Is there any point buying the pioneer elite sc 25 when the pioneer sc 05 can be had for a few hundred bucks less?
Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online StoreIs there any point buying the pioneer elite sc 25 when the pioneer sc 05 can be had for a few hundred bucks less?
Not too much different.
None at all, same IceAmps in both models. You may gain an output here and there not much more. If the SC-05 has what you need, go that route and save some coin. Both are very good either way.
Shoot the jumper.....................BALLIN.............!!!! !
Home Theater Pics in the Showcase
http://www.polkaudio.com/forums/show...p?userid=73580
Doesn't the SC-05 have a fixed power cord? Might be something to think about.
good AVR I personally have one. It is annoying that you can't upgrade the PC however some people don't always want to do that anyways. There are a few differences but honestly for the amount I saved it was worth it.
2 Channel-
Carver Amazing Silvers
BAT VK-31
VTL Deluxe 300 monos (modded)
Esoteric DV50
Dynavector modded phono stage
Music Hall 2.2LE TT
Squeezebox Touch
Modded Music Hall DAC Burson op amps
Richard Grey 600S
MIT Shotgun IC's and SC
Signal PC's
If you're a I-phone owner the iPhone feature is a plus On the 25 were the 05 doesn't support it.
but it works anyway. I have used countless Iphones from 2g 3g and 3gs on many 05/07's without any problems. Actually sometimes it doesn't sync and you have to unplug and replug back in , then it works fine.
The 25/27 doesn't have this slight hick up.
The power cord thing is not a big deal. But if your into power cords , then get a 25 or really go for the 35 , it's improved much over the last 2 Ice models.
Dan
Dan
There are currently 1 users browsing this thread. (0 members and 1 guests)
