Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 5 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 121 to 150 of 226
  1. #121
    Member Sales Rating: (13)
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,287
    Default
    Quote Originally Posted by quadzilla View Post
    Chum, I can see a bead of wood glue. Not sure how well the fiberglass would work.
    But then, if you let the silicone cure at least 24 hours, it should be ok too. Well, more thought required. I just want something that will seal the corner and stay flexible to handle changes in humidity, the vibrations that will, obviously, be going on a lot, etc.
    I'm sure he means fiberglass resin, which would be used to seal coat the interior MDF walls.
    Besides the corrosive issue of uncured silicone, it also creeps. That is, it will likely contaminate everything inside the cabinet. MDF is not subject to movement from changes in humidity, so there is no need for a flexible sealer. Take a look at the original glue/sealer Polk used and you'll see that it is pretty much rock hard.
    'Political Correctness'.........defined
    "A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
  2. #122
    Member Sales Rating: (5)
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,523
    Default
    OK, thanks very much. I'll probably just get some acrylic caulk then. That should be ok, yes?
    Are you part of the dirty digital peasants or a member of the great Analog Master Race?
    SDA Recommended Playlist https://docs.google.com/spreadsheet/...FZCRkdxYXVNanc
    Open for editing.
  3. #123
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,287
    Default
    Should be fine.
  4. #124
    Member Sales Rating: (0)
    Join Date
    Dec 2010
    Location
    Central NC
    Posts
    2,534
    Default
    Re: sealing cabinets, I'm getting ready to do that to my 2.3TL's. My approach is to use something that will seal them and increase the strength of the joinery. Stuff that outgasses VOC's = harmful effects on speakers, possibly caps, etc. Looked at all the the construction adhesive products at HD and Lowe's and they all had warnings about breathing the stuff while it's curing, as well as somewhat high levels of VOC's.
    However, I did find this stuff at Home Depot by Loctite called Power Grab Heavy Duty Exterior Construction Adhesive. Practically no VOC's (< 0.5%), and washes up with soap and water. Also, no respiratory warnings on label, which I think means it doesn't outgas stuff that'll harm sensitive electronics.
    Bought three tubes. I'll let you know how it works out.
    "Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills, polyswitches removed, Lg Solen inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips installed on back wall behind MW's & Tweeters, interior of cabinets sealed, AI-1 interface with 1000VA A-L transformer
  5. #125
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,287
    Default
    Ok, I've got to ask why do you guys feel the need to "seal" your speakers? The way the cabinets are made and glued up, I can't see air leakage at the seams as being a problem. Just because you might see areas that don't have glue oozing out does not indicate an air leak. Do the push test, if it passes then life is good and you just saved yourself time and money.
  6. #126
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,523
    Default
    OK, that's a fair question. Some of the seams have no hot glue, no anything. It's just the two panels meeting in a corner. Every other polk speaker I've seen, even the ported ones, have all the seams sealed with hot glue, so I assume these should have had something in the corners.
    That, and I've also seen a lot of people report favorable results from cleaning up and resealing the insides of the cabinets.
    Open for editing.
  7. #127
    Join Date
    Sep 2011
    Location
    Cleveland
    Posts
    6,407
    Default
    Haven't forgotten , waiting on return call from my son.
  8. #128
    Join Date
    Dec 2010
    Location
    Central NC
    Posts
    2,534
    Default
    Quote Originally Posted by F1nut View Post
    My speaks don't pass the push test - the mw's recede in < 5 seconds when I push the PR. The other thing is the bass response is not what it should be, even though placement is not optimal. So, I figure this can't hurt, and might help.
  9. #129
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,287
    Default
    I'd say 2 to 3 seconds is normal. That is as soon as you press in the PR and hold it, the MWxxxx's start to recede ever so slowly for about 2 to 3 seconds before coming to rest.
    With all the mods you've done, the bass should be quite good. As you state your placement isn't optimal, so I'd be inclined to believe that's the issue.
  10. #130
    Join Date
    Dec 2010
    Location
    Central NC
    Posts
    2,534
    Default
    They recede slowly, immediately to about the half way point and then stop until I release pressure on the PR.
    The mw's recede slowly, immediately to about the half way point and then stop until I release pressure on the PR.
    I think you're right - placement is the issue, which I can't do much about. Still, interested to see what, if any, effect sealing the cabinets has. The bass is there, it's just not as prominent as I'd like it to be so I'm using a sealed sub to enhance the bottom end. I'd like to get rid of the sub.
  11. #131
    Member Sales Rating: (4)
    Join Date
    Jan 2008
    Location
    Salem, Oregon (Polk county!)
    Posts
    4,351
    Default
    Quote Originally Posted by drumminman View Post
    I have found that the 2.3TL's (and SDA's in general) send out the bass pretty accurately to how the recording is produced. That is, if there is a lot of bass in the recording you will hear and feel it. If there is not, you won't. Have you tried any music with prominent bass? I would think yes, but wanted to make sure. One good test song would be Madonna's "Frozen" from Ray of Light. The midsong bass thumps should feel like an earthquake it.
    Greg
  12. #132
    Join Date
    Feb 2011
    Location
    North Central Illinois
    Posts
    1,982
    Default
    Quote Originally Posted by chumlie View Post
    hehe
    Madonna rules!
  13. #133
    Join Date
    Dec 2010
    Location
    Central NC
    Posts
    2,534
    Default
    Quote Originally Posted by headrott View Post
    Greg
    You're right, Greg, these are very accurate speakers which is one of their qualities I really like. Got bass, just want a little more. I have the the sub dialed in so it is outputting at a very low level, so I'm not looking for a major change.
    When I do the PR test on my RTA 12C's the MW's take much longer to return than those in my 2.3TL's, and they put out a bit more bass. Different speakers, but it got me thinking.
  14. #134
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,523
    Default
    I'll start posting pictures here shortly, but I've got one crossover done except for extending one lead on the resistors that are replacing the polyswitch and securing everything.
    Open for editing.
  15. #135
    Member Sales Rating: (16)
    Join Date
    Mar 2005
    Location
    In A Van Down By The River
    Posts
    21,240
    Default
    SDA's should have no problem with bass if set up properly and with proper gear and of course source material.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
    Pass Aleph 30; Eastern Electric Mini Max; Adcom GDA600; MIT S3/Z Pc; SDA 1C; Squeezebox; Tubes add soul!
  16. #136
    Member Sales Rating: (31)
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,791
    Default
    Quote Originally Posted by heiney9 View Post
    Depending on the room. :P
  17. #137
    Join Date
    Jan 2008
    Location
    Posts
    4,351
    Default
    Looking forward to it. Have you put them on the acrylic sheets?
    Greg
  18. #138
    Join Date
    Mar 2005
    Location
    Posts
    21,240
    Default
    Quote Originally Posted by Face View Post
    Properly set-up, if you have room issues, technically, they aren't properly set-up :p
    But I do understand not everyone has the "ideal" place to set them up to maximize every aspect of performance.
    P.s. My buddy has 7.1 HT and a Polk PSW-650 sub in his basement HT and whenever he comes over to listen to my rig he always says, "I can't believe you don't have a sub, you get better bass from those 2 speakers than I do with my sub" and he shakes his head. He's not a big audiophile so it;s sort of perplexing to him. He has his sub set up for boom boom, thump thump, which I can't stand.
  19. #139
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,523
    Default
    Here's a shot of the first completed crossover, with the exception of attaching the large inductor and the wiring harnesses. I took advice from various people, and didn't tie wrap the resistors to the board. Instead, I just used a bit of hot glue. It actually stuck to the resistors, which surprised me since the foam tape wouldn't. I also just used a couple of dabs along the length, so they do stand off the boards. I also have the acrylic board under them, but you can't really see it. It does make the whole assembly really stiff. Hopefully, it will help dampen it a bit too. Overall, placement seems to have worked out pretty well.
    Open for editing.
  20. #140
    Member Sales Rating: (49)
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,236
    Default
    How come you didn't put the wire bulkheads on the board? Or what ever they are called.
    Looking good
  21. #141
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,523
    Default
    Quote Originally Posted by Toolfan66 View Post
    Looking good
    Because I couldn't find any I liked. Neither tinned copper nor brass are worthy. So despite what a giant PITA it'll be if I ever have to pull this stuff back apart, everything will be direct soldered. I don't care if it's only one tenth of one percent difference. I still want that.
    Open for editing.
  22. #142
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,236
    Default
    After I posted I figured that's what you were after.. Are you going to solder straight to the drivers and tweets?
  23. #143
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,791
    Default
    Looking good!
  24. #144
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,287
    Default
    The traces on the boards are (tin) foil clad copper and the chassis wire is tinned copper. Just saying.
  25. #145
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,236
    Default
    Good point Jesse, I didn't even think about that.
    Is there any benefit in just doing a point to point crossover on say a piece of MDF?
  26. #146
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,287
    Default
    Larry, while there's certainly an argument for that, Tony's boards have very healthy traces. Healthy enough that I believe negates the point to point advantage.
  27. #147
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,236
    Default
    Thanks Jesse, Tonys boards are wonderful and I wouldn't do an upgrade without them, they are the best thing to hit this forum in the last year, and that's why I have a couple of extra sets in my goodie closet just in case something comes around. The set of boards I got from Ray for my 1.2tl's are very nice as well. They sure make the old boards look tiny and simplify the upgrades with more room to work with.
  28. #148
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,523
    Default
    Yeah. I'm a glutton for punishment. I have to be. I'm in technology.
    I know the traces are. I would've actually preferred a pure copper pad, but the boards are still excellent. I'm not using the stock harness either. Might make a difference, might not. Don't know, but it's the way I want to do it. And when you get right down to it, the solder I'm using is copper, lead, tin, and silver, but still, if I can get just a tiny bit more out of the speakers this way, I'm fine with it. And if I don't, then at least I threw everything I could think of at it to try to get a bit more.
    Open for editing.
  29. #149
    Join Date
    Jun 2007
    Posts
    69
    Default
    Looking good quad
    SDA SRS 2.3tls; RDO 198's, Dynamatted, Armaflexed, Gimpod Boards, Crossovers by quadzilla: Clarity ESA 630V, Mills Resistors, Track Audio Spikes, Musky's Curly Maple Caps
    CSi5, FXi5, Rythmik D15SE sub, Pro-Ject Xpression III/Ortofon MC-3 Turbo. Pro-Ject Speed Box. Pro-Ject Tube Box II
  30. #150
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,523
    Default
    Did some more work today. First pic I call "man down" The cabinets look so sad laying down like that. Any who, the other two show what I was talking about when I said the speakers don't seem to be sealed well. I can insider a very thin object quite a way into the crack you can (barely, in these pics) see. So I decided to just run a bead of hot glue around the edges. Never thought finding plain acrylic caulk would be so hard. Everything had silicone and/or VOC with warning about not even letting the stuff touch your skin, including the stuff that said "cleans up with water". So... I passed on all of it.
    Also, finished both xovers, including getting the new cable for the large inductor done. It was a bit trickier tinning the 15.5 ga. litz than the 17.5. Not sure what made it so much harder, but the first couple of tries didn't get the center conductors tinned. Finally got that worked out. And even tinned, the 15.5 will fit through the mounting hole in the board without modification, so that makes me happy. Tomorrow I'll start on the dynamat for the drivers after family time. The new harness will be the last thing I do.
    And if someone has a tip on gluing slick rubber to mdf, please, clue me in. Hot glue won't stick to what I need to mount at all. I'm thinking gorilla glue, maybe?
    Attached Thumbnails Attached Thumbnails Click image for larger version
ID:	64198   Click image for larger version
ID:	64199   Click image for larger version
    Open for editing.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. CS10 - How close to wall is to close?
    By cuban8 in forum Basic Hookup/Wiring Questions
    Last Post: 01-22-2010, 05:57 PM
  2. the truth really hurts,our sick society today
    By tom t in forum The Clubhouse
    Last Post: 04-10-2009, 01:18 PM
  3. A little humility never hurts...
    By steveinaz in forum 2 Channel Audio
    Last Post: 10-23-2007, 08:59 PM
  4. Man...........beer Hurts
    By JimBRICK in forum The Clubhouse
    Last Post: 05-07-2007, 04:59 PM
  5. 7B's waiting to be unleashed.....it hurts
    By Jonesy in forum Vintage Speakers
    Last Post: 03-24-2007, 08:51 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
