Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 30 of 72
Thread: LoMC Cart
  1. #1
    Member Sales Rating: (22)
    Join Date
    Oct 2008
    Location
    Directly over the center of the earth in Olathe Kansas
    Posts
    5,795
    Default LoMC Cart
    I recently secured the matching SUT for my Wright tube phono stage.
    My TT is the Marantz badged ClearAudio using Satisfy tonearm.
    Looking to get a LoMC cart.
    Budget is 2 price points $500 and $1000.
    Considering the following.
    Ortofon Rondo series specifically the Blue Rondo
    Dynavector 20x2 and 17D3
    Micro Benz Ace or Glide
    Looking for feedback or other Carts I should consider. I want the giant killer.
    I believe the Satisfy tonearm is light to medium compliance.
    Ofc: Wright WLA12 preamp: Anthem Amp 1: Pio Elite DV-79AVI: Airport Express: CAL Sigma II DAC: PA LS90 sonicaps and mills
  2. #2
    Member Sales Rating: (47)
    Join Date
    May 2005
    Location
    Sufficiently Breathless
    Posts
    11,101
    Default
    I like my Dyna 20 xl -- cannot comment on the 17D3,, shoot Rich(scomp) a pm,,
  3. #3
    Join Date
    Oct 2008
    Location
    Posts
    5,795
    Default
    Thanks George. The Dyna 20 is a serious contender. Also looking at the SHelter 501 MK2 but between the 2 some people seem to prefer the DYna.
    I have to get this right as I want to cry just once.
    Come on vinyl guys let hear your thoughts and experience.
  4. #4
    Member Sales Rating: (1)
    Join Date
    Dec 2004
    Location
    GA--Rollin' down Hwy 41
    Posts
    2,855
    Default
    What voltage output do you need from the cart? The cart and SUT output should match the input on your stage. You could underload or overload if you are not careful in chosing the correct gain. Random choices could provide additional tears.
  5. #5
    Join Date
    Oct 2008
    Location
    Posts
    5,795
    Default
    Excellent point and thank you. All I know about the Wright SUT is "stock" load of 100 ohms and is 1:10 ratio.
    I have read about people changing the stock load to closer match their cart by adding resistors via Y connectors on the input of the SUT.
    What other information would I need to know to determine best match for cart voltage?
  6. #6
    Join Date
    Oct 2008
    Location
    Posts
    5,795
    Default
    Is there a calculator online that will help me match SUT and cart?
    Here is the data on the Dyna 20x2.
    Technical Data:
    •Type : High/Low output MC cartridge with Flux damper and Softened magnetism
    •Output voltage : 2.8mV / 0.3mV (at 1KHz, 5cm/sec.)
    •Frequency response : 20 - 20,000Hz (?2dB)
    •Channel Separation : 25 dB (at 1KHz)
    •Channel balance : 1.0 dB (at 1KHz)
    •Compliance : 12 x 10-6 cm/dyne
    •Impedance : R=150 ohms / 5 ohms
    •Stylus tip : Micro Ridge Nude diamond
    •Cantilever : 6mm length hard aluminum pipe
    •Tracking force : 1.8 - 2.2 grams
    •Recommended load impedance: >1000 ohms / 30 ohms
    •Weight : 9.2grams
  7. #7
    Join Date
    Dec 2004
    Location
    Posts
    2,855
    Default
    There are other issues to contend with but this is a start.
    http://www.hagtech.com/loading.html
    Vinyl Asylum and Vinyl Engine has some helpful reading.
  8. #8
    Join Date
    May 2005
    Location
    Posts
    11,101
    Default
    IIRC my dyna has an output voltage of 0.28 mv,,and my denon is less than .5,, with my Cinemag SUT,,I can switch between 1:10 and 1:20 ,,can't hear that much of a difference,,to my old ears,,I will say that the Dyna and SUT is just simply stellar,,90% of my listening is vinyl,, a year ago,,it would have been different.YMMV-- consider the dyna line though,,well worth the price of admission.
  9. #9
    Member Sales Rating: (5)
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,522
    Default
    If you're looking for a cart and will go up to a 1000, you have to consider the Empire 501 Mk II. There's a really good reason that everyone that hears one says you'd have to spend at least 3K to get a better cart.
    Are you part of the dirty digital peasants or a member of the great Analog Master Race?
    SDA Recommended Playlist https://docs.google.com/spreadsheet/...FZCRkdxYXVNanc
    Open for editing.
  10. #10
    Join Date
    Oct 2008
    Location
    Posts
    5,795
    Default
    Thanks Rob but do you mean Shelter or Empire? I think you mean Shelter
  11. #11
    Member Sales Rating: (3)
    Join Date
    Sep 2007
    Location
    British Columbia (Canada eh)
    Posts
    3,479
    Default
    I am currently using the Benz Glider M2. They make an updated low output version that is supposed to be even better than mine. It must be mind blowing because the M2 is the best cart I've had on my system. Beautiful highs, if not slightly laid back, amazing bottom end, and the best mids I've ever heard on an analog system. This cart makes poorly recorded LP's sound good and well recorded albums sound fantastic. The only downside (if you can call it that) is that the stylus hangs out in front and you must be really careful when mounting. However, that's one other thing that makes it good. Because you can see the cantilever so well, it makes aligning easy. Just use the cantilever. I've got mine nearly perfect. I strongly recommend this cartridge, you won't be disappointed.
    Kelvin
    SDA-1C (full mods)
    Carver TFM-45
    NAD 1130 pre
    Nitty Gritty 1.5FI RCM
    The Clamp
    Nakamichi CR7 Cassette Deck
    Rotel RCD-855 with tube output stage
    Cambridge Audio DACmagic Plus
    DBX 3BX-DS
    DBX 224-DS
    ADC Soundshaper 3 EQ
    Ben's IC's
  12. #12
    Join Date
    Oct 2008
    Location
    Posts
    5,795
    Default
    Interesting you mention the Benz Glider. I spent about 45 minutes with Matt at NeedleDoctor yesterday looking for more clarity on carts that are a good match for my tonearm and SUT.
    Looking more like the Benz Glider SL is what I will get.
  13. #13
    Join Date
    Sep 2007
    Location
    Posts
    3,479
    Default
    I'm using my Benz with my Pro-ject 6.9 table with 9" arm and a PS Audio head amp (which is really a step up transformer in one box and an adjustable in/out module in another) in combination with my Eico's phono pre amp is total magic. The Benz sounds really good with my Carver TFM-45 and C1 pre but it's just in another world with the Eico and PS Audio. You'll really enjoy that Benz if you get the right combination. Your table with Satisfy arm should play really nice with the Benz SL.
  14. #14
    Join Date
    May 2005
    Location
    Posts
    11,101
    Default
    I'll follow up in this thread soon.I just received an e-mail that my Dyna 20 XL is ready to ship back from Soundsmith,,I had the cart. retipped with the ruby cantilever option,, prior to it's removal in did sound fantastic with the SUT (cinemag) that I was using.Always wondered what the rave was about,,now I'll find out if they are true.The Benz carts' that I have heard were very "organic" with nice detail/seperation.Good luck in your journey down the rabbit hole.
  15. #15
    Join Date
    Oct 2008
    Location
    Posts
    5,795
    Default
    Look forward to hearing your impressions George !
  16. #16
    Member Sales Rating: (2)
    Join Date
    Jun 2004
    Location
    New England
    Posts
    7,985
    Default
    Quote Originally Posted by thsmith View Post
    Looking to get a LoMC cart...
    Just noticed you have a Wright phonostage and thought I'd mention, in case you hadn't heard, that Allen Wright has just recently passed away:
    http://www.audioasylum.com/audio/gen...58/585284.html
    http://www.avguide.com/blog/allen-wright-passes
    all the best,
    mrh
  17. #17
    Join Date
    May 2005
    Location
    Posts
    11,101
    Default
    The Wright that thsmith has is a George Wright(washington state) piece,,and sadly too,he passed about 1 1/2 years ago.
  18. #18
    Join Date
    Jun 2004
    Location
    New England
    Posts
    7,985
    Default
    whoops... I knew of both gentlemen and still managed to mix them up :-(
    all the best,
    mrh
  19. #19
    Join Date
    May 2005
    Location
    Posts
    11,101
    Default
    Guys,, first George,,then Allen,, Gary Dodd hospitalized with apparently life threating/changing issues,,and we lost a co-worker today,who is 10 years youger than me,,just makes me realize my own mortality.I suppose that it's a road that we all will travel eventually.My heart is heavy today gents.well,, at least the re-tipped dyna is on the way,,now to discharge those 500 volts caps,,it's all good.George,,over and out.
  20. #20
    Join Date
    Jun 2004
    Location
    New England
    Posts
    7,985
    Default
    the thermodynamics (end state) is never in question, only the kinetics (rate at which the end state is achieved) :-(
    all the best,
    mrh
  21. #21
    Join Date
    May 2005
    Location
    Posts
    11,101
    Default
    I suppose you are right,,,reminds me of a sayin' I recall,,,something like,, "it's good to have an End to journey towards,,but,in the end,,it's the journey that matters",,thats as close as i can get the quote,,but you get the point.
    found it,,
    “It is good to have an end to journey toward; but it is the journey that matters, in the end”
  22. #22
    Join Date
    Oct 2008
    Location
    Posts
    5,795
    Default
    Tough times for sure.
  23. #23
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,522
    Default
    DOH... shelter. Invite to try the Shelter with your SUT. Also, recommended impendence is 100 Ohms, so your SUT should be a good match.
    Open for editing.
  24. #24
    Join Date
    Oct 2008
    Location
    Posts
    5,795
    Default
    Quote Originally Posted by quadzilla View Post
    Hummmmm, that is a very nice offer. Let me think on it.
  25. #25
    Member Sales Rating: (6)
    Join Date
    Apr 2008
    Location
    GA
    Posts
    2,143
    Default
    I am casting another vote for the Dynavector 20X. I love mine! George your in for a treat, mine has also been retipped by Soundsmith with the ruby cantilever and diamond stylus. I never heard it stock, I bought it off the 'Gon already modified. The original owner said it made a pretty signifigant difference. It has good accurate lows, sweet mids, and very detailed, yet smooth highs. I love the soundstage,imaging, tracking, and overall tone of this cartridge. I must note I am running this on a heavily modified KAB-Technics SL-1200 table using a Jolida JD-9 phono Pre with NOS RCA 12AX7 tubes. It sounds fantastic!
    George let us know what you think of the Soundsmith mods. I'm curious how the it compares to the stock cart since I never got to here it stock. Cheers.
    Steve
  26. #26
    Join Date
    May 2005
    Location
    Posts
    11,101
    Default
    will do-- the stock dyna 20/cinemag was very good.soon,guys,,soon
  27. #27
    Join Date
    Oct 2008
    Location
    Posts
    5,795
    Default
    Pulled the trigger on the Benz Micro Glider SL.
    George how is the Dyna sounding ?
  28. #28
    Join Date
    May 2005
    Location
    Posts
    11,101
    Default
    still waiting on it-- should be here any day.
  29. #29
    Member Sales Rating: (12)
    Join Date
    Feb 2005
    Location
    Plainfield, Illinois
    Posts
    5,282
    Default
    Quote Originally Posted by george daniel View Post
    I like the Dynavector line. Anxious to hear what you hear with the Soundsmith retip George.
    Good choice thsmith. Congrats!
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's
    Krell KSL Class A Pre w/ KSL Phono
    Krell Class A KSA-250
    Harmonic Technology Pro 9+
    Squeezebox Touch / Welborne Labs PS / I2S Out Mod
    Denon 3910 w/I2S/DSD Out
    Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC
    Sennheiser HD650
    Heavy Plinth Lenco L75 Idler Drive
    AA MG-1 Linear Air Bearing Arm
    Dynavector 17D3
    Shunyata Hydra (Original)
    NHT B-12d subs
    GIK Acoustic Treatments
    CP Showcase
  30. #30
    Join Date
    Oct 2008
    Location
    Posts
    5,795
    Default
    My BMS Glider SL arrived yesterday but probably won't get it mounted until Saturday.
    One thing that surprised me was they do not provide a stylis protective cover.
    For the money this cost it should but I can see where a nude body cart would be hard to attach it to.
    Need to have my A game handling this cart for the install.
    I do like that the body is threaded so no pesky nuts to deal with.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. $300 MM Cart vs $950 MC Cart
    By 187CAM in forum 2 Channel Audio
    Last Post: 07-03-2009, 11:38 PM
  2. It's Shades of CART all over again
    By Jstas in forum The Clubhouse
    Last Post: 06-27-2009, 04:45 PM
  3. TT Cart question...
    By unc2701 in forum 2 Channel Audio
    Last Post: 04-06-2007, 08:59 PM
  4. $200ish TT cart?
    Last Post: 04-18-2006, 10:04 AM
  5. looking for mmc cart. for b&o
    By hotwheelman in forum Flea Market
    Last Post: 01-10-2004, 12:16 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
