Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 4 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 120 of 226
  1. #91
    Member Sales Rating: (5)
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,522
    Default
    I had another idea for the 22.5 ohm resistors and the resistors I'm using to replace the polyswitch, so let me know what you guys think about this. I'll put down a small dab of hot glue at each end, then run a small "rope" across the top of the resistor to keep it in place. I doubt the glue will actually stick to the resistor though, since foam tape won't stick at all. Might be wrong, but we'll have to see.
    Are you part of the dirty digital peasants or a member of the great Analog Master Race?
    SDA Recommended Playlist https://docs.google.com/spreadsheet/...FZCRkdxYXVNanc
    Open for editing.
  2. #92
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,522
    Default
    One other question to go with that; when cleaning up/resealing the cabinets, which is better: silicone caulk or hot glue?
    Open for editing.
  3. #93
    Member Sales Rating: (0)
    Join Date
    Feb 2011
    Location
    North Central Illinois
    Posts
    1,970
    Default
    Quote Originally Posted by quadzilla View Post
    Non hardening, Non flammable silicon.
  4. #94
    Join Date
    Feb 2011
    Location
    Posts
    1,970
    Default
    Using that long of resistor I might be inclined to build a stacked board like Vmxr does and run a jumper to the corresponding holes in gimpods boards. If done properly you would be able to use the pin socket as a spacer and bend the leads to double as standoffs. That would also free up some space for the little inductors on th main board.
  5. #95
    Member Sales Rating: (49)
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,033
    Default
    I just ran a bead of hot glue around the inside of the cabinet and called it a day..
  6. #96
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,033
    Default
    Quote Originally Posted by SDA1C View Post
    Use the leads as stand offs?? WTF are you talking about
  7. #97
    Join Date
    Feb 2011
    Location
    Posts
    1,970
    Default
    Quote Originally Posted by Toolfan66 View Post
    Look at the xovers I did. I bent the leads about an 1/8 inch out from the body at 90 degrees. When you solder the lead it acts to hold the resistor off the board. For having all the answers some of you ask some pretty simple questions.
  8. #98
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,033
    Default
    stfu.. Have you ever used a Duland resistor? There will be no problem keeping them off the board also I had my mills on my boards for over a year with no problems. There is no way to mount the dulands flat to the board I tucked little pieces of sonic barrier Under the dulands to take away some of the vibrations since they stick above the board.
  9. #99
    Join Date
    Feb 2011
    Location
    Posts
    1,970
    Default
    oop sorry I was doing something more important than argue with you ...like scratching my... We clearly don't understand one another. No biggie not everyone does...
  10. #100
    Member Sales Rating: (13)
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    30,423
    Default
    Silicone has no business inside a speaker cabinet and hot glue doesn't really seal that well on wood products. Liquid Nails or maybe acrylic caulk would be better choices. Smoothing out the bead (wear latex gloves) will force the product into the seams for a tight seal.
    'Political Correctness'.........defined
    "A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
  11. #101
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,033
    Default
    Ok Mr I have upgraded a set of crossovers now I know it all guy!!!
    Take it down a notch you act like everyone is out to get you..
  12. #102
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    30,423
    Default
    They are.
  13. #103
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,033
    Default
    Quote Originally Posted by F1nut View Post
    I agree with you Jesse I just used what I had as I really don't feel thet cabinets leaked any air but since I had them apart and had two big bags of glue sticks I figured it couldn't hurt to go over the seams.
  14. #104
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    30,423
    Default
    You're right, hot glue certainly won't hurt anything. Silicone is another matter.
  15. #105
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,033
    Default
    Quote Originally Posted by f1nut View Post
    they are.
    lol!!!
  16. #106
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,522
    Default
    I am intrigued by your statements, and wish to subscribe to your newsletter. Seriously, why is silicone caulk a bad thing? I thought acrylic got hard, while the silicone would stay flexible? Did you have a bad experience with an "enhanced" exotic dancer, maybe?
    Also, I've had a lot of coffee already this morning. I mean a lot.
    edit: never mind, found this as an explanation. http://www.diyaudioandvideo.com/FAQ/Build/
    Open for editing.
  17. #107
    Join Date
    Feb 2011
    Location
    Posts
    1,970
    Default
    The whole fume thing is why I said use the nonflammable type. Generally it wont have caustic fumes if it isn't flammable. Also with a random spark it could go boom if it had the right air mixture (not likely but not worth the risk in my view).
  18. #108
    Join Date
    Feb 2011
    Location
    Posts
    1,970
    Default
    I know.... when someone doesn't drink your koolaid and honor your lifetime achievement of 2 years on an audio forum you get your balls in a bunch...I understand. I have seen the same attributes before and know it takes a lifetime of therapy to overcome such woes. I don't hold it against you Larry. I really don't. It's a sickness that has no known cure...only treatment. The way to be rid of it for the most part is to TREAT others with a little friggin respect and not assume that the only experience they have in audio (or life for that matter) is the time they have spent online having to deal with people like you.
    There's lots of "sealers in a tube" options. The liquid nails is a good one but it too has some fumes that must be abated. (The acrylic Liquid Nails that is) I used that exact one in conjunction with gorilla glue to repair the side panels of the (dare I even mention them) 1c's.
    OH yea...Making my second pot right now
  19. #109
    Join Date
    Sep 2011
    Location
    Cleveland
    Posts
    6,113
    Default
    Don't mean to butt in. But just out of curiosity i called my son who builds speaker enclosures. He uses glue or fiberglass.
  20. #110
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,522
    Default
    Girls, girls... you're both pretty. Now stop it.
    Chum, I can see a bead of wood glue. Not sure how well the fiberglass would work.
    But then, if you let the silicone cure at least 24 hours, it should be ok too. Well, more thought required. I just want something that will seal the corner and stay flexible to handle changes in humidity, the vibrations that will, obviously, be going on a lot, etc.
    Open for editing.
  21. #111
    Join Date
    Feb 2011
    Location
    Posts
    1,970
    Default
    Quote Originally Posted by chumlie View Post
    Was that what he builds them with or reseals them with? I too don't quite understand the reseal with fiberglass thing. Seems a bit difficult to me. Unless hes talking about redoing the outside, sanding it down all that. Then I get it.
  22. #112
    Member Sales Rating: (31)
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,733
    Default
    SDA1C, you don't play well with others, eh?
  23. #113
    Join Date
    Feb 2011
    Location
    Posts
    1,970
    Default
    Quote Originally Posted by Face View Post
    To be honest Face I do quite well with -most- others. But it does seem as I look back that the ones I don't do well with..I really really don't do well. lol
  24. #114
    Join Date
    Sep 2011
    Location
    Cleveland
    Posts
    6,113
    Default
    I have no idea how the fiberglass works. But if you tell me i'm the prettiest, i'll find out.
  25. #115
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,733
    Default
    It appears you like to cause friction with the most helpful members here and once you start posting in a thread it starts to go downhill. You may want to re-think your attitude.
  26. #116
    Join Date
    Feb 2011
    Location
    Posts
    1,970
    Default
    I'll see what I can do.....
  27. #117
    Join Date
    Feb 2011
    Location
    Posts
    1,970
    Default
    Quadzilla might get jealous lol
  28. #118
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,522
    Default
    Of course you're the prettiest. You're a pretty, pretty princess.
    <where's a blueberry man smiley when you need one?>
    Open for editing.
  29. #119
    Member Sales Rating: (4)
    Join Date
    Jan 2008
    Location
    Salem, Oregon (Polk county!)
    Posts
    4,102
    Default
    Good observations and advice.
    Greg
  30. #120
    Join Date
    Sep 2011
    Location
    Cleveland
    Posts
    6,113
    Default
    I'm on it Pumpkin. Soon as my son gets out of work i'll find out. Seriously though. Excellant job
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. CS10 - How close to wall is to close?
    By cuban8 in forum Basic Hookup/Wiring Questions
    Last Post: 01-22-2010, 05:57 PM
  2. the truth really hurts,our sick society today
    By tom t in forum The Clubhouse
    Last Post: 04-10-2009, 01:18 PM
  3. A little humility never hurts...
    By steveinaz in forum 2 Channel Audio
    Last Post: 10-23-2007, 08:59 PM
  4. Man...........beer Hurts
    By JimBRICK in forum The Clubhouse
    Last Post: 05-07-2007, 04:59 PM
  5. 7B's waiting to be unleashed.....it hurts
    By Jonesy in forum Vintage Speakers
    Last Post: 03-24-2007, 08:51 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
