Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 31 to 36 of 36
  1. #31
    Member Sales Rating: (0)
    Join Date
    Dec 2006
    Posts
    131
    Default
    Well, I don't know how much processing power I have with my HU (CD7200mkII), but I suppose I will be asking questions once the tweeters are installed and I'm trying to equalize it. They should arrive tomorrow, I'm just hoping the install won't be a PITA.
  2. #32
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    I think the Eclipse 7200 is at par with the Alpine 9887. It lets you go active, gives you time alignment for each driver and a 7-band eq. However I dont think it gives you seperate L/R. In real terms, what you get with the 7200 is enough to dial in great sound.
  3. #33
    Join Date
    Dec 2006
    Posts
    131
    Default
    Running 3 way it's an 11-band eq. The problem is knowing which frequencies to adjust, and by how much. I even have the microphone, but the Eclipse website is quite frankly sub-par, so I do all my adjustments in the HU.
  4. #34
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    Cut everything except for the sub frequencies and maybe 500.
    http://www.reverse-engineering.info/...wl_eq_info.pdf
    http://www.independentrecording.net/...in_display.htm
    Some stuff you can look at.
  5. #35
    Join Date
    Mar 2009
    Location
    Columbus, OH
    Posts
    147
    Default
    So you are using the 11 band parametric then? This will be a little more difficult to use as you have to pick the frequency to cut as well as how wide the cut is. Let me make very rough suggestion as far as frequencies to adjust.
    (2) 80Hz -1/2db, (3) 125Hz -2/4db, (4) 200Hz -2/4 db, (5) 315 Hz -2/4db, (6) 630 Hz -2/4db, (7) 1 kHz -2/4db, (8) 2.5kHz -2/4db, (9) 4kHz -2/4 db, (10) 6.3kHz -2/4db, (11) 12 kHz -2db
    As far as Q goes, the higher the narrower the cut. Others can give you more specifics on Q factors to use. I would use Q of 3 on low end bands (3) -(5) and maybe (6). I think a wider Q like 1.5 or 2 would be good for the rest.
    Arun feel free to chime in here
    This is just a starting point, play around the bands i've suggested and the amount of cutting. The levels i've suggested are just a starting point, I may be way off in some cases because I haven't heard your car. Alternatives could include 800Hz and 1.25kHz for bands 6 and 7.
    I would suggest 24db/octave crossovers on everything.
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  6. #36
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    Q 1 = 1 1/3 octaves
    Q 1.5 = 1 octave
    Q 3 = ~ 1/3 octave
    So if you cut 100hz on a q of 2 you would be cutting like 80-160hz. The frequencies at the outer end of this range would be cut less than the central / selected frequency. Just like a bell curve. Based on the settings available from your manual, try this.
    Low : This is basically for your sub, you get 1 band here. Don't do anything leave this flat.
    Mids : You get 5 bands from 63-16khz. Use the 5 bands from 63 to about your xover point.
    1. Select 100hz cut by 3 db on a Q of 1
    2. Select 200hz cut by 4db on a Q of 1
    3. Select 800hz and cut by 4-5db on a Q of 2
    4. Select 1.25khz and cut 4-5db on a Q of 1
    5. Select 2.5khz and cut 3-4db's on a Q of 1.5
    Highs : You get another 5 bands which you can use for your tweets.
    1. Select 4 khz and cut by 2 db on a Q of 1.5-2
    2. Select 6.3khz and cut by 4-5db on a Q of 2-2.5
    3 Select 8khz and cut ~4 db on a Q of 2.5-3
    4&5. Cut 10 and 16 by ~ 2-3 db on a Q of 2.5
    Most important, hear how it sounds. Chances are somethings will be right some wont. Go back to the sheet I attached and see whats wrong and therefore what you need to correct.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Really upset...and a little flustered.
    By PerfectCreature in forum Car Audio & Electronics
    Last Post: 08-02-2010, 03:08 PM
  2. Need Help More upset than setup: need help
    By blurayhooray in forum Basic Hookup/Wiring Questions
    Last Post: 03-24-2009, 01:25 AM
  3. Anyone else upset due...
    By Grimster74 in forum Music & Movies
    Last Post: 04-15-2008, 03:54 PM
  4. This guys a bit upset
    By Ron-P in forum The Clubhouse
    Last Post: 04-23-2007, 02:34 AM
  5. Really upset with LSiC!!
    By haveldl in forum Troubleshooting
    Last Post: 02-28-2005, 04:19 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
