Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online StoreLast edited by DarqueKnight; 01-28-2012 at 06:08 PM.
"Polk SDA-SRSs are hopelessly out of date both sonically and technologically... I see no value whatsoever in older SDA speakers."~Audio Asylum Member
__________________
"Knowledge, without understanding, is a path to failure."~DK
Round it is..
Is the 1.875 center to center on the holes? Also will .250 holes be ok or do you need them to be a different size?
Colors? I probably can come close to matching any color you would like.
I made a small prying bar from a 8-1/2" piece of coathanger wire. I flattened the prying end a little bit (reduced thickness about half) to make it easier to get under the rim hole.
I still use the pry bar with my Armacelled drivers. Of course, the Armacell does not cause as tight a fit as the Mortite, but the Amacelled drivers don't always fall right out after unscrewing.
__________________
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
Pass Aleph 30; Adcom GFP750/Dared SL2000A; Adcom GDA600; MIT S3/Z Pc; SDA 1C; Squeezebox; Tubes add soul!
__________________
Consider it done!!![]()
Thanks. Send me a PM with cost and shipping.
__________________
One of my braces had come loose and i had to pull a driver to get to it. I struggled with the driver and ended up having to use a screw driver to pry on it which nicked the wood slightly and I am not too trilled about it. I ended up using a screw that was able to grip the screw hole on the basket and use that to pry. I am not sure what damage this has caused and I have had a really frustrating day cause of it.
When I installed the mortite I pushed it onto the basket and then screwed it onto the wood. When I pulled it off half of it was on the basket and the rest on the wood. I even had used poly urethane on the wood before I installed the mortite to prevent it sticking.
I am using Larrys rings as well and maybe that is what is causing the sticking.
Yes, the Armacell is only sticky on one side, but some of my drivers have a snug fit which requires some extra effort to remove them. I made the small end of the prying bar 3/8 inch long.
One clarification: I call this a "pry bar", but I don't use a prying action where the flat end is inserted in a driver's rim hole and the bar is pressed downward to pry the rim up. The flat end is inserted in the rim hole 1/8" to 1/4" and the tool is pulled outward.
I cut 1/2 inch strips. The Armacell is 2 inches wide, so this allowed four 1/2 inch strips per section:
__________________
Old thread, great info.
There are currently 1 users browsing this thread. (0 members and 1 guests)
