Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online StoreHell yeah! Those are collector items now. ;)
MECA SQ Rookie of the Year 06 ~ MECA State Champ 06,07,08,11 ~ MECA Finals 2nd place 06,07,08,09
Congrats!
Polk Audio SDA SRS 1.2TL's
With new Exotic wood, Sonicaps, Mills & RDO198's - Born on 4-24-1989 and Signed by Matthew Polk!!!!
My Polk SDA SRS 1.2TL's http://www.LASAREATH.com/
It All Started here: http://tinyurl.com/lasareath2
Part Deux: http://tinyurl.com/lasareath3
Congrats, you will love them.
Pioneer P88RS-II | Polk Audio SR5250 | JL Audio 12w6v2 | 2x Genesis 3 Stereo 100 | Genesis 3 Monoblock
Ahhhh... Finally:
And I love them, yes! Sounds excellent. Mighty midbass, and even sub-bass!
I tried cut them at 31.5hz and I've got to say WOW, but I use 40hz (24db/okt)
now and it blends well in with subwoofer at 40hz (36db/okt). And they have only
gotten around 20 hours of use, can they really get any better now!? :D
After about 3 months of listening, I noticed I could cut my 5250's lower and lower. I had them cut off at 63 the first few months, but now I play with 40-50. Generally its left at 50, but if I listen to acoustic or something not as bass-heavy, I have no concerns about dropping it to 40. I think that is pretty exceptional for a 5.25" speaker with some of the volumes I listen to them at.
I would think it would be an identical situation with the 6500's.
The 6500's are very aggressive in the 80-100hz range. 50 hz though will be much louder from your sub, regardless of which 6.5-6.75" driver you're using. So how you set the 50-100 range at your eq really defines how well the mid bass shines and blends with the sub. Will vary a bit for the sub you run, enclosure, power etc.
Again, assuming that you have the ta, slopes, xover points etc set correctly for that eq setting.
The 5250 have cleaner mid range, thats very critical when blending the mids and highs. The sr-6500 are weaker in the 1-4khz range, than the 5.25". Maybe not in the physical db sense, but yes in terms of natural presentation. Mind you the difference is minute, but just noticeable :).
Frankly, having listened to and tweaked both, I'm at a loss as to which one I prefer.
I love the SR6500's! Much better midbass yes, but I had to pinch down 80hz and 125hz some - a lot of energy there.
Otherwise, I made them blend in very well with my sub too. With the woofers in well-damped doors,
and the woofers mounted in a stiff and thick plate, they does give me a lot of bass, pretty deep too...
About the midrange, I think they sound good, not very different - but it won't be a problem
since I'm gonna cross them at maximum 1.25khz when I get my Tang Band 2" speakers on the dash.
So far, I think I like the SR6500 a little better - mostly because
I love midbass and don't hear much difference in the midrange. ;)
Should've posted on this thread as well, just installed them 2-3 days ago :D:D:D
I'm looking at trying to get this Polk PA330 amp that's on craigslist (will use it to bi-amp the SR's with the other 2-channel amp I have) but the guy has yet to reply to my email.
So far I'm loving them! Never heard so much detail in a car stereo, just glad it's MY stereo that sounds so good :)
But they're pretty stiff yet, huh? I mean, they're not broken in? These have EXCELLENT bass...
Got mine used (since what, they're nearly impossible to find unused) however I had to purchase a pair of Vifa's from Madisound because they didn't come with the stock tweeters. The crossovers weren't used since they were in an active X-O setup so I guess those are having to break in.
Haha no, I don't think the X-overs need break in time. :p But what do you think about the midbass? Where do you cross them?
Hmm, I'd beg to differ. I experienced that when I upgraded the caps in my old RT1000P towers and it took some time for the X-O's to really make the speakers sound good.
Right now I've got them crossed at 70hz -6db. I'm not going to leave it at that though since I want to bi-amp the SR's, replace my sub+sub amp and dynamat my doors. Still a long way to go![]()
Crossovers dont break in. The caps may take a second or two to form after the first power up but thats it.
So it's pretty much next to impossible to find some decently priced SR6500 anymore?
almost craped myself while at frys today when i saw the price tag of the 5250s @ 350.00 made me want to sell both sets of momos that second.
i prob wont sleep tonight thinking about it.
2005 Subaru Outback XT Limited
POLK SR5250
POLK SR 12"
Kenwood Excelon XR-1S
Kenwood Excelon XR-4S
JBL-MS8
SR6500 on e bay today
http://cgi.ebay.com/Polk-Audio-SR650...item1c16238960
8 hours left to bid and $350.00 starting bid. 1 scratch on cone and used only 2 months he says.
No idea if it comes with a box> read the full description before bidding and maybe e mail the guy as well.
Dodge Ram 1500 SLT Quad Cab 2007
Pioneer DEX-P99RS, IPOD Touch 64gb, Rockford Fosgate T1000-4, T600-2 & T1500-1bd CP
Polk Audio SR speakers, 6.5's, 5.25's, SR tweets and 2 SR124-DVC subs in 1.57cu ft sealed enclosures
Yeah they're great Mac, but like you said: The SR6500's has far more superior midbass. :D
Oh yes. Did you notice that they're a little "stiff" since they're not broken in?
And oh, they look amazingly good ^
After getting used to the 5250, I don't know that I'd switch to the 6500 given the opportunity. I absolutely love the midrange they produce. The midbass punch is lacking a bit, but I think I've gotten to the point where I'd rather have the midrange over midbass.
For me it's midbass > midrange, by far! :D But hey, the SR5250's has excellent punch...
I crossed mine at 80hz, and used 18db/octave, with sub at 63hz (36db/oct.), worked well!
Right, the 6.5's do have better midbass response and hell they get really close to sub bass but the midrange and detail of the 5.25's is just superb and really hard to beat. Pair these with some good midbass drivers and youre set!
Trust me, I know only too well. This is the first year since 2006 I wont be at MECA finals. Aint got no money!
This has been something I have been toying with in my head for the last 3 months or so. Unfortunately, the funds won't allow the ability to set up a 4-way network for quite some time. With my long and wide Camaro Doors, I definitely have the space to get two drivers in the doors. It'd take some custom panels to do it, but it'd also allow me to bring out the 5250's and get them on axis.
I still think occasionally about the 6500, but if there is a fall off on the midrange and upper end, I just can't see doing it. As I tweak all the tunings, I still hear new things in songs I listen to regularly on a frequent basis. I've still got my MMC6500's in a box sitting in the attic, ready to get back in action on another car. I'm a bit scared to listen to them again since I'm so spoiled by the SR's now...
There are currently 1 users browsing this thread. (0 members and 1 guests)
