Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 8 of 8 FirstFirst ... 4 5 6 7 8
Results 211 to 226 of 226
  1. #211
    Member Sales Rating: (4)
    Join Date
    Jan 2008
    Location
    Salem, Oregon (Polk county!)
    Posts
    4,355
    Default
    Are those the Aural Thrills tube amps? Never heard them, but he makes pretty nice IC cables. I have a pair of Air silver XLR's, a pair of silver RCA IC's, and a pair of copper IC's. All are very good. Not as good as MIT Shotgun S3's, but the Aural Thrill are 1/4 the price too and are about 85% of the MIT's. Great price to sound ratio!
    Greg
  2. #212
    Member Sales Rating: (5)
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,523
    Default
    Yeah, they're Aural Thrills. They're the same ones I swapped out the sonicap coupling caps for claritycaps. I've done a couple of other mods to them too. They sound very nice. I also have one of his tube cables that uses a tube to invert the signal and charge the shield.
    Are you part of the dirty digital peasants or a member of the great Analog Master Race?
    SDA Recommended Playlist https://docs.google.com/spreadsheet/...FZCRkdxYXVNanc
    Open for editing.
  3. #213
    Member Sales Rating: (0)
    Join Date
    Oct 2004
    Location
    North Texas
    Posts
    6,148
    Default
    Went to Rob's today and spent a few hours with them. Having heard them before and after the upgrades, I must say they are fantastic and have improved vastly. The first time I heard them, I left feeling like they were nice, but I wasn't in awe of them like I felt I should've been. Tonight was great and I thoroughly enjoyed every minute of it. The midrange really stands out now, while the bass is well-defined and seems to have that perfect blend between what you hear and what you feel. The highs are extremely smooth, never becoming overly harsh or out of balance compared to the rest of the music. Overall detail is through the roof.
    All those upgrades really paid off Rob. Congrats on some spectacular speakers!
  4. #214
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,523
    Default
    And it was great having you over Skip. Great to see you again. Now we need to find some caps to fix your amps and get those in there. Then I want to come over and hear those.
    Open for editing.
  5. #215
    Join Date
    Jan 2008
    Location
    Posts
    4,355
    Default My review of the Clarity Cap ESA and Duelund resistors in the 2.3TL's.
    I have approximately 350 hours on the new Clarity Cap ESA and Duelund cast resistors mounted to one of Tony's (gimpod's) boards. I also used Larry's (Toolfan66's) idea of mounting the crossover boards on acrylic plates (I used dark blue) and unfortunately I did not take pictures of them so you can't see them but they look nice with the dark blue acrylic plates (even though you can't see them because they are inside the 2.3TL's). I previously had Sonicap/Mills on the original crossover boards as a comparison. I still only have a jumper in place of the Polyswitch. There is no resistor in it's place. Also, the associated gear I am using with the 2.3TL's is listed below:
    Amp: Aragon 8008bb with MIT Shotgun S3 balanced cables
    Pre-Amp: BAT VK-3i with 2 Bendix 5992 tubes and 4 1964 Amperex 7308 (made in USA) tubes
    DAC: My own built DAC found here and using 4 Mullard 1959 longplate 12AX7 tubes and MIT balanced Shotgun S3 cables
    Source(s): Denon DVD-5910 hooked to the DAC with my own built digital cable using VHAudio Pulsar Ag cable and WBT Nextgen Ag-152 connectors
    Teac X-2000R reel to reel deck
    Using various power cables from a VHAudio to Shunyata to my own built using NeoTech NEP-3001 wire and Wattgate 330i Ag connectors
    With regards to the sound.......well......
    If I was to sum up the Clarity Cap ESA and Duelund Cast resistor combination, I would use one word. Transparent. This was the first word that I thought of after the full burn in and I listened to the 2.3TL's. If you have excellent sounding gear (source, (DAC if used) pre-amp, amp, and cables (and of course a nicely mastered CD, SACD, tape or vinyl) you will hear excellent sound coming out of the speakers running the Clarity Cap ESA and Duelund cast combination. If you do not have excellent sounding gear and CD, SACD, tape or vinyl (or a combination of bad gear and/or source) then the sound you will hear not so nice audio coming out of your modified speakers.
    I also agree with quadzilla that the Clarity Cap ESA and Duelund Cast resistors are on the warm side of neutral. Not overly warm, but pretty darn accurate to the source(s). The next thing I would say about the audio signature is how much more detailed the Clarity Cap ESA and Duelund Cast resistors are compared to Sonicap/Mills combo. I guess this goes in hand with how transparent the combination is as well. I was hearing micro details I had either never heard or barely heard with the Sonicap/Mills combo. I was impressed at how detailed the Clarity Caps and Duelund resistors are. This detail does not come with a price of the caps and resistors sounding too analytical though. I have heard some gear with detail amount in spades, but at a price of being analytical and having no life (tone) to the sound. There is tone with the Clarity Caps and Duelund resistors, but there is also details in spades. Is the Clarity Cap and Duelunds combo as full of tones as the Sonicap/Mills combo? I don't believe so, but I would also argue that the Sonicap/Millls combo adds some artificial tones to the audio signal. The Sonicap/Mills combo has a little overdone bass and is a little boomy compared to the Clarity Cap ESA and Duelund Cast combo. Also, the high end with the Sonicap/Mills combo is not as smooth as the Clarity Cap and Duelund combo. The Calrity Caps and Duelunds are very smooth and not harsh. I will not say perfect, but IMO much better than the Sonicap/Mills. Mind you that I am not using a resistor of any kind in the polyswitch spot, and I was with the Sonicap/Mills combo. The highs are very nice, IMO. Also keep in mind you that I have tubes that may be altering the high end output to a certain extent as well, those especially being the Mullards. The midrange is exquisit with the Clarity Cap ESA/Duelund combo. Both male and female vocals and especially acoustic guitars, violas, violins, Hammond B3 organs, and drums sound very natural and real with the Clarity Cap ESA/Duelund Cast combination on the crossovers.
    I am going to have to wrap this up as my bloodsugar is getting too low, but I wanted to reiterate that if I was to summarize in one word the audio signature of the Clarity Cap ESA/Duelund Cast resistor comination, it would be transparent. I am very satisfied with the sound of my rig at this point. The audio signature of my rig is pretty accurate with nice smooth highs, accurate bass, and very nice tones without anything being emphisized too much or underdemphasized at the same time. Compared to the Sonicap/Mills combo I find the Clarity Cap ESA/Duelund Cast resistor combo an easily worthwhile and very positive change to the audio signature of my SDA SRS 2.3TL's. If you own some 2.3TL's I can easily recommend buying some of the Clarity Cap ESA's (quadzilla still has some I believe!) and Duelund Cast resistors to put onto Tony's (gimpod's) crosover boards. You will not be disappointed with the outcome. I hope this helps you guys out.
    Greg
  6. #216
    Join Date
    Dec 2010
    Location
    Central NC
    Posts
    2,534
    Default
    Quote Originally Posted by headrott View Post
    Greg
    Thanks for the write up, Greg! Very interesting.
    How many hours do you have on the CC/Dueland combo, and how many did you have on the Sonicap/Mills? Though I have no complaints about the S/M's in my 2.3TL's I also haven't heard 'em with the more expensive cap/resistor combo for comparison.
    What is the cost of the CC/Dueland mod?
    Thanks,
    Fred
    "Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills, polyswitches removed, Lg Solen inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips installed on back wall behind MW's & Tweeters, interior of cabinets sealed, AI-1 interface with 1000VA A-L transformer
  7. #217
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,523
    Default
    If you do Duelands for the 22.5 resistors, the 4 will run 200-ish. I have 2 sets of caps left, 325 shipped. The biggest problem at this point is that if you don't have Gimpod's boards, or aren't willing to build your own point to point, then you'll have a very hard time fitting the caps on the stock boards. Add about 10 bucks if you want to put Mills in the polyswitch spot. That's a lot cheaper than what I did, because I used Duelands there as well, and had to buy a total of 6 to get the correct value for the polyswitch. But I don't regret it. That's the only place I disagree with what Greg posted; I prefer the .18 resistance I have where the polyswitch was.
    It's not a cheap mod, but having heard the Sonicap/Mills, I think the Claritycap/Dueland combo far exceeds the regular S/M mods. With the Sonicaps, I always hear a hump in the bass centered around 60-70 Hz, and much less detail in the mids and highs. Even the bass has a lot more texture and detail, and actually images from a specific point, rather than just coming from somewhere at the front of the room. Soundstage also seems to be much wider and deeper, with more definite SDA effects.
    Open for editing.
  8. #218
    Member Sales Rating: (31)
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,791
    Default
    The improvement in spacial cues is why I love the Claritycap ESA/MR line so much.
  9. #219
    Join Date
    Jan 2008
    Location
    Posts
    4,355
    Default
    That is one thing I realised I didn't talk about after doing the write up. I didn't talk about the improvement in imaging. Face and quadzilla are correct about the improvement in imaging. It is more pinpoint with the Clarity Cap ESA/Duelund combination. I don't know if it's a "night and day" difference compared to Sonicap/Mills. At least to me I'm not sure it is. There is a definate improvement in spacial imaging though. The most "night and day" differences I hear are the detail and transparency you get with ESA/Duelund.
    As a side note, I have not even tried a resistor of any kind in the polyswitch spot with the ESA/Duelund combo. I really don't feel the need to with my rig. If I get too curious though I may put in the 0.5 ohm Duelund resistor in the polyswitch spot just to hear the differences.
    Fred, I have a little over 350 hours on the CC ESA/Duelund crossovers and I am not sure how many were on the Sonicap/Mills but I would guess well over 2,500 or more. You will not be thinking about the amount of money you spent on the ESA/Duelund with gimpod's boards. You absolutely will not regret it, IMO. You will only be seeing the improvements and not focusing on how much it costs to attain those improvements.
    Greg
  10. #220
    Join Date
    Dec 2010
    Location
    Central NC
    Posts
    2,534
    Default
    So many upgrades - so little time/money!
    I can't say I'm unhappy with the S/M, and I'm hearing many of the things with them described with the CC/D components. Still, I'm curious and love doing this type of work.
    Got to prioritize all this stuff: amp upgrade, Xover work, cables/connectors, refurbish Ludwig Vistalites, construct LR built in cabinets/shelving. . . .
    As a side note I spent a couple of hours listening last night. My AI-1 Dreadnought has around 30 hours on it so far and the sound quality/imaging continues to improve. No question that burn in on this is real. My imagination is beginning to fail me on how much better these speakers can sound. It sounds like I've put a more powerful amp in place - more slam, tighter control of everything, smoother mids and highs. The DN is turning out to be one of the most cost effective mods yet.
  11. #221
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,523
    Default
    Yes, I'll be building a dreadnought next month. The only question is which xformer to use? I'm reading DK's latest thread with some interest.
    Open for editing.
  12. #222
    Join Date
    Dec 2010
    Location
    Central NC
    Posts
    2,534
    Default
    Quote Originally Posted by quadzilla View Post
    Gotta say if I was building the AI-1 now, I would get the 1000 KVA transformer. But the 800 is no slouch. Whichever one you use I'm sure will put a smile on your face.
  13. #223
    Join Date
    Jan 2008
    Location
    Posts
    4,355
    Default
    Rob, if you are going to build it next month I would wait for (we are expecting anyway) an evaluation of the Plitron 1KVA transformer that thsmith was going to purchase and send to DK to evaluate. I would probably just buy this one instead of the 800VA Avel Lindberg transformer. I am going to purchase the Plitron here soon. I am hoping to get a reply from DK or thsmith about whether the evaluation is going to happen or not. I posted about it yesterday, but there is still no reply. I will probably order the Plitron regardless as there is no better alternative that anyone is aware of for a 1KVA transformer. I was just hoping to get some specs before ordering to know exactly what I am getting for the $258.00. Anyway, I only think the Dreadnought will be better with the Plitron 1KVA not degraded. I would go that route. I will be.
    Greg
  14. #224
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,523
    Default
    That's why I'm reading DK's thread with interest. I already checked out the Piltron. I'm just waiting for the eval, same as you guys.
    Open for editing.
  15. #225
    Join Date
    Jan 2008
    Location
    Posts
    4,355
    Default
    I'm still waiting to know for sure there is an evaluation.
    Greg
  16. #226
    Member Sales Rating: (22)
    Join Date
    Oct 2008
    Location
    Directly over the center of the earth in Olathe Kansas
    Posts
    5,825
    Default
    I guess I better get it ordered and sent to Ray.
    Ofc: Wright WLA12 preamp: Anthem Amp 1: Pio Elite DV-79AVI: Airport Express: CAL Sigma II DAC: PA LS90 sonicaps and mills
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. CS10 - How close to wall is to close?
    By cuban8 in forum Basic Hookup/Wiring Questions
    Last Post: 01-22-2010, 05:57 PM
  2. the truth really hurts,our sick society today
    By tom t in forum The Clubhouse
    Last Post: 04-10-2009, 01:18 PM
  3. A little humility never hurts...
    By steveinaz in forum 2 Channel Audio
    Last Post: 10-23-2007, 08:59 PM
  4. Man...........beer Hurts
    By JimBRICK in forum The Clubhouse
    Last Post: 05-07-2007, 04:59 PM
  5. 7B's waiting to be unleashed.....it hurts
    By Jonesy in forum Vintage Speakers
    Last Post: 03-24-2007, 08:51 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
