Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online StoreGallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i
A good link about using USB DACs:
http://www.benchmarkmedia.com/wiki/i..._-_Setup_Guide
-izafar
HT/Gaming
RTi6 Mains
CSi30 Center
Fxi 3 Surrounds
PSW 505 Sub
ONKYO TX-SR605
Sony PlayStation 3 BR Player/Gaming
Nintendo Wii Gaming
Samsung HP-T4254 Plasma
Headphone Gear
Ultrasone Pro 900 Headphones
Little Dot 1+ Headamp
Musical Fidelity Vdac 2 with PS3 Power Supply
Squeezebox Touch
Well we're coming up on 48 hours of burn in. I listened to it immediately upon hooking it up, and again now, a couple days later.
Wow, what a difference a couple days makes!
It was good right out of the box, but exhibited exactly what I expected with no burn-in - harsh on the high end. It may have been a little loose on the bottom end, but I couldn't tell you because the highs were overbearing. I wasn't shocked though, know that's how it often goes especially with DACs. SO I put the playlist on repeat and decided not to touch it again for a couple days.
I came back about an hour ago and decided to put the headphones on and was pleasantly surprised. The highs are ironed out and the overall tone is typical Musical Fidelity, just on the warm side of neutral. I'm not gonna go into a big story with a bunch of audio superlatives, let's just say is sounds good.
I'm running a pair of Beyer Dynamic DT880 on it. They're a great set of cans but are just a tad forward for my liking. Like I said, the V-DAC is typical MF, so it helps tame that brightness just a bit. The Woo Audio 3 tube headphone amp that I've got on order should go the rest of the way in getting them right where I want them.
I am going to get the V-Link to pair with this DAC to get me support for Hi Rez audio. I wish it had asynchronous USB support and support for 24/96 on the USB port built in, but for the price I guess I can't complain.
I did hook this up to my Squeezebox Touch via optical and played through some of my 24/96 files and it sounds phenomenal. I may end up ordering another one for the living room but want to get my computer rig fully built out first. The fact that it sounds so good playing the hi rez files gives me confidence in ordering the V-Link, because it should sound just as good on the computer rig with that in the chain.
In fairness, I did not compare directly to other DACs in this price range, but it's hard to imagine anything better out there for the price. I've read about the HRT Music Streamer and am going to order one of those for the laptop rig. It gets good reviews online and looks good on paper from what I can tell, so we'll see. I started with the V-DAC because it also has the extra inputs that I need.
Main HT
Magnepan 1.6QR fronts, PSB Image B4 surrounds, Pioneer SC-25, Parasound Halo A23, Oppo BDP-83 SE, Airport Express w/ Peachtree DAC, Sony KDL-55HX850, Sony PS3, Apple TV
Bedroom System
Polk Blackstone TL3, Polk PSWi225 Wireless Sub, HK 3490 Integrated, Oppo BDP-83, Sharp Aquos 32" TV, Apple TV
Office Rig
27" iMac w/Amarra, Peachtree DAC-IT, Focal XS Book, Schiit Valhalla > Sennheiser HD600, Schiit Lyr > HiFiMan HE0500, LG 47LM7600, Sony PS3, XBOX 360, Apple TV
I have a V-Link, so the following was learned with that piece of equipment...
Find a way to get the V-Link it's own non-usb power. It makes an AMAZING difference. I am using a USB cord that runs a separate line to a dedicated 5 volt battery source and the difference between the music before and after the change is quite breathtaking...
HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
Outlaw 970 Preamp, Outlaw 7700 Amp, Velodyne SMS-1, Oppo BDP-83,
2 APC H-15s and a Panamax 5400 for good measure ;)
Stereo: DIY Alix Music Server, DODD Audio Battery Tube Buffer, Modded DAC-60 and MF V-Link (for now), DIY Silver ICs, Battery Powered Class D SDS-254 Amp, and GR-Research N2X Speakers
The V-Dac is better than the HRT Streamer.
What's the name of the cord you're using? Sounds cool.
I'm guessing that the difference is due to galvanic isolation. Did you hear a difference with both the coaxial and toslink outputs? I ask because the nature of the optical out keeps your other equipment galvanically isolated from the computer, so I would assume that using an external power supply would only affect the sound of the coaxial out, but you never know. Theory and practice don't always align.
edit:
I found a review of the vlink that said that someone from Musical Fidelity recommended using the toslink out for the above reason.
2-Channel:
Source 1: PC/foobar2000/ASIO
Source 2: Rega Apollo CDP
USB to SPDIF Converter: Stello U3
DAC: Audio GD NFB-7
Preamp: Audio Research LS-15
Power Amp: BAT VK-500
Speakers: Magnepan 3.7's
HT:
Sources: HTPC, FiOS, Oppo 103
Pre/Pro: Marantz av8003
Amp: Rotel RMB-1095
Speakers: LSiM-703's, 702's, 704c
Subs: Dual SVS PC12-NSD's
TV: Panny 55" VT50
I'm glad you're liking the vdac. I have heard that it sounds very similar to the m1, which I think does a great job!
You should hear a big difference with the addition of the vlink. It's an awesome little piece. I like having the converter and DAC separate so you can upgrade either separately. It also allows you to use any non-usb DAC that you want.
I'll let you know this week if I'll be getting rid of my vlink. If I do, you've got dibs.![]()
2-Channel:
DAC: Audio GD NFB-7
HT:
Amp: Rotel RMB-1095
TV: Panny 55" VT50
2.1: Musical Fidelity V-DACII>Yaqin MC-10L w/SED =C= EL34, Voskhod 6N1P-EV>polkaudio RT25i, PSW202
5.1: ATI HD5850 HDMI Bitstreaming>Denon AVR-1910>polkaudio RT7, CS350-LS, RT3, PSW505, Sony Bravia KDL-52W3000
Great information!
I have been looking at a HRT MS II, but I might go this route for my small system in my bedroom.
Don
Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
My opinion differs from dorokusai regarding the HRT MS II. I don't think it sounds compressed or artificial at all. I've also seen several other direct comparisons online between the two that are favorable toward both, and none that seem to point to obvious issues with either. I have not directly compared the HRT MS II and V-DAC side-by-side, however.
I've got a friend who has the HRT Music Streamer II and he agreed to bring it over last night, albeit reluctantly knowing what may happen.
We were both in agreement that the V-Dac is significantly better than the MSII, even without the V-Link in the chain. Since I don't have the V-Link yet I can't really compare on hi rez material via the USB.
Mark is pretty spot on with his thoughts on the sound, although I imagine other equipment would sound different. I had seen the sound characterized "too digital" and now understand those comments. it didn't sound real at all to me. Keep in mind though that as I mentioned before my headphones are already a little forward, it may sound completely different on a more laid back system.
Main HT
Bedroom System
Office Rig
Did you guys by any chance have speakers hooked up for the demo as well?
Curious as the HRT was on my "short" list of possible DAC's along with the Musiland Monitor 02, Audnst HUD-MX1 and Yulong U100. All would be between my computer and HK3490 (and later on pre-amp)
We had them hooked up to my Swan active monitors, but did most of the listening on my headphone rig. The Swan are good speakers, but don't have nearly the resolution that my headphone rig has. With those cans you can hear every nuance and detail in the sound, some of that gets lost on anything but the best speakers out there.
Like I said, this DAC is typical Musical Fidelity sound, just a bit warm of neutral, so take that into account.
I did listen to the V-Dac on my main system out of my Squeezebox and it sounded excellent, but did not use the HRT on that system as it's USB only.
Main HT
Bedroom System
Office Rig
I got the V-Link in today. My initial impression is about what it was with the V-Dac, it definitely needs some time to burn in. I'll post my thoughts after it settles into the rig.
After some more time with the V-Dac and assuming that once the V-Link has the same sound signature when it settles in I can say this is probably the last DAC setup I'll ever need. It may not be the last one I buy, but I just can't imagine it getting much better than this at a price I'll be able to afford. I'd need to greatly improve my headphone and amp setup before a better DAC would help, and that's at least a couple grand and not on my to-do list anytime soon.
Main HT
Bedroom System
Office Rig
Glad you're enjoying the v-link; it's a great little piece of gear.
BTW, are you running your media player in one of the bit-perfect, hardware direct modes? ie: ASIO or kernal streaming?
I know that a MAC OS does less damage to the signal than Windows does, but I think it would still be beneficial.
2-Channel:
DAC: Audio GD NFB-7
HT:
Amp: Rotel RMB-1095
TV: Panny 55" VT50
I also wanted to post a note that I thought would be relevant here for anyone on a Mac using iTunes. If you're on a Mac product using iTunes exclusively to handle your music playback then you're missing out on sound quality. If you're using iTunes for playback then I recommend you purchase a program called BitPerfect from the app store, it's easily the best $5 you'll ever spend.
Apparently iTunes doesn't change the bitrate when you select tracks with different bitrates for playback, or when you create a playlist of tracks with multiple bitrates. I didn't believe this at first, but tested and it is indeed true. So if you have a regular CD track and then a Hi Rez 24/96 track iTunes will play the CD track at its native 14/44 resolution and then downsample the hi rez track to that same resolution. Or if you play the hi rez track first and then the CD track it will use it's crappy engine to upconvert the CD track. Either way its not good.
The only way around this is to close iTunes, open up the Audio Midi tool and change the bitrate then open iTunes back up, its a huge PITA...until now.
There are and have been programs like Amara and Pure Music that tie into your music library and will play it back at the correct bitrate, automatically changing the bitrate to match the track and will even upsample if you want. The problem with these, especially Amara, is that they're very expensive.
There are other programs like AudioNirvana that will change the bitrate accordingly and sound great, but don't have any library interface to speak of and aren't as convenient. I've been using AudioNirvana for the last week and it does sound great.
Then there's BitPerfect. It's still not quite as featured as something as Amara or Pure Music, but if at the end of the day all you're after is the best sound fidelity possible I think it's just as good, and it's hundreds of dollars cheaper.
BitPerfect runs in the background and integrates with your iTunes library. So you use your library and start up songs or playlists just like you would normally, except that BitPerfect intercepts the signal and handles the actual audio playback, but handles things like automatic sample rate switching for you. The sample rate switching alone is worth the $5 several times over, but there are other features like upsampling and 'hog mode' (where it doesn't allow other system sounds to use the audio device it's using). It also has a couple other things that I haven't played with yet like 'integer mode'.
Anyway, that's my input, can't go wrong for $5.
Main HT
Bedroom System
Office Rig
So is the Vlink better than the VDac?
The V-Link is just a USB to SPDIF converter; there is no DAC in it.
The V-Link is used for computer rigs in conjunction with the V-DAC to increase performance since the V-DAC does not have an asynchronous USB input.
edit: the V-Link could also be used with any other external DAC since it has normal coaxial and optical outputs, so if you already have a good non-USB DAC, and you want to try a computer as your source, you can just pick up the inexpensive V-Link and continue using your existing DAC.
2-Channel:
DAC: Audio GD NFB-7
HT:
Amp: Rotel RMB-1095
TV: Panny 55" VT50
The vLink runs 169 shipped from Amazon:
http://www.amazon.com/Musical-Fideli.../dp/B004PH03GU
Another option is the Musiland Monitor 02. It runs 125 shipped (from China):
http://cgi.ebay.com/USB-Digital-Soun...item3cadfa1b56
A third option is the Audio GD Digital Interface. The "B" version retails for 140, but with the optional external power supply (75) and upgraded clock (23) and shipping from China (40ish) and paypal fees, it comes in at about 290, but you could get the standard version shipped for more like 180.
http://www.audio-gd.com/Pro/dac/USBface/Digital1EN.htm
I currently use a V-Link. My dad uses a Musiland Monitor 02. I have an Audio GD Digital Interface on the way. I'll do a write up of all three when I can A/B/C'em in a week or two.
I was so impressed with the Audio GD NFB-7 DAC that I bought off zingo that I had to try their USB-SPDIF converter. I went with the optional external power supply and upgraded clock cuz I'm trying to get my computer to be as good of a source as possible.
I'm not sure if it will sound better or worse than the V-Link...but I will find out one way or the other! Super solid build quality, sound quality, and customer service from Audio GD. Their email replies have been in broken English, but the slowest reply I've had so far was 4 hours; that's the best response time from any company I can remember dealing with.
There's a thread on a DAC comparison I was in the middle of that I will update soon now that I have the NFB-7.
2-Channel:
DAC: Audio GD NFB-7
HT:
Amp: Rotel RMB-1095
TV: Panny 55" VT50
One thing to note about the V-Link is that it does NOT require special drivers. This may be the same with the others as well, but I just plugged the MF in and it worked without loading anything.
Main HT
Bedroom System
Office Rig
I saw mention of the Audio-gd stuff. I noticed that Pacific valve dropped almost the entire line. I don't know that I would ever order one straight from China.
I'm using a Headamp Pico. It's a pretty good usb only dac that's line
powered. I've been thinking about an Arcam, but really would like the Rega
DAC if I could swing the extra coin.
I ordered mine straight from Audio GD in China. King-wa, the owner, has a great reputation for customer service and honoring warranties etc. He frequents a few audio forums like head-fi. This is my first time dealing with the company, and I haven't actually received the piece yet, but so far the customer service has been great!
2-Channel:
DAC: Audio GD NFB-7
HT:
Amp: Rotel RMB-1095
TV: Panny 55" VT50
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
Pass Aleph 30; Adcom GFP750/Dared SL2000A; Adcom GDA600; MIT S3/Z Pc; SDA 1C; Squeezebox; Tubes add soul!
2-Channel:
DAC: Audio GD NFB-7
HT:
Amp: Rotel RMB-1095
TV: Panny 55" VT50
There are currently 1 users browsing this thread. (0 members and 1 guests)
