-750 phono preamp
    Acurus L10 preamp
    Adcom GFA-545 power amp
    PolkAudio SDA 2A's/PolkAudio Monitor 7A's
    Audioquest Type 4 speaker cables
    Audioquest Sidewinder IC's
    Audioquest Black Mamba IC's
    Signal Cable Analog II IC's
  25. #55
    Member Sales Rating: (7)
    Join Date
    May 2007
    Location
    Climbing that pole...in your backyard
    Posts
    3,992
    Lightbulb
    Quote Originally Posted by dorokusai View Post
    I've been farther than you have...you can bet on that Russ.
    I know. It's just fun for me to get a rise from you.
    You still have bad ears.
    Say sumpin' chump!:D
  26. #56
    Join Date
    May 2007
    Location
    Posts
    3,992
    Lightbulb
    I've just read a few of your other posts; when was the last time you had your mouth washed out with soap?
    SHUT UP RUSS!:p:D
    I can use the F word any way I wish.
    except here....
  27. #57
    Join Date
    May 2006
    Location
    Posts
    852
    Default
    I agree with almost everything you state. The 9.6mh coil will NOT function the same if it were in the positive side of the circuit, because if it were in the positive side, the SDA signal coming from the other channel would go to ground without being blocked/filtered/modified by the inductor. Or, put another way, the inductor will function the same way, but it's in the wrong place with regard to the SDA signal. It's in the negative leg so that it filters/modifies the SUM of the "regular" signal delivered to the dimensional drivers and the SDA signal which is applied to the ground side of the drivers.
    I don't fully understand how the SDA signal travels through the wiring of the speaker; it seems to me that there's every likelyhood that it back-feeds through the drivers and crossover network as well as draining directly to ground through the big inductor. And, it doesn't help my understanding that the SDA signal is very changeable due to the program material. I know that if you disconnect the + speaker cable at ONE speaker, with the SDA cable connected, the speaker will still produce sound (program material dependent) at the tweeters due to the SDA signal back-feeding through the crossover. Spooky.
    I don't know what else to say except "Thank You". Every time I read about the SDA signal, I'm forced to re-examine what I know about it; and pretty much every time I learn something I didn't know before.
    Quote Originally Posted by bigaltx24 View Post
    Shove a jumper wire into the negative terminals, and see what happens. Worst case: you've wasted ~$5 on two Rat Shack banana plugs and a foot and a half of speaker wire.
    Gut feeling: add jumper wire; your midrange/vocal anomaly is g-o-n-e. But what do I know?
  28. #58
    Join Date
    Mar 2005
    Location
    Posts
    20,710
    Default
    Or he blows up his amp. Why are you insisting on him jumping his negative terminals on his amp? Do you have specific knowledge of his amp? I'm just curious, not being argumentative. Many non-common ground amps can NOT be jumpered or strapped without blowing up the amp. It seems his amp is common ground because of the the very low reading he has when measuring.
  29. #59
    Member Sales Rating: (58)
    Join Date
    Feb 2003
    Location
    6 Underground
    Posts
    25,086
    Default
    Heiney brings up a serious point....as you cannot just strap any amp and press play.
  30. #60
    Join Date
    May 2006
    Location
    Posts
    852
    Default
    If there's less than one ohm between negative posts already...
    ...how is a jumper wire going to hurt??? The negative posts are already electrically connected; just with a hint more loss than is optimum for the SDA signal.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Korn - Unplugged
    By VR3 in forum Music & Movies
    Last Post: 05-23-2010, 12:43 AM
  2. Alice n Chains Unplugged
    By specd_out in forum Music & Movies
    Last Post: 01-08-2009, 12:10 AM
  3. New SDAs
    By CTTE in forum Vintage Speakers
    Last Post: 09-02-2008, 03:50 PM
  4. How far away do you sit from your SDAs?
    By nms in forum Vintage Speakers
    Last Post: 02-02-2008, 02:40 PM
  5. DIY SDAs
    By zingo in forum DIY, Mods & Tweaks
    Last Post: 09-25-2007, 08:32 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
