Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 61 to 90 of 108
  1. #61
    Member Sales Rating: (2)
    Join Date
    Sep 2007
    Location
    Seattle, WA
    Posts
    540
    Default
    Quote Originally Posted by geoff727 View Post
    But I think I freed up a cubic litre of space inside each speaker!
    What's funny is, the first thing I thought when I got out of bed today was, "did I actually write that last night?!" Yep, I did.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Monitor 4.6
    Polk Lsi9
    Infinity RS-II (modded)
    Infinity RS-IIIa (modded)
    Infinity RS 2.5 x 2
    Magnepan 1.6QR (modded)
    System: http://forum.audiogon.com/cgi-bin/fr...vol&1290711373
  2. #62
    Join Date
    Sep 2007
    Location
    Seattle, WA
    Posts
    540
    Default
    Quote Originally Posted by filmfreak1138 View Post
    Thanks again! I'm looking forward to seeing, and HEARING, these speakers at the April meet-up!
    I got both the 15th and the 16th off work, so we are on for Friday afternoon/evening for you to come over here and spend some time getting to know them again. I am putting together a playlist of things I would like you to hear on them. And, if you want to bring some CD's or vinyl, please do so. Then you can listen, uninterrupted, for at least a couple hours. Pick them apart, or just relax and enjoy, either way.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Monitor 4.6
    Polk Lsi9
    Infinity RS 2.5 x 2
  3. #63
    Join Date
    Sep 2007
    Location
    Seattle, WA
    Posts
    540
    Default
    Quote Originally Posted by Joe08867 View Post
    Secondly, I had an issue with resonance at certain frequencies on my SDA2's and used a strip of dynamat about 2 inches wide in an X pattern along the sides and back and it worked wonders....
    Yes, Dynamat is neat for all kinds of things, isn't it? When Roger and I were deciding on what he wanted to do on these, we talked about the various internal linings. Price-wise, it basically came down to either 5 sheets of 3-layer Sonic Barrier, or a lesser quantity of NoRez. Would the adhesive-backed vinyl layer on the NoRez have made a difference, even in a lesser quantity? I don't know. It may have afforded some damping, it may have increased the mass of each panel wall so that any resonance is a few Hz lower. Who knows. Tough to say without doing some tests.
    What I can say for sure is, the clarity of vocals is much better. The 'singing into cupped hands' coloration is substantially reduced, which is a welcome improvement.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Monitor 4.6
    Polk Lsi9
    Infinity RS 2.5 x 2
  4. #64
    Join Date
    Sep 2007
    Location
    Seattle, WA
    Posts
    540
    Default
    Quote Originally Posted by danger boy View Post
    I am curious as to why with the increased inside material for sound absorbtion that one of the speaker is resonating at certain frequencies? wouldn't the sonic barrier control that?
    Basically, the mian goal here with the application of that kind of material is to cut down on internal reflections that bounce around on bare-wood internal enclosure walls. Internal reflections make their way back out of the enclosure via partially-sonically-transparent driver cones (the 2 mid-bass drivers). This colors the midrange and midbass sound of the speakers. The proper amount and type of internal fill is important also. In fact, it would be interesting to experiment with different amounts of natural wool fill in these, a material which naturally has differing lengths of fibers and typically produces some of the smoothest "fill response" inside enclosures. Actually, I have some other fill on hand and i might experiment before Roger gets here and see if I can get some moderation at that frequency, in case I am wrong about that being an enclosure material resonance.
    The 3-layer Sonic barrier has a vinyl layer in the middle that's supposed to act as an "isolation" layer, the intent being to isoalte the effect of the push and pull of sound waves on the enclosure walls. Because, obviously, the more the enclosures walls vibrate, the more they become a sound source of their own, and the more they interfere with the purity of the music. So the goal of this stuff is two-fold: reflection reduction and vibration reduction.
    Without bracing the enclosure walls, I wanted either direct vibration damping or isolation in there. As i wrote to Joe above, the choice came down to either the 3-layer Sonic Barrier (which has a measure of isolation but no direct enclosure wall damping) or a lesser quantity of NoRez (which has direct enclosure wall damping but no isolation). I think Black Hole 5 has a little bit of both, but it was beyond the budget at 50-some dollars per sheet.
    So, we made our choice and went from there. Indeed, the Sonic Barrier is reducing vibration of the enclosure walls. All you have to do is put your hand on the side of the enclosure while they're playing music, and they obviously vibrate less now. But, it's not a perfect material, so the effect is not 100%. It's almost like controlling symptoms, rather than getting to the heart of the medical matter. The heart of the medical matter in this case is the 3/4-inch-thick particle board enclosures. Now, could Polk have built these out of 1 1/2-inch thick baltic plywood for a sonic improvement? Sure....but then we'd be paying 2000 dollars for a pair of 12's or SDA's instead of 1000 dollars, and Matt Polk's potential market would have gone way down. Which means economies-of-scale would have been reduced, further increasing the price and further reducing the market.
    If the enclosures are indeed resonating at that frequency (or narrow range, actually, depending on the Q [width/height relationship] of the resonance), I'd speculate that the isolation layer is probably helping things, and I may be perceiving the resonance because of the added clarity of everything else. This is just a guess. Because the Sonic Barrier is not perfect, if that one frequency is still 'let through' then it will set the enclosure wall into resonance.
    But, I think I'm going to experiment, in the hopes that I am misinterpreting what I'm hearing, and that I can moderate that "bump" down a little bit.
    G~
    This is just an aside, but look at this review of the LSi7. In Fig. 2 of the Measurements section, you can see two definite enclosure panel resonance modes. http://www.stereophile.com/content/p...r-measurements
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Monitor 4.6
    Polk Lsi9
    Infinity RS 2.5 x 2
  5. #65
    Member Sales Rating: (1)
    Join Date
    Apr 2007
    Posts
    3,920
    Default
    The resonance wasn't everywhere just a particular note range that would really bring it out. Kind of almost a warbled buzzing sound. Not at all loud unless the volume control was really cranked up. It was more of a nuisance as it took me out of a listening state to troubleshooting state.
    Like I said I had the same issue in my SDA2's. and the Dynamat was the difference. The sonic Barrier was good but the two together was awesome. I understand that price is always a big issue, for me as well. I don't want to dump 1,000's into a speaker I paid 250 for. Luckily I had the Dynamat from another project (Car) so it was money I had spent already. So it was free for this project sorta.
    I hope you find another method to get rid of the vibration. It would be nice to have another trick to use that wont intrude to much on the volume of the speaker like braces would.
    Quote Originally Posted by Timothy Smith View Post
    WOW!
    That's like working your way through Katie Perry in order to get to Rosie O'Donnell.
  6. #66
    Member Sales Rating: (0)
    Join Date
    Dec 2009
    Location
    Canuckistan
    Posts
    3,146
    Default
    Nice job and great attention to detail.The nicest vintage Polk reburb I've seen.
  7. #67
    Join Date
    Dec 2010
    Location
    Central NC
    Posts
    2,526
    Default Geoff727, following your lead!
    Just ordered sonicaps and mills from Sonicraft!
    Getting ready to bring my RTA 12C's to the next level, or at least back to as new condition. Still gathering materials so I probably won't start for a week or two. I've struggled a bit with the cost of all this stuff vs. the value of the speakers, but in the end I enjoy doing this type of work. Also, if the improvement is similar to that which I heard with similar mods I did to my DT BP30's it'll be worth it.
    Where did you buy the Neutrik connectors and what model are they? Did you consider hardwiring everything, or would it have been too difficult to move the speakers?
    Have you had a chance to do any more listening, and, if so, what are you hearing?
    Thanks,
    Fred
  8. #68
    Join Date
    Sep 2007
    Location
    Seattle, WA
    Posts
    540
    Default
    Quote Originally Posted by FTGV View Post
    Those are some very kind words.
    Thanks again for the compliments that everyone has written.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Monitor 4.6
    Polk Lsi9
    Infinity RS 2.5 x 2
  9. #69
    Join Date
    Sep 2007
    Location
    Seattle, WA
    Posts
    540
    Default
    Quote Originally Posted by drumminman View Post
    Sonicaps for the whole crossover? Wow, that's commitment!!
    It's a labor of love, no doubt.
    They're available at PartsExpress or Mouser Electronics. I'm sure a lot of other places too. About hardwiring them, no I didn't consider it. Roger wanted these to retain the original configuration, and needed them to be detachable to fit in the back of his car for the return trip to his house.
    The midrange bloom around that one frequency is still there, but i think i may have moderated it a bit by settling on a polyfill amount of 70%. I still think this is due to the cabinet, and no amount of polyfill experimentation is going to effectively change this. I may move one of the speakers next to my computer, run an impedance plot, and see if the trace has any small bumps which would verify my thought.
    Other than that, the bass is very much cleaned up compared to stock. The treble is much, much better. It will continue to improve when Roger can put in high-quality fuses instead of the cheapies that I have in there now.
    G~
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Monitor 4.6
    Polk Lsi9
    Infinity RS 2.5 x 2
  10. #70
    Join Date
    Mar 2010
    Location
    The Burgh
    Posts
    321
    Default
    WOW!!!!, great job & thanks for sharing on this forum and for sharing.
  11. #71
    Member Sales Rating: (11)
    Join Date
    Jul 2001
    Location
    Spokane, Washington
    Posts
    15,835
    Default
    what's the latest verdict on the updated RTA12's Geoff? is burn in time complete?
  12. #72
    Join Date
    Sep 2007
    Location
    Seattle, WA
    Posts
    540
    Default
    About as complete as it's going to get, I think. I listened for about 2 hours last night. Everything sounds pretty good to me; my initial impressions still stand. I think the speakers have made a large improvement, all around. I am much happier with the clarity, dynamics, and musical communication from top-to-bottom. I think Roger's money was well spent.
    I suppose you are anxious to have Roger over and put them side-by-side w/ your SDA's? Ya, I'd like to listen to that. That would be an interesting comparison, between two similarly-sized same-generation speakers.
    I got the 15th off (the day before our get-together, assuming it's still going on) to have Roger over, so I can spend some time with him going over some specifics of the speakers, both functionally and sonically. But I know he's thinking about not doing it if the get-together falls through. So PLEASE help me convince him not to skip this important step. He needs to hear them set up and driven properly to have a 'baseline' sound for setting them up in his own system, and I need to show him specifically some things they're doing now that they were not doing before- subtle things I don't want him to miss. Without this, I think he risks some disappointment with the upgrades. He's invested a fair amount of time and money in these, and definitely should not skip this final step. So can you help me with that?
    Geoff
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Monitor 4.6
    Polk Lsi9
    Infinity RS 2.5 x 2
  13. #73
    Join Date
    Mar 2011
    Location
    Gamehenge
    Posts
    260
    Default
    Geoff I know I have already said this, but your work is amazing. I am sure the speakers sound great.
  14. #74
    Join Date
    Oct 2009
    Posts
    35
    Default
    DAGNABIT! DARN IT!!!!!!!!! I see those and wish I had extra green and time so I could upgrade my two pair! I mean SHEESH! With all the wishful lists on the musical heaven YOU have to make a storm ! LMFAO! Great work!! SEXY TOO!!!!!!!!!!!!!!!!!!!
  15. #75
    Join Date
    Sep 2007
    Location
    Seattle, WA
    Posts
    540
    Default
    Some of you guys kill me. :tongue:
    I am really gratified with all the good responses this thread has gotten. I'm amazed people are still looking at it! In less than two weeks, they go to the Seattle get-together and then home with their owner.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Monitor 4.6
    Polk Lsi9
    Infinity RS 2.5 x 2
  16. #76
    Member Sales Rating: (49)
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,218
    Default
    Geoff,
    That is a very beautiful job!!! Love the detail in your work and your post..
  17. #77
    Join Date
    Jul 2001
    Location
    Spokane, Washington
    Posts
    15,835
    Default
    Geoff, sorry bud, I missed your response on March 22.. but Roger is very interested in hearing the 12's are your place.. and i'm sure you two have spoken since your post.
    I too may be making the trip on the 15th to your place if you don't mind me stopping by as well to hear the newly improved speakers.
    Things are moving forward for the get together at bikerboys house the following day. I think you said you'd be there, right?
    This will be a fun weekend of speaker and gear listening.
    PolkFest 2012, who's going>?
    Vancouver, Canada Sept 30th, 2012 - Madonna concert
  18. #78
    Join Date
    Oct 2007
    Location
    Dallas, TX
    Posts
    245
    Default
    WOW, you sir are an artist and a craftsman, I raise my glass in your direction.
    To paraphrase ‘If these were mine…I would have...strip the vinyl veneer off.’ I am surprised they have vinyl veneer. My RTA12C’s are only 611 off in serial numbers from these and are finished in real wood veneer, odd.
    Thanks so much for the detail you went in to, I have downloaded the picture of the crossover with the values written on the parts. When I build up the courage to take the plunge I will refer to this post as guidance.
    Thanks!
    Abel
    Polk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
  19. #79
    Join Date
    Dec 2010
    Location
    Central NC
    Posts
    2,526
    Default It's a great tutorial
    I'm 3/4 of the way through rebuilding mine with Sonicaps, mills, and teflon OCC 18awg solid core wire.
    Geoff wrote a really clear and concise guide that was a tremendous help to me.
  20. #80
    Join Date
    Mar 2011
    Location
    Gamehenge
    Posts
    260
    Default
    Now that I am in the middle of doing a lot of these upgrades to my RTA's I have a better appreciation for what Geoff put together.
    As Drumminman said this really is a great guide! Thanks Geoff!
  21. #81
    Join Date
    Sep 2007
    Location
    Seattle, WA
    Posts
    540
    Default
    Quote Originally Posted by factorz View Post
    Ya, they're a pain in the neck, aren't they?
    Anyway, I'm glad this thread helped!
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Monitor 4.6
    Polk Lsi9
    Infinity RS 2.5 x 2
  22. #82
    Join Date
    Feb 2010
    Location
    San Antonio, Texas
    Posts
    157
    Default
    Saweet Job geoff - my RTA' 12's are calling your name all the way down from here in San Antonio Texas....
    Pioneer Elite SC-35, Polk RTA (Real Time Array) 12's,
    Polk Monitor 40 surrounds, Polk CSiA4 Center,
    Polk PSW125, Sharp LC-46D62U,
    Panasonic DMP-BD85, Harmony One,
    iMac streaming an Apple TVII, or Squeezebox Touch
    Bedroom Rig~Sony STRDG-920, Polk Monitor 60 fronts, Polk RM6750 Satellites and Sub, Panasonic DMP-BD85
    Rabbit Hole Rig~Yamaha CA1010, Yamaha CT1010, Polk SDA 2A's, Teac A1500 R2R
  23. #83
    Join Date
    Jun 2011
    Location
    Wilmington, NC
    Posts
    600
    Default
    Excellent work! Thanks for taking the time to share. Very helpful.
  24. #84
    Join Date
    Sep 2007
    Location
    Seattle, WA
    Posts
    540
    Default
    Thank you, folks. I'm amazed this thread is still getting views.
    G~
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Monitor 4.6
    Polk Lsi9
    Infinity RS 2.5 x 2
  25. #85
    Join Date
    Jan 2011
    Location
    fla
    Posts
    1,806
    Default
    Absolutly fantastic job!!!!
    Main Rig:
    Krell KAV 250a
    McIntosh MC 2120 bi-amped
    Into JBL L123 drivers
    Rane external crossover.
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    ADCOM GDA 700 DAC ( MODDED)
    YAMMY CDC-665
    Marantz 6100 tt w/pickering XV-15/625E cart.
    POLK RTA-12C'S W/ RDO194 TWEETS, clarity ESA caps mills risistors (full mod)
    MIT exps2 speaker cable
  26. #86
    Member Sales Rating: (7)
    Join Date
    Oct 2006
    Location
    Spokane, WA.
    Posts
    1,664
    Default
    Might be way off here, but if the owner of these speaks is Roger from Spokane, DangerBoy's friend, I think they used to be mine!
    If so, I'm thrilled to see them getting so much TLC!
    If not, well, ditto!
    "Wish I didn't know now what I didn't know then." Bob Seger
  27. #87
    Join Date
    Mar 2011
    Location
    St. Louis
    Posts
    309
    Default
    Yeah this is a great thread. Very well-written and thorough and shows all the meticulous work that went into the project.
    Thanks for sharing.
    POLK AUDIO SRT (Signature Reference Theater)
    Pioneer Elite SC-09TX AVR
    Pioneer Elite BDP-09FD Blu-Ray
    Pioneer Elite BDP-33FD Blu-Ray (Region-Free)
    Custom HTPC w/Multi-Lane SATA Hot-Swapable Drive RAID Tower
  28. #88
    Join Date
    Sep 2010
    Location
    I'M BANNED,I'M NATIONWIDE
    Posts
    2,705
    Default
    G~
    This thread will be historic!
    And not in a Hurricane Irene way either.
  29. #89
    Join Date
    Jan 2010
    Posts
    11
    Default
    I love my RTA12c's even more after seeing there potential .........
    if I could just find a second set I would be thrilled....
    but it is inspiring to see such fine craftsmanship ,I do have one question ,mine blows the 3/4 amp fuse located on the tweeter whenever I use my EQ ,
    of the upgrades you did would replacing the tweeters with the upgraded model you used maybe fix this issue ?
    I am using your completed pics as the wallpaper on my phone..........
  30. #90
    Join Date
    Dec 2010
    Location
    Central NC
    Posts
    2,526
    Default
    Do you blow the tweeter fuses in any other situation?
    I would have to guess that the settings on your equalizer may be causing this. Also, what kind of amp/power are you pushing them with? If you're cranking 'em up and your amp is unable to deliver clean power that would be a cause as well.
    I'm pushing mine with a Carver TFM 42 (375 wpc) and they just sing I've never blown a fuse.
    "Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills, polyswitches removed, Lg Solen inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips installed on back wall behind MW's & Tweeters, interior of cabinets sealed, AI-1 interface with 1000VA A-L transformer
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. New Forum Member requests guidance
    By piper in forum The Clubhouse
    Last Post: 12-31-2009, 01:49 PM
  2. These belong to a forum member?
    By NeilGabriel in forum Vintage Speakers
    Last Post: 04-26-2007, 04:17 PM
  3. Looking for forum member in Dallas
    By joeparaski in forum The Clubhouse
    Last Post: 07-26-2006, 01:06 PM
  4. Looking for forum member in San Diego
    Last Post: 06-02-2006, 01:07 PM
  5. Forum Member Ages
    By audiobliss in forum The Clubhouse
    Last Post: 08-05-2004, 06:47 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
