Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 8 of 8
  1. #1
    Member Sales Rating: (0)
    Join Date
    Dec 2009
    Location
    Orlando, FL
    Posts
    849
    Default Which turntable route to go?
    Hey guys,
    I really want to get into analog but I'm having a dilemma. In my possession is a JA Michell GyroDec which needs a new power supply, arm board and to be assembled (it's currently in pieces). I don't really have the time or money to fix it, and honestly I'm a bit daunted by it as a first dip into analog; seems a bit much for a first table. I was hoping to start off simple, something like a Rega P1, which I could afford to buy in the near future (and sell the GyroDec). A factor that is pushing me in this direction is, as you can see from my sig, my hi-fi is pretty budget. Given this, would I really be able to tell a big difference between an entry level Rega and a GyroDec on my rig? I figure by the time I have money to upgrade to a higher resolution system, I'll have money to buy a new and even nicer TT. Just a thought, wanted to see what the "been there, done that" group had to say. Thanks!
    - Jeremy
    - Jeremy
    Primary Rig:
    NAD C320BEE integrated amp
    Polk LSi15's / Polk LSi7's
    Creek OBH-11 headphone amp
    Sennheiser HD-515 headphones
    JA Michell GyroDec Turntable
    Secondary Vintage Rig:
    Sansui G-9700 receiver (200 wpc)
    Polk Monitor 5jr's
    Polk Monitor 10's
  2. #2
    Member Sales Rating: (3)
    Join Date
    Sep 2007
    Location
    British Columbia (Canada eh)
    Posts
    3,443
    Default
    My vote is to save yourself the hassle and go with the Rega. I'm a big fan of vintage gear but the GyroDec rebuild is a big task (although likely worth it). Save it for down the road. The P1 is a very nice entry table that will give you a lot of satisfaction with a nice cartridge.
    By the way that Sansui receiver is a very nice piece in your secondary rig. That P1 would work on it very nice.
    SDA-1C (full mods)
    Eico ST70 tube integrated rebuilt
    Nitty Gritty 1.5FI RCM
    The Clamp
    Nakamichi CR7 Cassette Deck
    Rotel RCD-855 with tube output stage
    Cambridge Audio DACmagic Plus
    DBX 3BX-DS
    DBX 224-DS
    ADC Soundshaper 3 EQ
    Ben's IC's
  3. #3
    Member Sales Rating: (5)
    Join Date
    Jul 2007
    Location
    Jacksonville, FL
    Posts
    631
    Default
    Save money and buy the P1, don't sell they GyroDec right away. The GyroDec you have in pieces could be an excellent table. If you decide to move up in the TT source chain you possibly will not be able to buy the same quality back for what you might sell it for today. If the P1 is totally satisfying then you can sell the GyroDec in the future and use the money to upgrade other equipment.
  4. #4
    Member Sales Rating: (6)
    Join Date
    Apr 2008
    Location
    GA
    Posts
    1,768
    Default
    I'm going to offer a similiar but slightly different suggestion; don't fool with the GyroDec for now until you get more experience with TTs and buy a used Technics SL-1200 instead. I am running a heavily modified SL-1200 with lots of the KABUSA mods and it's outstanding. I know friends who have spent way more on their turntable setup then mine and honestly, mine sounds just as good. I've had intro ProJects and a Rega P1 in the past and frankly they were not as good as the 1200. Don't get me wrong ProJect and Rega make outstanding products, but their intro tables are not quite as good as stock 1200s. You can commonly find used 1200s for $200. Add a Herbie's Way Excellent mat, a good record clamp, and a decent cartridge and you'll be in TT heaven.
  5. #5
    Member Sales Rating: (1)
    Join Date
    Dec 2008
    Location
    New York
    Posts
    2,560
    Default
    just hypothetically
    if you were to sell the GryoDec
    what do you think you would sell it for ?
    if only the Power Supply needs repair or replacement.
  6. #6
    Join Date
    Dec 2009
    Location
    Orlando, FL
    Posts
    849
    Default
    Quote Originally Posted by jvc View Post
    just hypothetically
    I'm not sure really. There is one on audiogon in great running order for $1500, and it's stock. Mine is obviously not assembled and needs the power supply, but it does have the Orbe platter and clamp upgrade ($850 msrp) and an RB300 tonearm (missing Rega arm board; has a VTL one on it now).
    Thanks for the advice guys. Dawgfish, I have heard great things about that table, but I'd rather get something new right now just because between undergrad, work and preparing for graduate school I just won't have time to upgrade or fix anything if something breaks. I want something low maintenance that I don't have to worry about tinkering with for a while (outside of the usual adjustments). Oh, another limiting factor for the table is this: my pre-amp is a very budget Cambridge Audio 540P; I don't think it would do a GyroDec justice lol.
    - Jeremy
    Primary Rig:
    Polk Monitor 5jr's
    Polk Monitor 10's
  7. #7
    Join Date
    Dec 2009
    Location
    Orlando, FL
    Posts
    849
    Default
    Looks like Rega is phasing out the p-1 in favor of a manual rp-1 that is a bit more expensive and has no dust cover. Anyone know of the major differences between these two pieces? I really liked that the P-1 was fully built in Britain; is this new one a Chinese product? Either way, if I want the p-1 I need to act fast.
    Oh, and just in case I'm away from my comp, a preemptive Happy Thanksgiving!
    - Jeremy
    Primary Rig:
    Polk Monitor 5jr's
    Polk Monitor 10's
  8. #8
    Join Date
    Sep 2009
    Location
    Austin, TX
    Posts
    1,597
    Default
    I believe the RP1 is a replacement for both the p1 and the p2, Affordable Audio had a review of it recently.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Scenic route from Houston Texas to L.A.
    By LeftCoast in forum The Clubhouse
    Last Post: 10-26-2010, 11:34 PM
  2. Need Help turntable
    By chemical in forum Speakers
    Last Post: 08-25-2009, 05:36 PM
  3. DBX DAV-600G A/V Program Route Selector
    By George Grand in forum For Sale (FS) Classifieds
    Last Post: 05-06-2009, 09:04 PM
  4. Need Help turntable mat/pad
    By Toolfan66 in forum Electronics
    Last Post: 02-27-2009, 12:00 PM
  5. Is this a better route than RTis?
    By dane_peterson in forum Speakers
    Last Post: 11-30-2006, 08:47 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
