Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 61 to 82 of 82
  1. #61
    Member Sales Rating: (1)
    Join Date
    Mar 2004
    Location
    somewhere in Canada
    Posts
    530
    Default
    Quote Originally Posted by MacLeod View Post
    Both those links dont work. They sound interesting though. Having essentially a parametric, 1/3 octave EQ would be pretty cool if youre tuning with an RTA.
    If I were in the market though Id be eyeballing the new Apline H800. The H700 was a masterpiece and all you really would ever need so the H800 should be as good.
    The PXA H800 is on my list too, but the Asian/European models released so far have had some bugs, only one of which has been addressed by a firmware update so far.
    http://www.diymobileaudio.com/forum/...on-thread.html
    The Helix piece is probably pretty nice, but there isn't much in terms of user reviews and info floating around the interwebz just yet.
    http://www.diymobileaudio.com/forum/...t-answers.html
  2. #62
    Member Sales Rating: (0)
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Alright, figured Id post an update cause Im sure everybody is anxiously waiting for details on how my install is coming. OK, but seriously this has been the hardest f***ing install I have EVER done! Nothing, and I mean NOTHING has fit the first or even 50th time Ive tried to make it but Im finally over the hump. It took 2 nights but I finally got these mids to fit.
    This was one of the first mounts I made. Id made a couple others but they were too big so I kept having to size them down. This one fit the best.
    Then I ran into my first problem. I realized that Id need more space behind the back of the mid. It uses an AP vent in the back and requires at least a half inch of space behind it. I was gonna use one of the existing holes in the sheet metal (cutting is not allowed in my class). So I cut out a 1/4" piece of MDF to give it more space. Worked perfectly after 2 hours. These Morel mids have the mounting screws about .00001" beyond the cutout. So if the cutout is 1mm too big, its too big to screw the screws in. I went thru a millions cutouts for each. Infuriating! So I got the space I needed but now it wont fit behind the A pillar. So I need to size it down but couldnt figure out how to mount it if I got it too small. Then I thought "L brackets"! So I stopped by Lowes on the way home and after about an hour, came up with this:
    This worked perfectly! Best of all, I had enough room to leave my airbag attached. I did have it unbolted and pushed up into the upper part of the pillar. God help me if that thing ever deployed. You can see all the other drilled out holes from my other 600 attempts to get something to fit properly in there.
    The other best of all was that this left me with a lot of space behind the pillar so I wondered if I could fit my tweeter back there. I tinkered around for a bit and came up with this:
    I think this is going to work very well. The tweeters arent as on axis as I would like but Ive got a lot of processing power so I think I can work with it. This will also have the mid, midbass and tweet working in the same direction and should clear up any phase issues for the most part. The thing I like best is that you wont see any speakers at all. Im going to drill a crap load of 1/4 holes in the trim panels then wrap them in grill cloth. When Im done, the only thing youll see is the sub box in the back and head unit. No speakers or amps will be visible and I will have given up zero storage or leg room aside from the underseat areas of the back seats and front passenger seat.
    Tomorrow I have to work my 2nd job but hopefully I can get the holes drilled in the passenger side trim panel and run the wires for mids and tweets. Then Thursday I can wrap both panels and hopefully have enough time to get the amps hooked up. Friday night at the latest I should be done and can start tuning. Georgia State Finals on the 25th is my goal so that will give me a few days to tune. We're going to Florida for a few days next week so seat time will be precious little.
  3. #63
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    looks good dude
  4. #64
    Join Date
    May 2011
    Location
    Baltimore
    Posts
    8
    Default
    Not sure if it was mentioned elsewhere in the thread but, are you still using the SR's in the doors or have you completely moved away from them?
    Has the system produced sound yet or are you still installing? I thought I saw that you had gotten the amps mounted. I'm anxiously awaiting to see how this comes out..... should be awesome.
    Justin Dorsey
    www.Soundscapemd.com
    (we were the first polkaudio dealer ever)
    ___________________________
    Pioneer 880PRS
    Polk SR6500/5250
    SR104dvc
    C400.4-modded/C500.1
  5. #65
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Yes, still using the SR 5's in the doors for midbass. I'd love to use the 6's but they just wont fit without more modifications than I'm willing (or able) to make. The only non-Polk gear I'm running is the Morel mids and tweets., and the Crossfire amp that'll replace the Polk 2 channel that has pink noise coming out the right side.
    It played music (and pink noise) for the first time last night at 12:30. Haven't listened too much but this thing already sounds very good with ZERO eq! All I did was use some time alignment and crossovers and its already very solid. Not competition ready of course but take not going to take a lot to get it there. The mids and tweets in the A pillars is the best place for them IMO.
  6. #66
    Join Date
    May 2011
    Location
    Baltimore
    Posts
    8
    Default
    Yeah, I saw the other thread about the amp and tweeter problem. I'm sure the A-pillar loc is great, I have no room there even for tweeters unfortunately. Drivers side is taken up by a gauge pod and monitoring my motor trumps tweet location in this car. Best of luck getting all this sorted.
    I have to say when I went from the just the 5250 setup in the kicks to including the 6500drivers in the doors, I also noticed a huge improvement with just time aligning over all previous configurations I had tried, which included 6500's in doors and tweets in sails 2way(had been that way for years). Getting the crossover right has been somewhat time consuming but its def getting there.
    Not that I am comparing our systems as they are quite different and you know well more than I about car audio, but, ears dont lie...
    Justin Dorsey
    Pioneer 880PRS
    Polk SR6500/5250
    SR104dvc
  7. #67
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Yup, there is no replacement for placement. It is everything. No amount of processing can overcome crappy speaker locations. I tried every thing I knew to try with the speakers in the stock door locations of this Edge which are halfway up the door, but couldnt make anything work worth a damn. I put them in the A pillars and with no EQ it already sounds as good as my heavily EQ's system did in the stock locations.
    I just got home so Im gonna go replace that amp and finish hiding all the wires. Im chomping at the bit to get out there and do some tuning. Im really excited about the potential this thing seems to have.
    Youre right tho that most cars have very little room in the A pillar location. This Edge has huge, flat pillars so its perfect. The Honda Civic and Fit are also great and have a big huge area at the corner of the dash and windshield for speakers.
  8. #68
    Join Date
    May 2011
    Location
    Baltimore
    Posts
    8
    Default
    Get that thing tuned up!
    I'll be messing with mine some after work too. something is funky with the amp I installed last night.
    Justin Dorsey
    Pioneer 880PRS
    Polk SR6500/5250
    SR104dvc
  9. #69
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Its ALIVE!
    Yessss! Its playing music and I havent broke anything else! I hooked up my trusty old Crossfire and its playing just fine. Still has the turn off thump it always used to but thats what capacitors were made for (turn off delay circuit. )
    I did a quick tune on it and its sounding pretty good. Not loving the Morel MDT12 tweeters though. Just not enough bite. Think Im gonna put those LPG aluminums in there and see what they sound like.
    I can do that later though. For now Ive got tunes so I can start cleaning up and finish hiding the wires. God what a relief. This is hands down the worst install Ive ever done in my life! And that goes all the way back to 1989 when I first tried to install a Mitsubishi cassette player in my 1977 Mustang Cobra.
  10. #70
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    And done. Well gotta wrap the A pillars since theyre full of 1/4" holes but Im done with everything else. I actually might run up to the local shop and let them wrap the pillars for me. I just know there is no way I could do it and not have a thousand wrinkles and creases. Shouldnt cost more than $50 or $60 I would hope since an experienced guy should be able to do both of them in an hour.
    There is zero wire management. Having to mount everything under the rear seat and still have room for the spare tire right behind them, its all tuck and go. The H701 is under the passenger seat and everything is just tucked in under there too including a 20' Ai-Net cable and 25' optical cable.
    Its embarrassing but it will do til next year when I can dump this thing and trade it in on a more stereo friendly ride.
    Took out the Morels and stuck in these Vifa soft domes and they do a much better job. These are great little tweeters especially considering they only cost $22 a pop. They have much more bite and bring the brassiness of a saxophone out much better. Ill ride with them til I can get my Scan replaced or repaired.
  11. #71
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    You may want to try the SR' tweets too. If you're running the mid-range till 5-6khz and then use the RR's after that, you would be running them in the zone they are best in.
    Did you manage to contact Madisound? Any news?
  12. #72
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Nah its the weekend so wont get in touch with them til Monday.
  13. #73
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Having fun tuning this thing. It sounds very good and is needing very little EQ. Im playing around with different crossover points and levels right now but am getting closer. Right now Im at 4KHz @ 24db on the tweeters, 4KHz @ 24db and 500 Hz @ 24db on the mids then 500 @ 24db and 63Hz @ 24db for the midbass then finally 40Hz @ 24db for the sub. I tried staggering the crossover for mids and tweets but it just had something missing. I wouldve thought that having the mid and tweet right next to each other and firing in the same direction wouldve called for a staggered crossover point so they wouldnt be running all over each other. Doesnt seem to be the case.
    I think these SR 5's will have enough grunt to work as midbass but I do need to look into finding something a little better though for a little more energy.
    I also need to dampen my doors. Got all kinds of resonance there not to mention some other panels. May need to slap a layer of Dynamat on every panel I can for good measure since the sub is actually in the cabin with me.
    Got noise issues for days though. The replacement Crossfire amp has a big turn off thump that I may be able to cure with a big enough delay circuit. Will have to experiment. Ive always thought it was BS that MECA counts off for turn on/off pops. That is in no way the fault of the install or installer. Hell, $1000 Genesis amps have turn off pops. I protest every year but it falls on deaf ears.
    Also found a noise issue with the mids/highs amp. One of those faint buzzes that slowly runs all the way up then back down the frequency spectrum. For some reason its very faint when I use my 18' JL Audio cables but a little louder with my 3' Tsunami cables. Guess the extra resistance is choking if off some. It is very faint and you can only here it if you pause the CD and are in a dead quiet environment so for 99% of shows, I doubt any judge will cue in on it.
    Sigh, guess Im just gonna have to break down and invest in some Zapco ampage.
  14. #74
    Join Date
    Jun 2005
    Posts
    619
    Default
    What brand of components are most people running these days in the competitions? I know focal has to be still at top of list. Also anybody heard about eric stevens leaving imagine dynamics? I hear precision power owns them now. So the brand should go to sh!t pretty soon.
  15. #75
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    I havent been to a finals since 2009 so Im not up on the latest batch of guys. MECA is growing pretty steadily it seems especially out on the western states like California.
    The best guys arent using a particular brand. There arent really any high end car audio speaker makers left anymore except for Morel and Focal I suppose. Most of the top guys are using different combinations of raw drivers from Scanspeaker, Seas, Vifa and even Tang Band. If I had to pick the best brand of car audio speakers though, it would have to be Morel but install and tuning matter the most. Ive seen a world champion win with a pair of $40 mids.
  16. #76
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Alright, I think Ive got my final answer for GA state finals tomorrow. Got the SR 5's playing very low, down to 40 Hz actually. Took some trickery but I think it works.
    MECA uses the Chesky Ultimate Demonstration Disc for their SQ judging but they also use 2 optional tracks and they change every year. I dont like this but a lot of guys do. It always presents a problem that will force you to make sacrifice between the Chesky and optional disc. This year, one of the tracks is Keb Mo - Suitcase. Right where the vocals kick in at 32 seconds I think, that first note is a BIG bomb that was bottoming out the SR's pretty good. I tinkered around and found 80 Hz was the culprit so I cut it 6db and dumped 63 3 db for good measure and that did the trick.
    Surprisingly I didnt lose any midbass energy in kick drums like I thought I would. Guess being able to fatten up 40-50Hz thru the midbass helped.
    Slapped a bunch of foam inside the A pillars as well. Was getting kind of an "echoy" thing going on kinda like if youre talking down a paper towel roller. Stuffed foam into every place I could and that fixed that. Gotta love foam. Dirt cheap and fixes so many things.
    Dont know though, havent been in another car in a while so there is no telling what will happen. State Finals isnt the place to be breaking out a brand new install.
    Also figured out that whine I was having. Embarrassed I didnt think of it before but my sub amp is grounded about 2 feet from the ground for everything else so Ive got a bit of a ground loop going on. Dont have time to fix that tonight so I just hope its kinda noisy at the show tomorrow because its very faint and unless its dead quiet, you aint gonna hear it.
  17. #77
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    GL Bro. Any idea how many competitors expected? Keep us updated from the venue if you can.
  18. #78
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    So I won my class but not convincingly. I need to be in the 80's to stand a chance at finals and I scored a 74. Granted I had 79/74/69 so one judge boned me but he's not known as the best judge in the world.
    I did get some good feedback though. Tonality Im pretty well set. Got high scores all across the board. Imaging is where Im hurting and noise. My left side is very weak. In Spanish Harlem, a pair of violins come in about 1:40. My right side was fine but the left was smeared and not focused. Thought it was the mids needing to be angled in more so when I got home I rigged them to angle in a tad more but this didnt help. So I stuck the tweeter in the sail panels and this helped a lot! I guess the tweeter sitting right next to and in front of the midrange just wasnt working. Works much better with them in the sail panels and the stage is noticeably wider albeit a tad lower now but not too much I dont think.
    The noise I can hopefully fix by fixing up my grounds and grounding everything to one spot. Ill give that a try tomorrow night when I get home from work.
    Alabama finals are next week and thats the big one. One of the best SQ judges the business will be there. He'll also be a judge at world finals this year so if I get a high score from him, I know Ive got a shot. If he trashes me, Ill wait to next year. Not blowing $300 to finish 5th!
    On the up side, so long as I finish at least 2nd at Alabama Finals, I will have my 4th state championship. You gotta have 40 points to qualify for world finals and state championship as well. So yay me! One more cool thing to add to my sig hopefully.
  19. #79
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Alright well Im in. Registered today. Sheer insanity if you ask me. Its the most competitive class, its the class with the most competitors and 3 weeks ago my car was bone stock. Something tells me I shouldve lit that $165 and smoked it instead. Wouldve got more out of it. Good God Im gonna get stomped.
    Last day for registration is tomorrow but the list so far looks pretty thin (except for my class of course). We've got a couple classes with only 1 competitor! Mark Eldgridge is in his class all by his lonesome! The list usually grows a bunch the last day of registration so I hope it does so again.
  20. #80
    Join Date
    Oct 2004
    Location
    North Texas
    Posts
    6,118
    Default
    Cash prizes?
  21. #81
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Ha! Never. Well almost never. I think the 2 seat class has a cash prize maybe. Mostly its for bragging rights and one of those big ass 6' trophies.
  22. #82
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    3rd place. I suck.
    I'm pissed now though. 5th finals and I still can't win. I'm going balls to the wall next season. I'm winning next year. This is getting ridiculous. I lost 3 points to system noise with turn on pops and such. Gonna have to do an overhaul.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. MECA SQ competition in Dickson, TN
    By MacLeod in forum Car Audio & Electronics
    Last Post: 09-14-2011, 01:26 PM
  2. 2009 MECA World Finals
    Last Post: 10-09-2009, 05:48 PM
  3. MECA Finals pics
    Last Post: 12-13-2006, 11:57 AM
  4. MECA World Finals
    Last Post: 11-13-2006, 10:57 PM
  5. MECA Rules!!
    Last Post: 01-08-2006, 11:39 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
