Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 31 to 60 of 64
  1. #31
    Member Sales Rating: (0)
    Join Date
    Jul 2010
    Location
    Texas
    Posts
    372
    Default
    Using the crossover that came with the speakers is good, no worries there. Using the first two channels for them is where you need to be. As for channels three and four that would be the one for the subs, and you could bridge it as well on those channels, and if you have the bass boost knob that is also from what I can tell for the sub channels three and four.
    So, on channel 1 & 2 you put the crossover on full range and then adjust the freq according to what the speakers can manage. Look at the manual for the Dxi's to get a better idea on that. Putting the crossover on full range is fine because, the crossover that came with the Dxi's will divert the signal accordingly. Do not turn on the bass boost on these channels... It will make them sound more bassy, and muddy. Use the HU bass, trebel, and mid for that stuff.
    Channels 3 & 4 is for the sub. I think you can bridge that to get more power, but I could be wrong. I sure I am right, but a little hazy on that.
    Arun please help with this. Thanks.
    At any rate if bridging the last two channels is good. Then plug in the bass boost control to the hole, then set your croosover to lass pass, and then adjust the freq. Now with this, anything that is higher then lets say... 40Hz should not pass through. In fact I would leave that at 40Hz, and call it even. Do not use the bass boost switch on this either. That is what the knob is for. This should be by the driver side of the car.
    The volume issue is not at all bad. Basically what they do (Best Buy) is turn up your volume on the HU to roughly 80% max volume. They then adjust the gain, and they try to get this match what the HU is pushing out. They adjust it to where they hear audiable distrotion, then turn it down a bit. It keeps you from blowing your speakers. NOW THE GAIN KNOB ON THE AMP IS NOT VOLUME CONTROL. It is only used to match the signal that comes from the HU.
    The over all idea is blend the sub with the front speakers so that they sound as one. I have a feeling that I may be off on some of things by a little bit. I have had an EXTREMELY wonderful weekend, and I am still thinking of this girl from the club so, yyyeeeaahhh my mind is kind of all over. LOL.
    2006 Prerunner Access Cab
    5 Speed 4 cycl 2wd
    Audio:
    Pioneer P860 Head Unit
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
    Kinetik HC2000 battery and Sleeve
    200 Amp Mean Green High Output Alternator
    Need a DJ, photobooth, or both for rent?
    http://photoboothdallas.org
  2. #32
    Join Date
    Oct 2011
    Posts
    33
    Default
    LOL i know how that is haha. Well one of the problems with the crossover for the sub is, its a component sub so it doesnt come with one i dont think. Im just throwing it into a box and putting it on my amp. I dont see anything on my amp thats a dial or anything. All I see are places to connect things like the channels and speaker inputs. I do have the bass controller that came with the amp, but I dont see any settings about crossovers or anything on the amp, just inputs.
    By the way, does the RC cable have neg/pos ends or is it different than normal wire? Name:  Kicker RC.jpg
    I hooked in the Kicker RC Cable to the Rear/Sub inputs but I did not know which end went to which. The kicker has blue/green ends and the inputs have a red slot and white slot. I just put the blue in the red and the green in the white. Does it matter or does it just matter when you go back to the amp to make sure the blue is hooking into where you want on the amp etc.
    As far as briding a SVC sub goes to 2 channels of an amp. I want to run the 2 channels at 4 OHMs and just give it the two channels power. I see people writing about how they lower it to 2 ohms but my subwoofer does not support that. Is it easy to bridge it?
  3. #33
    Join Date
    Oct 2011
    Posts
    33
    Default
    actually, scratch that I do see now the crossover part of it. it was hidden in the back. looks like it has a crossover for channels 3/4 and for channels 1/2. Ill leave 1/2 at full range and change 3/4 to what you said. Im still a little sketchy about the bridging thing. Does a subwoofer have to support bridging, for it to be able to do it? or can any subwoofer do it. I also looked at my amps manual and it showed how to bridge but It showed all channels bridged. 1/2 were to 1 subwoofer and 3/4 were to 1 subwoofer. Can I have channel 1/2 to my front speakers reguarly wired and then 3/4 bridged to my subwoofer? Looks like my amp manual is telling me to connect the positive of channel 3 and the negative of channel 4 to the subwoofer. Will it damage the subwoofeR?
  4. #34
    Join Date
    Jul 2010
    Location
    Texas
    Posts
    372
    Default
    Yeah it was a great weekend. The stipper was so fine, and well built....Sigh... it was beautiful. In fact her name was beauty, and now I know why..... Uh.. back on topic sorry.....
    As far as cables having a designated positive, and negative, there is no such thing. Any cable you put into positive is postive, and any cable you put into negative is negative... So, it is up to which one you want to be what. As for the bridging this, you are right. Wire one cable to the positive of channel 3, and one wire to the negative of channel 4. If you look at the link you posted on your amp. There is a picture showing the channels that the speaker cables connect to. There you will see that they show what is bridged by this l-___________+l or vise versa, and is says bridge in the middle of the line. Will your sub be able to handle it, the short answer is yes. Now what you are talking about wiring the sub down to a 2 or 1 ohm load. That has do with how you wire the actual subwoofer. There is series, and parallal, but for just hooking up one sub you dont need to do this. Just hook up positive from sub to positive on channel 3, then negative from sub to negative on channel 4. Dont' worry you will be fine, and the sub will, and can take it. The whole wiring thing only really comes into play if you are dealing with 2 or more subwoofers that are either SVC, and DVC, Or have one sub that is a DVC (Dual voice Coil). Try not to over think it too much, it only makes it more confussing. With the wiring stuff, go online and look at series, and parallal wiring.
    Thanks.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  5. #35
    Join Date
    Oct 2011
    Posts
    33
    Default
    Thanks man, I appreciate it.
    My subwoofer comes tomorrow and hopefully I can finish it up and enjoy the fresh new sound. The only last tiny problem is the box in my trunk. The subwoofer box fits and everything but you said I should definitely screw it down. I can do that, but the problem is, theres only the carpet underneat the box. Under the carpet is just empty space because thats where my spare tire is kept. Think it will be enough just screwed to the carpet?
  6. #36
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    Quote Originally Posted by KaosTsoc View Post
    Right, so someone got lucky last weekend? and he's still swooning on Thursday...hmm
  7. #37
    Join Date
    Oct 2011
    Posts
    33
    Default
    Also, For the bridging. Does the bridging reduce the ohms of the amp? or affect its output? Reason I ask is because im wondering if bridging channels 3/4 will affect the unbridged channels 1/2 or something.
  8. #38
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    With a component and sub you would have two cross over points. One for your sub and midbass, which you would set either at your hu or your amp and the other for the mb and tweeter which is basically the passive that comes with the components. You don't need an external xover for your sub. What HU are you running?
    The amp will run at the impedence of the speaker connected to it. So if you run an SVC sub the amp will see a 4ohm load and if you run a DVC where you have connected the two coils on the sub to 2ohms, the amp will run at 2 ohms. Most amps will put out more power at lower loads. Thats why people run DVC subs. Your amp is two ohm stable. If you run a SVC bridged, your sub will get 160 watts, while with a DVC it will get 400 watts.
  9. #39
    Join Date
    Oct 2011
    Posts
    33
    Default
    the HU I am using is a Sony CDX-GT340
    http://aboutgadgets.net/2010/02/sony-cdxgt340-review/
  10. #40
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    OK your hu does not let you set the sub/mid xover, so you will have to do this at your amp. If you're running the sub off channels 3&4 select LPF for these channels and set the knob ~ 50hz.
  11. #41
    Join Date
    Jul 2010
    Location
    Texas
    Posts
    372
    Default
    Arun...Yeah great weekend. Can't wait to do it again, or see her again.... Oh yeah..... Thanks for your input as well. Always a pleasure.
    Dan,
    Where are going to put the box at? Which way is the sub going to be firing?
    Thanks.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  12. #42
    Join Date
    Oct 2011
    Posts
    33
    Default
    The box will be pointing/fireing into the trunk towards the seats and be placed behind my amplifier like this. Is that ok?
  13. #43
    Join Date
    Oct 2011
    Posts
    33
    Default
    Also another stupid question. How do you connect this type of connection? It has a screw on top or something but Im not sure exactly how to connect the wire here. its the outside of the box for the subwooferName:  sub connex.jpg
  14. #44
    Join Date
    Oct 2011
    Posts
    33
    Default
    AWW MAN how dumb. The subwoofer I bought didnt come with leads to get from the subwoofer to the subwoofer enclosure input. Well, I did a crappy solder job with extra speaker wire to those odd little metal pieces that you always see on the connectors of speakers, the plastic shielded wire part goes over it or w/e. Anyways, I hope its ok, I just put some of the wire through the hole of the metal part and folded it over and then solderedName:  solder pic.jpg
    I know you cant see much but thats the wires soldered onto the + and - terminals on the sub. Is this ok to do? I guess Ill find out if it blows up or not
  15. #45
    Join Date
    Jul 2010
    Location
    Texas
    Posts
    372
    Default
    The way your soldered the wire are just fine. I have did mine that way as well. So, you are good. Now just make sure you know which one is positive, and which one is negative. Now hook up those wires to the terminal inside the box. When that is done, just make sure to take note which one is positive, and which one is negative. Now that the inside is done, it is now to the out side where ther gold terminals are. Basically they should unscrew, and there should be a hole in th middle of the post, I think... I can not really tell by your picture, but if that is correct. Put one wire into the postivie, and one in the negative, then hook up the according cables to the positive, and negative terminals of the amp, and done.
    As for securing the box to the carboard floor mat, that should be fine, but it would be better if it was connected to some sort of metal surface in the trunk. If this is not possible, then the floor should be fine.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  16. #46
    Join Date
    Oct 2011
    Posts
    33
    Default
    Well, I ended up making the sub as far back in the trunk as possible, and aimed it opposite of the cabin. I read in a couple articles that that is recommended. Anyways, its all connected and set up and it sounds good. Im almost positive that there are tons of tweaking things that should be done but I just dont know how to do. I like the sound of it all but sometimes its weird because like, I feel like I get a great sound out of my polk speakers, but its the higher frequencies and then for the real low frequencies I get the sub, but it feels like the mid/lower mid part of the music is sometimes lacking. The only options I get on my HU are Sub, Low, Mid, and High control. I usually leave everything at 0 so its equal, but I have been putting the "low" option up a little bit because I feel like it controls the woofers of the front speakers. I just feel like theres a big frequency difference between the lowest part of my components and my sub and I feel like its missing a chunk of frequencies, but hey maybe its just me. Maybe even my subwoofer is just up to high. Do you recommend just keeping all of the Equalizer settings at 0 so they are even?
  17. #47
    Join Date
    Jul 2010
    Location
    Texas
    Posts
    372
    Default
    Good to hear all is working.. As for the sound, and frequency loss, with the HU you have it will limit what you can, or can't tune. That is where an external equalizer with at least 7 bands comes into play. You could leave everything at 0 if it sounds good to you. The key part of that is YOU..... Sound is going to be subjective for each person. What sounds amazing to me, may sound muddy or unlcear to you..... So, with what you have, try to play with it until you get the sound that you are looking for. As time goes on, you will might end up trying to get an equalizer that will allow you to inhance the high, mid, and low frequencies. Time alignment, and independent left/right channel equalization will all help with this. However since you are just starting out, play with what you have, and get the basics down first. Again it is YOUR ears, and YOUR system, and YOUR car. So, it has to sound good to you. Dig around the fourm, and look at tuning frequencies that have been suggested over time. Alot of will not make sense at first, but once you do some research, and apply it. It will all come together. If it makes you feel any better, I am still learning the frequency stuff as well. It is a constant battle, and constant learning.
    Thanks.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  18. #48
    Join Date
    Oct 2011
    Posts
    33
    Default
    Thanks man, I couldnt have done it without all of every ones help =D!
    I started thinking about the frequency loss thing and I wondered if it is because the speakers are 5.25'' speakers. Because I remember on my old 6x9s they pumped out a lot of good mid/low frequency because they were full range, and big. These woofers even though they are higher quality, arent as big =/. The subwoofer is great but I wonder if maybe I put the low pass too low? I think its around 50 right now but I wonder if my small polk woofers can even get that low.
    The subwoofer does sound really great, for SOME songs. For other songs where it is a fast beat. I hear it get muddy because it is not a clean hit for the beat. Its a hit and then it vibrates for a second so instead of hearing a fast beat you just hear the continous subwoofer. I think you can kinda guess how it sounds, but for other songs its great. Any idea how to fix that?
    also http://www.sonicelectronix.com/pictu...ture_id=244153 In that picture where it says "min/max" dial next to the bass boost, is that the bass boost dial, or the gain dial? I have not touched either of them and I wonder if I should have...
    The subwoofer I have is a 12'' polk audio one, and this is the box I got http://www.ebay.com/itm/230686505069...84.m1497.l2649 . Do you think maybe that box is just not good with my subwoofer? Is there any way to make it a more clean strike than muddy?
    And also last but not least, my radio on my head unit hasnt worked ever since I took it out and put the other 2 RCA inputs in and disconnected the battery and all that. I heard you have to push reset on the system somewhere before you put it back. Unfortunately I learned that after the fact when it was all put back together, So I figured id leave well enough alone but now the Radio doesnt work anymore. Any suggestions?
  19. #49
    Join Date
    Jul 2010
    Location
    Texas
    Posts
    372
    Default
    Ok. Well let's start with the radio. This may sound dumb in all or condescending, but it is not ment that way. If you look at the picture you posted in post 23. There is a hole just to the left of the rca's. Do you have your antenna hooked into that hole? As for the sound in the 5.25, they should handle the 50hz range from what I understand (mac, or arun please chime in here), however you might what to set that a little higher like in the 60hz range. As for the min/max dial you are talking about, that is your gain. The actual switch that is to the left of that is your bass boost. Now, if you going to mess with the gain, you will need to turn it all the way down to min. Turn up your radio to 80% of max volume, so if your hu max is 40 then 30 or so should be 80% I think. Kind of fuzzy on the math.... anyways. With the HU at 80% turn the gain on channels 1/2 toward the max side bit by bit. Since your amp is in the trunk, you will end up turning the gain a little, go to the door speakers, and listen. If you hear audiable distortion (you will know what it is when you hear it, it will should waffled, or about to blow), you will go back to the amp, and turn the gain down just a bit, and your set there. As for the sub, you will do the samething. Once you have this done you will have your amp set to the approximate voltage that your HU is putting out. As for the bass boost I would not mess with it too much, you will end up putting to much of a boomy sound out. Try this, and see what happens, but just be careful when adjusting the gain. You can end up blowing your speakers, and worse yet blowing the amp. Which in both cases you do not want to do, because that would put back to square one. Just remember the gain knob is NOT VOLUME control. If Arun, mac, dskip, or anyone will chime in about the frequency that would help too. Hope this helps.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  20. #50
    Join Date
    Oct 2011
    Posts
    33
    Default
    Thanks. I actually just found out that my subwoofer box is a lot bigger than its supposed to be. My sub is meant for a .88 cu ft box and my box is 1.36 cu ft. I will take it out and try putting in a few 2x4s in some places to make it smaller.
  21. #51
    Join Date
    Nov 2010
    Location
    MD
    Posts
    41
    Default
    Quote Originally Posted by dan553 View Post
    That may be a bit big, however depending on what your looking for, larger than manufactures specs can yield a better sound. Ex: Polk recommends 1.2cu ft for the SR line sealed, but for SQ, a lot run 1.5-1.7cu ft.
  22. #52
    Join Date
    Mar 2009
    Location
    Columbus, OH
    Posts
    147
    Default
    We're talking about the Dxi speakers right? I had the db's and they really did not do too well with a HPF of 50Hz. For one, it made it seem like there was a gap in the response, and two it muddied up the midrange detail.
    I'd suggest keeping it at 60 or 63Hz.
    With regards to setting the gain, the old 80% rule is not the best. My headunit the Excelon X595 goes all the way up without clipping. It outputs 4V at volume 35 and like 2.5V at 34. If I set my HU for 80% I would be sending the amps less 1V potentially requiring the gains on the amps to be turned up.
    For the speakers turn the gain all the way down. Now turn up the volume on your headunit until it distorts. Note this number and take it back one or two notches and set your amp gain then. It might not distort at all, My last HU pioneer 6000UB went up to 60/62 without clipping.
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  23. #53
    Join Date
    Oct 2004
    Location
    North Texas
    Posts
    5,565
    Default
    dan, can you list your gear by make and model numbers? There's too much going on above and I don't care enough to read it all. Don't worry too much about the box size right now, it should be fine until you get to know your system better.
  24. #54
    Join Date
    Oct 2011
    Posts
    33
    Default
    my gear is
    Front speakers - Polk Audio DXI 5 1/4'' component
    Sub - Polk Audio DXI 124 12'' subwoofer SVC
    Amp - Soundstorm SSL f4 800
    HU - Aftermarket Sony head unit.
  25. #55
    Join Date
    Oct 2004
    Location
    North Texas
    Posts
    5,565
    Default
    I wouldn't trust those DXi's to go down to 50 with any kind of authority. You might get decent sound out of them at 63 as mentioned above, but you may have to go higher than that. My SR5250's are generally set at 50, but sometimes make it up to 63 depending on the music. Perhaps a shallow slope (say -12) on the fronts at 80 and a steeper slope on the subs at 63 (-24) would mesh well.
    I've never used a Sony HU and never had a desire to, so I can't comment on that. I doubt the 85x4 wpc advertised for the amp are accurate and would consider it to be much, much lower (at least half). That doesn't mean you can't get good sound out of it though. I have an MTX 564 that is about twice that size and only does about 50x4 of nice, clean power. It is an older amp, but I don't think technology has advanced that much over the years to get the same quality power out of a similar power source half its size. It also reads that you should NOT bridge your sub over two channels if it is a 4 ohm speaker. That Soundstorm can't handle a bridged 2 ohm load.
    As for the 80% rule when setting gains, it still stands in my books. To be honest, if you tune heavily, you will probably find that the 80% moves up to 90% or higher when all settings are finalized.
  26. #56
    Join Date
    Oct 2011
    Posts
    33
    Default
    Alright pals, next questions on my journey (haha when you get tired of them just tell me to stop)
    I returned my polk 5 1/4''s to purchase a component setup that is 6 1/2'' and will give me the lower end I am looking for. I am looking at the boston acoustic sr 60 set. They seem pretty thick and like they can deliver some decent bass.
    My questions are, when I took out my component system today, there was a lot of moisture on the magnet. Where the front of my speaker is, it is lined with dynamat, but the back has a LOT of moisture. Not exactly 1-2'' of water sitting but enough for where you slide your finger down it, it gets very wet. So the question is, is this normal, and if it is, can non-marine speakers (such as Bostons), survive in that type of environment?
    2nd question. I noticed that (and I am PRETTY sure I started hearing this when I lined my drivers side door with dynamat), when my head unit is turned on, I hear a higher pitched noise that just stays constant. When I push in the throttle, it seems to get higher pitched, like eventually my car might take off or something. When the music is louder you cant hear it, but if you are listening to music on a lower setting you definitely notice it. Any ideas on what it might be? My theory was that maybe when I forgot to setup the antenna in my hu correctly after reassembling it, its the radio trying to pick up bad pitches or something but this happens even when the tuner radio is not on. Any ideas?
  27. #57
    Join Date
    Oct 2004
    Location
    North Texas
    Posts
    5,565
    Default
    You've got alternator whine. Check your amp's power lines under the hood. If anything is exposed, get some electric tape and make sure its covered.
  28. #58
    Join Date
    Oct 2011
    Posts
    33
    Default
    Alright ill check that out. thanks a lot man
  29. #59
    Join Date
    Oct 2011
    Posts
    33
    Default
    well, none of the wire seems to be exposed. Its relatively new, heavy shielded wire too. I wonder if maybe because it is just laying on a metal piece connected to the alternator that it is transferring? Maybe I'll try just shifting the placement around a bit and see if it goes away. Unfortunately I cant put it all back together until I get my new 6 1/2''s in. Im so excited! :D Every one kept telling me that the polk audio mm6501s were the way to go, and I wanted to get them so bad. They were my first choice to begin with. My accord's fits 6 1/2''s in the front but unfortunately the mounting depth available is only 2'', while these take I think 2 7/16. I have a small bracket that best buy put on a long time ago to raise them out a bit, but I think it is just not enough because crutchfields calculator, as well as their customer service said it wouldnt go in. So ima try out the boston acoustics sr60 and see how they go.
  30. #60
    Join Date
    Oct 2004
    Location
    North Texas
    Posts
    5,565
    Default
    Look up alternator whine and you should be able to find a few other issues that might cause it. IIRC, where you ground your amp might also be a cause.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. World Currency War Question
    By avelanchefan in forum The Clubhouse
    Last Post: 09-07-2011, 10:47 AM
  2. Question about Polk Audio 10A speakers
    By bobsvinyl in forum Vintage Speakers
    Last Post: 03-16-2006, 08:05 PM
  3. biggest subwoofer of the world for an A/V room
    By dlew308 in forum The Clubhouse
    Last Post: 04-08-2004, 08:50 AM
  4. Best Speakers in the world.
    By VR3 in forum The Clubhouse
    Last Post: 04-29-2003, 02:40 PM
  5. Replies: 5
    Last Post: 03-25-2003, 06:19 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
