Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 90 of 173
  1. #61
    Member Sales Rating: (0)
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    Happy New Year guys, hope you'll have a great year ahead.
    The TA on the bit10 is a bit strange as you 'set distance' in inches / cm and then fine tune in ms. The beauty about phase is that its relative and not absolute. So exact measurements are not really important. You can either enter measured distance to the sub or even leave it at 0.
    Play some bass heavy tracks and cut all drivers except the sub and the far mid. Start with the far mid at 0 and add delay to it till you hear and feel the sub from the far mid. You want it at a point where you hear the sub from the far mid without losing the clarity in the midbass/mid range. Our ears cannot locate (front/back or left/right) sound below about 70hz. By getting your sub and far mid in phase your brain and ears are cueing the 70hz and below at the same point as 70hz and over i.e. the far mid. Once you have this dialed in cut your sub and play only the mids and now add delay to the near mid till you get the stage focused upfront. Then play only the far mid and tweet and dial in the tweet and then the near mid and tweet. While doing the mids and tweets you're trying to lift the sound higher than the level of the midbass. Now play all drivers together and you will need to do some minor tweaking.
    Mac is spot on, you will wind up with your near mid on a delay between 3.5-3.7ms relative to your sub. The delay between the two mids (assuming door mounted) will be ~ 1-1.2ms. If the tweets are mounted higher than the mids i.e. dash level or pillars, the delay between the tweets would be slightly more than that between the mids. Conversely, the tweets are lower than the mids the delay between the tweets would be slightly less than that between the mids. This is because the PLD between drivers reduces the lower they are mounted.
    Frequencies that are phase sensitive, tend to be those played by the mids. Hence getting the mids and the sub/mids in phase is vital. However it is equally important to keep the mids and tweets in phase as well. Doing this is actually tougher than just dialing in the sub and mids.
    There are two types of phase. Mechanical phase and acoustic phase. Mechanical phase is when the drivers are firing in an exact sequence based purely on distance of each driver from your ears. Mechanical phase is aimed at exact arrival time. Here measured distances are critical. If you were listening to music in a far field environment, free from early reflections with speakers at different distances, then yes you would want to get them in mechanical phase. But a car is a near field environment with tons of early and late reflections. These reflections are causing phase shifts along with summations and cancellations at different frequencies. Hence mechanical phase is of limited use here. The sequence that Mac is describing ie sub followed by mids together and then tweets together etc is acoustic phase.
  2. #62
    Join Date
    Mar 2009
    Location
    Columbus, OH
    Posts
    147
    Default
    I've tried having my near mids delayed by between 3.25 and 4ms, and far mids 2 to 2.92ms. In all cases it sounds better when I invert the phase of the sub. I had been hesitant to add even more delay, I'll go and try adding even more and see how it sounds.
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  3. #63
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    Where is the sub placed and which way is it facing? How is the eq set for the 20-80hz range?
    Can you describe 'sounds better' a bit?
  4. #64
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    Check the polarity of connection from your amp to the sub. If the polarity is reversed (+ from amp connected to - at sub), then reversing the phase will actually bring the sub back in phase. I'm just trying to eliminate all possible options.
  5. #65
    Join Date
    Mar 2009
    Location
    Columbus, OH
    Posts
    147
    Default
    Polarity is good, positive going to positive and vice versa. There is no phase switch on the amp. Sub is in the back corner on driver side, side firing towards the opposite side of the car. Also the rear seat is always down on the passenger side to make sub more efficient and cool my 4 channel amp. I've tried different positions before and this position was the best. I don't like the sound of the sub against the seat and firing back - it sounds empty, and in the corner and firing rear is too boomy. Subsonic is turned all the way down to 5 Hz.
    If I don't reverse the phase, kick drum sounds weak. Upper bass sounds good but there is no low end impact. Kick drum sounds up front but low end is just missing. Inverted phase on bit ten, there is much more low end energy and it is up front. Here it sounds like the sub and mids are cooperating in the crossover region smoothly. Without phase reversal it sounds like the sub is not doing as nearly as much.
    Can some amps cause the signal to undergo a phase shift compared to the full range amps?
    EQ is flat up until 60Hz (-1.5db), 80Hz (-7.5db), 100Hz (-9db).
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  6. #66
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    Its possible that your issue is not phase related, but one of integration between your sub and mid bass. You have the spl meter right?
    Measure the 20-160hz range using the pink noise and the spl meter.
    1. Sub only
    2. Both mids only
    3. Sub and mid playing together.
    Dial in your TA before you do this. Let's see what comes up.
  7. #67
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Dont be skurred to add more delay. I have my driver side tweeters delayed by 6.5 ms. It aint gonna hurt anything. If it doesnt sound good, you can switch it back.
  8. #68
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    Wow I've never gone out that far. What's the delay on the near side midbass and mid range?
  9. #69
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Mids are about the same IIRC cause theyre right next to the tweeters. The mids are the furthest forward driver in my system. Theyre in A pillars while the tweeters are in the sail panels about 4" behind the mids so I was able to keep their delay about the same value.
  10. #70
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    One of the continuing challenges for me, is overcoming mindsets and stepping out of the comfort zone. On these settings I have pulled up the 80-200 hz a bit but the biggest change is in the 2-5khz at the near mid and tweet. This range is now pulled up ~1.5-2.5 db on the near side mid and cut by about 2-2.5db on the near tweet. This range is now dominant from the mid. The way I had it setup earlier, I think the tweets carried a lot more. The touch of hollowness on vocals is gone and the upper mids are much more fluid. Not tight and a bit harsh like earlier.
    Attached Thumbnails Attached Thumbnails Click image for larger version
ID:	64504   Click image for larger version
ID:	64505   Click image for larger version
Name:	Far tweet.png‎
ID:	64506   Click image for larger version
Name:	Near Tweet.png‎
  11. #71
    Join Date
    Mar 2009
    Location
    Columbus, OH
    Posts
    147
    Default
    I haven't had the time to go through and do the measurements with my SPL meter. I did go through quickly and play with delay and phase. So I tried increasing the delay even up to 6ms. Through the entire range from 3.5ms to 6ms it sounds better when the phase is inverted. The 3.8 to 4 ms range sounds optimal to me right now, adding more delay sounds like there is less bass.
    I am thinking that even though the wires from the box to the amp are in phase, I might have hooked up the actual sub inside in reverse order in the box (+ side of voice coils going to - terminal on the box). When I had the ported db sub in I had played with reversing the phase but it made it sound worse, like there was less bass and it moved it to the rear (in the same 3.5ms to 4ms region). Now with my new sub it is the opposite, revering phase makes the kick drum sound much deeper and realistic sounding, and it just sounds like there is more bass. Basically it sounds like the sub and mids are cooperating with sub reversed while in phase it is mostly the mids.
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  12. #72
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Well if thats what it takes to make it work best, then thats the answer. At the end of the day, its your ears that matter and if thats what sounds best then thats the way it should be. If you get more bass output with the phase switched then that is the correct phase. If you lose bass energy then youre getting cancellation and that means the phasing is incorrect.
  13. #73
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default myth or fact
    Most people who are serious tweakers will eventually realize, that there is a huge subjective side to sound, beyond the numbers. Once you accept that, it opens up a whole Pandora's box in terms of what is legit and what is purely your ears and mind playing tricks on you. This is a partial list of some of my observations. I wonder how many are true and how many are myths.
    1. The same setting will sound different with and without a passenger upfront. With a passenger up front you will lose a bit of the lower end.
    2. Engine, road and wind noise will obviously lead to cancellations and hence change in sound. Even the airflow from your a/c or heater will interfere with the sound dispersion and you will hear that difference.
    3. On cold winter days / nights you will feel a loss of the lower end, till the cabin heats up.
    4. Sound in a car is mostly about trade offs. In most cases you will get something at the cost of something else.
    5. Some days are just better hearing days than others.
    6. Knowing when to stop and save the settings is critical.
    7. Once you get to a decent level, its easy to develop mindsets and tweak within a narrow band. That will limit your progress.
    6 was always a weakness, 7 is something I'm discovering recently. I had made a list of 16 points for this post, but I think I'll start with these. Would rather be ripped on 4 of 6 than 12 of 16
  14. #74
    Join Date
    Mar 2009
    Location
    Columbus, OH
    Posts
    147
    Default
    Totally agree with the winter day thing. I first noticed it like 7 years ago ,even with stock systems and no sub it sounds like there is less low end. The question is is there really less bass because some components need to warm up or is our perception of bass reduced when we are colder or the air is colder that the sound is travelling through?
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  15. #75
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Quote Originally Posted by arun1963 View Post
    Itll depend on where the speakers are located. If theyre in the kick panels or in the doors, then a passenger will block their line of fire and youll generally mainly get a center image shift to the left. Dont think Ive ever noticed less low end. Dont think that would make a difference. If anything it would increase it as there isnt as much empty space in the car with a passenger in there.
    Wont interfere necessarily, just drown it out. The AC wont matter much at all unless youve got it blasting on high. Road noise will easily mask all the intricate details that you were up all last night trying to tune in.
    Hmmm, not sure about this one. I would think this might just be from youre freezing your ass off and cant feel as good as in warmer temps.
    Nah. You can get as much as you want but itll depend on how far youre willing to go with the installation. Tuning will only get you so far. A car with stock speaker locations just doesnt have the same potential as a car with a much more custom installation as in mids in the kicks in sealed enclosures.
    Aint that the truth. Some days I think everything sounds like a dying cat then the next day its not so bad.
    Its all a work in progress. You stop tonight because your ears are fried and save your preset then start again the next day or two after youve had some time to live with it and pick things out you like and dislike.
    Again, this will depend on your install. You can reach the maximum potential of your install after a while. If youre not making any more progress and arent satisfied with the sound then its time to look into moving the speakers around and getting some better pathlenghts going on.
  16. #76
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    ***Tube light response***
    Thanks bro. Picking up on point #7, I wrote that cause I felt that I was kind of stuck in a rut. Nice sound but not really improving at the pace I wanted. Over the last week or so, I've gone and redone practically everything. However, I still landed up more or less where I had started from in terms of sound quality. I was also sure that I had not hit the limits of my placement or tuning skills. Something had to give.
    So I went back to your 08 finals tuning sheet that you posted in one of my threads. I know, different setup, environment, placement etc etc. But there had to be something there and there was. I looked at the printout of your sheet with that of the equal loudness curves. I still had to account for the natural peaks in the car, but boy it feels like being catapulted into a different level. I need to go back and do the L/R again, for sharper imaging. But I think I'm just going to soak this in for a few days .
  17. #77
    Join Date
    Mar 2009
    Location
    Columbus, OH
    Posts
    147
    Default
    Arun or Mac, my far tweeters are measuring about 2db-3db hotter in the 4-10kHz region. Do you normally get this in your car or in vehicles you have measured?
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  18. #78
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    It will depend on a lot of factors like where the tweets are mounted, the axis relative to your ears, how close they are to reflective surfaces like the windscreen, pillars, dash etc. If you have the tweets mounted lower, then they will have a lesser PLD difference between them and the far tweet which is more on axis will be hotter in this range. 10-12khz is typically the beaming range for most 1" tweets and for sure the more on axis tweet will be hotter here.
    In my case since the tweets are on the dash the PLD between them is much higher. Hence the near tweet is much hotter in the 2-5khz range and the far tweet is hotter in the 10-12khz range. Go with what your ears tell you. Most spl meters aren't very accurate in the 5khz+ range. Play the tweets only and try to get the image centred where you want it. Be carefull with the 2-4khz range from the tweets as this can add smearing, kinda like a snowy / diffused effect to the sound.
  19. #79
    Join Date
    Mar 2009
    Location
    Columbus, OH
    Posts
    147
    Default
    Check out the Audison Facebook wall. Two new products including the Bit Play HD and Bit Tune.
    I think the Bit Tune looks interesting as this is Audison's first autotuning product. It looks like something dealers/installers will buy, but thats just me speculating. The mic apparatus looks fancy and they are marketing it as being better with a response closer to human hearing. It looks like you will be able to select multiple target curves as opposed to imprint and others that just give you a flat response. Anyway it would be cool to run it and try a few different curves and compare with manual tuning. It just generates a setup file that you would input into the Bit processor. You would then be free to tweak as you wish.
    Bit Play looks like a new type of media center deal that can interface with anything type of drive you want. This media center runs every type of file including FLAC and OGG. You could encode all of your cd's as FLAC and keep it all in your car.
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  20. #80
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default Equal Loudness curves vs Macs competition sheet
    http://hyperphysics.phy-astr.gsu.edu...nd/eqloud.html
    These are the Fletcher Munson equal loudness curves. They represent the human ears sensitivity to frequencies across the ten octaves. The chart shows that the human ear is most sensitive to frequencies in the 2-4khz range and least sensitive to the lower frequencies. While the relative sensitivity will change with the decible volume you're listening at, the basic pattern remains the same.
    Once you move beyond the 2-4khz range the ears sensitivity again starts to decrease. If this is an accurate representation of our hearing pattern, then it stands to reason that while eq, you would want the sub frequencies to be the loudest with a gradual roll off in intensity to about 200hz. You would want 400hz to about 1khz to be flatish but lower by about 2-3dbs from the 60-200 range.
    Going further, 2-4khz would be the range that you cut the most and you would set this ~ 3-4db lower than the 500-1khz range. You would start raising the level again around 5khz - 10/12khz. Opening 10-12khz range would also give you the airy sound and shimmer on your highs. Beyond about 8-10khz there would be a natural roll of in the car and your hearing in anycase. Once you have dialed things in take a FR response playing all drivers, and you should end up with a curve similar to the FM curves.
    Point to note : The above does not take into account the peaks and imbalance that you would have at different frequencies which you would need to correct independent of these graphs. But yes, these graphs are a good trendline. Attached below is Mac's tuning sheet from '08 Finals. It pretty much follows the same pattern. For his install in the Honda, if he did a FR response curve I'm willing to bet that the curve would be close to the FM curves. Ofcourse we can't copy his settings cause they are for a different vehicle, placement, equipment, xover points etc etc. But I think the trend stands out.
    Thanks Bro, I don't know how many times I've gone back to that sheet and eveytime I've learned something new.
  21. #81
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    I'm not good with the science side of sound. Most of the technical stuff around this hobby goes over my head. These charts are an exception. Or maybe I'm just looking at them differently now. For instance, they explain why you lose your lower end when you turn the volume down. The difference between the most and least sensitive frequencies rises as turn the volume down.
    It also explains why your ears would be more sensitive to any discrepancy in the sound, in your sensitive zone. Any sharp peaks or dips, L/R imbalance, phase issues to an extent, reflections and comb filtering etc. As also why you wouldn't bother about the difference between 0.1 and 1% THD in your lower end. It also explains why home and car audio are so different. Cause none of this would matter in your typical 2ch set up with you in the sweet spot.
    But with this hobby, it always comes down to doing it by ear. With shaping the curve, you're covering for the way you hear and the effect of your environment, but you're still going to dial in the tonality by ear. The curve is just getting you in the ballpark. Mac shared his sheet about three years ago and I first saw the FM charts about a year back. I guess that proves if you stick with the hobby the sound will get better. No matter how much you suck at it.
  22. #82
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Quote Originally Posted by pentoncm View Post
    Yes because the far side tweeter is more on axis with your ears and the higher the frequencies go, the more directional they become and their volume increases the more on axis you are to them and likewise the volume will drop more the more off axis you are. So it is natural that most of the upper frequencies from the most in axis driver will be louder.
    I'd almost forgot about that tuning sheet. Those things were very handy and a nice backup in case you accidentally hit the wrong button and lost all your settings the night before finals!
  23. #83
    Join Date
    Mar 2009
    Location
    Columbus, OH
    Posts
    147
    Default
    Mac, thanks for posting your tuning sheet. It was helpful to see how your L/R differed on your mids. My near side sounds just a tad weak on the midbass and I'm trying to find where the problem is. Before I had cut everything from 160 to 400Hz by about 4.5 to 5db. I have to find the right balance but it sounds better to me bringing up 160Hz and 250Hz up to the -3db,-3.5db area. I need to play around with 250, 315, and 400 more though.
    I feel that I am making progress.
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  24. #84
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Got a couple questions about that Bit Ten.
    Are you guys running optical outputs to it or thru RCA's?
    If its RCA's, how it doing for noise? I know my Alpine H700 when getting the head unit's analog output has some decent hiss if you turn the volume up pretty high.
    Im thinking about getting one of these things for my system but will be using an analog output and dont want to do it if Im going to be losing 1 point every time for hiss. MECA judges are turning into noise nazis these days.
  25. #85
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    I had mine wired thru line level to start with and the tweets would randomly go into hiss mode. Just like you mentioned. I'm now running it with RCA's and it's good so far. The bit10D which takes digitial in is supposedly clean on this front.
    The bit10 though will not let you do a 3way. I think with the 10D you can technically run a three way, but two of the three drivers on one side would share an eq between them. It's perfect for a 2way plus sub though. You will love eq in 0.2-3db steps
  26. #86
    Join Date
    Mar 2009
    Location
    Columbus, OH
    Posts
    147
    Default
    I only hear hiss when there is hiss in the recording like many rock tracks at the end of the song. On better quality material it is dead quiet. The noise should be lower with a headunit that has a higher output voltage. My Kenwood sends out a 4V, so the gain on the Bit Ten input is really low, around the 1 marker out of 5 (not voltage scale, it relates to amount of gain).
    If you have a way to send a digital signal to the Bit Ten D it would be even better. If you want to invest in the new Audison Voce amps then the Bit Ten D can output 8 channels digitally all the way to the amps.
    The Bit Ten D comes with the DRC remote while the Bit Ten doesn't. It costs the same to get the Ten D as it does to get the Ten + DRC.
    Does it make sense that the processor should be more quiet if you use the DRC? If you don't use the remote, then you turn the Bit Ten output all the way up and then use your HU volume as the main volume control. This works but if you don't turn the HU all the way up then the processor receives a lower input signal (instead of 4V you could be sending 1 or 2V easy). This could lead to more potential noise in the system during average listening. I have the DRC so my HU is always turned up to max so the Bit Ten is always getting the maximum signal which should reduce noise.
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  27. #87
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Hmmm. No 3 way huh? That sucks.
    The new MECA CD is going to have a zero bit track on it so theyll play it (dead silence) and turn the volume up to something like 30/36 on my Alpine and if they hear hiss, thats -1 point. Ridiculous really but thems the rules.
    I had a CD player (9861) that has an optical output but its crapping out on me. Wont auto feed the CD, takes like 30 seconds to read the CD once you get it in there and its making funny noises. The first Alpine head unit Ive had a problem with in 20 years of buying Alpine.
    So I really dont want to have to spend $600+ on a CD player with an optical output and thats assuming they even still make one! I dont think Alpine does and Im not sure who does other than those big $1000 double DIN touch screen DVD players. If I could get a processor that would work with an analog output but not have that damn hiss, that would be cool. Its bad enough Id have to slap $800 on my credit card for a Bit Ten, $400 for a laptop (but my wife really wants one so that can be more justified) and then have to buy a new CD player on top of that when my Alpine 9855 is still working great and looks cool too.
  28. #88
    Join Date
    Mar 2009
    Location
    Columbus, OH
    Posts
    147
    Default
    $800 for Bit Ten? No way. Bit One is $1000 up to 24db/octa and has 8 channel output. Bit Ten $400, Bit Ten D $600. DRC is $200 if you want to add it to Bit Ten. So you want to set up a three way plus sub? I would just go with the Bit One, see if you could find it on sale or something. Bit Ten has slopesve. Bit One goes up to 48db/octave. The Bit processors are supposed to be the cleanest on the market.
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  29. #89
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,828
    Default
    Oh OK. The Bit One was the one I was thinking about. The Bit Ten might still be am option tho. I need to look into that. I've got time alingment and crossover on my 9855 so maybe I could use that for my midbass or something. $400 is a lot more reasonable to maybe I can figure something out.
  30. #90
    Join Date
    Mar 2009
    Location
    Columbus, OH
    Posts
    147
    Default
    Check this out http://www.mobileelectronics.com.au/...rom_arc_audio/
    Looks like Arc Audio is joining in the processor fight
    31 band parametric, and what the heck is a Bessel Crossover? Also you can change the Q of the crossovers? Audison better watch out
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Tuning amp
    By bradw011 in forum Car Audio & Electronics
    Last Post: 08-29-2011, 12:44 AM
  2. Thanks for the tuning help
    By pentoncm in forum Car Audio & Electronics
    Last Post: 12-12-2010, 04:19 AM
  3. Tried tuning the p-99 today
    By arun1963 in forum Car Audio & Electronics
    Last Post: 11-30-2010, 08:48 PM
  4. Replies: 3
    Last Post: 06-05-2007, 12:35 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
