Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 15 of 15
  1. #1
    Member Sales Rating: (0)
    Join Date
    Feb 2010
    Location
    KY
    Posts
    52
    Default AVR to TV Picture
    Just recently my tv has started to display a "soap opera" type picture. It is doing it on both HD as well as regular cable. It does this when i run the hdmi from the dvr straight to the tv but usually not after i run it into the avr. Blurays seem to also be doing this slightly as well.
    Recently switched to an elite sc-37 and hasn't been a problem till just recently. My other setup is listed below. Has anyone else had any situations like this??
    "C-A-T-S CATS CATS CATS"
    Receiver- Pioneer Elite SC-37
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio Monitor 40
    Back Surrounds - Polk Audio Monitor 40 Series II
    Sub- Polk Audio PSW505
    T.V.- 55" Samsung 240 Hz LED UN55B8000
    Blu-Ray- 120 GB Slimline PS3
  2. #2
    Member Sales Rating: (24)
    Join Date
    Sep 2009
    Location
    all I see is cows and cheese...
    Posts
    4,206
    Default
    what do you mean by "soap opera" picture?
    is it grainy? is it muted in color? what do you mean? have you tried different settings on the TV? Have you tried different settings on the AVR? Have you tired a different input or outputs on the AVR as well as the TV? have you had any other changes in the set up? Have you made sure all the cables are all the way into the connectors etc.
    2 Channel-
    Soundlab M3PX
    BAT VK-31
    Wyred SX1000 monos
    Esoteric DV50
    Dynavector p75 modded phono stage
    Rega P25 modded-Denon 103R Cart
    Squeezebox Touch
    Modded Music Hall DAC Burson op amps
    Richard Grey 600S
    MIT Shotgun IC's and SC
  3. #3
    Join Date
    May 2010
    Location
    San Mateo, CA
    Posts
    1,583
    Default
    Polknewby - do you have the TV's motion function on? ie. the 120Hz/240Hz business? On my LG it's called 'TrueMotion' - it'll be called something similar on your Samsung. Go to your TV's picture menu and check if it is off. If it's not, then turn it off and let us know if that fixes it.
    The motion comp feature tends weird people out who aren't used to it.
    Of course, if it was this it would happen whether or not you're running the video through the AVR first ... but who knows..maybe your receiver's video setting are canceling it out somewhat.
    ALL BOXED UP for a while until I save up for a new place :(
    Home Theater:
    KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
    2 Channel:
    Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs
  4. #4
    Join Date
    Apr 2008
    Posts
    42
    Default
    I got the "everything looks like a soap opera" complaint and when I asked my guests to elaborate they stated "Everything just looks so real like they are really there". I offered to scratch up a piece of plexi-glass and stick it in front of the TV but no one bit. (I have pretty much the same tv)
    You might want to make sure that you are not in store display mode. Another option is to try calibrating your colors. I have been debating having a pro calibrator come in since I got my tv but the discs seem like a smarter cheaper option.
    I would like to hear more about this "soap opera effect", try and put the difference that you are seeing into words if you can. My one thought is that you are seeing a smaller range of color that may be corrected in calibration or picture mode adjustment.
    Also remember that some modes on these tvs will change the back light based on the amount of light in the room, so If you recently started leaving the blinds closed that might cause the picture to dim a little bit.
    HT:
    TV: Samsung UN55C8000 | Player: OPPO BDP-95 | Games: Xbox360 / PS3 | Party Music: Squeezebox Duet
    Mains: LSi15 | Center: LSiC | Surrounds: LSiFX | Sub: SVS 20-39pci
    Pre-Amp: Outlaw 990 | Power-Amp: Outlaw 7700
    Cabinet: Salamander Synergy Twin 30 | Speaker Wire: Lowes 12AG w/ monoprice banana plugs
  5. #5
    Member Sales Rating: (3)
    Join Date
    Jun 2009
    Posts
    2,187
    Default
    Idiot me, I thought by the "soap opera comment" , you were referring to it looking like it was shot on tape ,not film.
  6. #6
    Member Sales Rating: (1)
    Join Date
    Nov 2010
    Location
    Minneapolis, MN
    Posts
    1,083
    Default
    I don't know of a good way to explain the soap opera look - but I've seen it with my own eyes. My parents have an LCD, that the only thing I can guess is that the sharpness is up way too much? I won't go as far to say that it looks "too real". I've got my set calibrated (Panny 50VT) so it's got a damn good picture. My parents just looks.... odd. Not sure how to describe it. Almost as if everything is in technicolor? It looks "real", just not "natural". Kind of like the difference between a TV show, and a handheld cam (even the "handheld" on a show when they show a home movie on a sitcom)
    50" Panasonic Vierra TC-P50VT20 (w/5 pairs glasses)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  7. #7
    Member Sales Rating: (6)
    Join Date
    Sep 2003
    Location
    Arizona
    Posts
    16,493
    Default
    I've seen tv's on disply at BestBuy that had the soap opera effect. It's strange.
    Transport: Oppo BDP-103/USB HDD (flac)
    DAC/Preamp: Benchmark DAC/PRE
    Power Amp: Parasound HCA-1500A
    Speakers: Harbeth Compact 7ES-3 Monitor
    Cables: Kimber Hero/8TC; DH Labs D-75
  8. #8
    Join Date
    Feb 2010
    Location
    KY
    Posts
    52
    Default
    Sorry it's taken some time to respond- but for me just doesn't have the natural effect it has had. Feels like I'm sitting in the corner of the set as they tape it. What odd though is it just started the past week or so. I've had the tv for a year or so and hasn't been an issue up to this point when I run through hdmi.
    I'm going to try and unplug the hdmi cords tonight and see if that doesn't 'reset' the connections.
    Zaigrith- do you recommend one calibration disc over another for our model? And I wasn't aware the amount of light in the room changed the amount of light- I know my uncles lg has an 'eye' that does this but was unaware that this model did it.
    Glowrdr- have you ever had any issues with the sc-37 upconversion? For exame running the 1080/24 setting on hd cable? Seems when I do it has a somewhat choppy motion and if I put it on auto or pure it will cause sports tickers at the bottoms of the screen to become distorted sometimes. I have my tv auto motion on smooth for fast moving scenes.
    Thanks for all the help!
  9. #9
    Join Date
    Jan 2008
    Posts
    267
    Default
    It's called Motion interpolation
    It can be turned off on your display but might cause motion blur.
    Each Manufacture calls it something different for their displays.
    Hitachi - Reel120
    Insignia - DCM Plus, for Digital Clear Motion 120 Hz
    Kogan Technologies - MotionMax 100Hz, 200Hz
    LG - TruMotion 120 Hz, 240 Hz
    Mitsubishi - Smooth 120 Hz
    Panasonic - Intelligent Frame Creation
    Philips - HD Digital Natural Motion
    Samsung - Auto Motion Plus 120 Hz, 240 Hz
    Sharp - Fine Motion Enhanced[6], AquoMotion 240Hz
    Sony - MotionFlow 100 Hz, 100 Hz PRO (XBR series, Australia), 120 Hz, 200 Hz, 240 Hz, 400 Hz.[8][9]
    Toshiba - ClearScan 120 Hz, 240 Hz
    Vizio - MEMC (Motion Estimation, Motion Compensation)
    Sceptre - MEMC (Motion Estimation/Motion Compensation)
  10. #10
    Join Date
    Feb 2011
    Posts
    21
    Default
    Every time I see new TVs on display at Costco, etc I notice this - the pictures look really nice, but the motion nearly makes me sick. Really weird.
  11. #11
    Join Date
    Sep 2003
    Location
    Arizona
    Posts
    16,493
    Default
    I much prefer running my video sources direct to the HDTV via HDMI.
  12. #12
    Join Date
    Jan 2008
    Posts
    267
    Default
    Quote Originally Posted by steveinaz View Post
    You will still get "Soap Opera" effect either way..
  13. #13
    Join Date
    Sep 2003
    Location
    Arizona
    Posts
    16,493
    Default
    Nah, I got plasma...
  14. #14
    Join Date
    Jan 2008
    Posts
    267
    Default
    Oh lol.. I just assumed you had an lcd..
  15. #15
    Join Date
    Nov 2010
    Location
    Minneapolis, MN
    Posts
    1,083
    Default
    Quote Originally Posted by polknewby View Post
    I actually can't really say that I've noticed anything like that. I guess I haven't played around with the settings while connected to my HD sat box though. Everything I changed, I did while using the Spears and Munsil cal. disc so that would have been true 1080/24 for the testing.
    Plus, not sure I'd run into the distortion issues as mentioned by Steveinaz - we've both got plasma's. I'm sure there are some features that I'm missing though, I just may not have found them yet. I'm one of those people that spent $1200 on a DSLR and use it on auto 80% of the time. lol
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Post a picture... any picture
    By MrNightly in forum The Clubhouse
    Last Post: Yesterday, 10:05 PM
  2. i need a picture
    By emiq in forum Car Audio & Electronics
    Last Post: 02-01-2010, 04:33 AM
  3. Best...picture...ever!
    By Jstas in forum The Clubhouse
    Last Post: 12-02-2009, 09:48 AM
  4. end picture
    By amulford in forum Forum Testing Area
    Last Post: 11-21-2004, 08:00 PM
  5. This is a picture of ....
    By hoosier21 in forum The Clubhouse
    Last Post: 06-23-2004, 02:07 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
