Good or bad for entry level amp(s)? I realize Carver went out of business but that's not necessarily a bad thing.
Any info someone can give me about them would be great.
How do Carver amps sound combined with my in your face Rti8s and Csi5?
Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online StoreGood or bad for entry level amp(s)? I realize Carver went out of business but that's not necessarily a bad thing.
Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1
They have a huge following and are frequently connected to Polks of all kinds.
If you want best of breed, this man has a good reputation for making stock units better:
http://carvermk2.com/
VTL ST50 w/mods/RCA6L6GC/TlfnknECC801S
CJPV-5 w/mods
TT CJ Sonographe SG3 Oak/Sumiko LMT/Grado Wood Plat/Sumiko PIB2/The Clamp
Musical Fidelity A1 CDPro
Tuners w/mods Kenwood KT5020/Fisher KM60
MF x-DAC V8, HAInfo NG27
Herbies Ti-9/Vibrapods/MIT Shtgn AC1 IEC's/MIT Shotgun 2 IC's/MIT Shtgn 2 Speaker
PSAudio Cryo PwrPrt Prem/ExctPwrEP15A
Wlnt SDA 2B TL/Oak SDA SRS II TL-Sonicaps/Mills/Cardas/Cust SDA ICs/Mortite/Dynamat Extreme/TFLF Rings/FSB-2 Spikes
NAD SS rigs w/mods
GIK panels
I have owned quite a few Carver amps. I like them very much!
Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
Very neutral sounding, for their budget stuff, if your looking for a cheap carver amp to tame the rti8's brightness, you may be barking up the wrong tree. Just sayin' is all.
general consensus says they had some winners and losers, I have a m4.0t i recently had rebuilt, and a TFM 42 (same amp with a different outer shell as the 4.0t)
the rebuild I did to the 4.0t means that is pretty much going to be my amp for life.
Incidentally, these amps lean pretty much to the warm side, as they were specifically voiced to sound like Carver's signature amp at the time (Carver Silver 7)
Theater - Polk LSi15, LSiC, LSi9 speaks, DIY Sub (142.5L box, SVS plus driver, 500 Watt plate amp)...Outlaw 990 pre/pro, Carver TFM45, 2 X Outlaw M200 . Rotel RB980 . PS3, Monster 3600 power center
2 Channel -
Anthem Pre 2l, Jolida JD100 CD player, CAL Sigma DAC, Carver m4.0, Polk LSi9 w external modified Crossovers (thanks Trey!)
.... double post
2 Channel -
I am running a 5 channel Carver amp (AV-705X) with my Monitor 60's (bi-amped currently) and a CS2 and honestly love the combo.
I did have some issues with the amp originally (see my Carver thread) but a bit o solder fixed that up easy as pie.
There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
Advice is free, the Flea Market is earned - F1Nut
My Sales Rating > 10
^^^reported, be slow to remove tho, she's awefully cute with that slight nip-slip.
i like carvers sound, but would never personally purchase one without it being a great deal
some cheap free sony speakers
psw125
denon 1610
3.1 channel because i hate cables ran across the living room like that
post # 9 spam reported - thalgetycle
CJPV-5 w/mods
NAD SS rigs w/mods
GIK panels
CJPV-5 w/mods
NAD SS rigs w/mods
GIK panels
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
A carver M1.5t was my first and second amp, I still have them and a 1.0t. I bought them when I thought power was the answer and it was for that set up (RTi12s for HT). I still might hook up the 1.0t this summer so I don't kill my A/C with the tube mono blocks I bought this winter. But, I like my carver stuff and would recommend them to anyone that wants a lot of power cheep that was built well.
Now if you want some really nice Bob Carver designed products go look a his Sunfire gear. I have one of the 400x7 in my HT and have loved it everyday since it showed up.
If life had more tubes it would be a lot smoother.
I have always enjoyed Carver amps with Polk speakers.
PM sent
I see your point about an amp being for music but wouldn't movies sound better if you had more power running to your center channel as well as your fronts? I figure a channel amp is just as cheap as a 3 channel from what I've found and at least that way all of my speakers are powered by the same amp.
it was directed right at me, i dont do HT, that was my point to ES, i am a 2 channel guy, so a five channel amp is on the verge of useless to me unless i only want to run 2 of the five. plus i dont think id use a carver for music, personal preference, wont start a debate over it
psw125
denon 1610
I love my carver mono blocks,silver 7 t.when the opportunity come to get the Silver 9t I will. One day I'll have the Carver Silver 7 and The Krell mono bloc.Hey,seek and you shall find.
PolkAudioClyde
I was in Jacksonville Fla at sound advice,now decease, and a guy and I got into a friendly debate about the Carvers.he was talking about the Harmonic Distortion of the carvers and how the Apogees<spell check,sounded better than the Polk 1.2's,don't think so.
PolkAudioClyde
How old are the Carver av-505s now?
Carver amps are not my cup of tea, but there are a lot of people here who use them and are happy. It's my opinion that many times you'll pay more for a used Carver amp than better performing second hand amps at equal or lower prices.
but I think it's pretty unanimous advice that the "cube amps" (m-400) should be avoided. but then again, im sure there are a few that even like those.
Good build quality but they tend to be on the bright side.
O
In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence.
"The best way to enjoy digital music reproduction is to never listen to good analogue reproduction". - Kenneth Swauger
A friend of mine had a Caver amp, I believe it was the A-220. It was a nice sounding amp and looked super cool. To me the sound seemed on the fast side, a little bright. Don?t get me wrong it was a nice amp but I like an amp with a little less snap. I think it would make a great home theater amp.
O
There are currently 1 users browsing this thread. (0 members and 1 guests)
