Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 13 of 13
  1. #1
    Member Sales Rating: (0)
    Join Date
    Nov 2011
    Posts
    54
    Default Pioneer vs Onkyo
    Well it appears I've got to get a new receiver, old one can't do what I want. Trying to decide between the Onkyo 809 for about $629. or Pioneer sc 35/55 for about $1200. Is the price diff. worth it? Funny the 55 is their #2 receiver right now and it can be had for the same price basically as the phased out 35. Any opinions on that? The 35 are getting hard to find also.
  2. #2
    Member Sales Rating: (1)
    Join Date
    Jun 2006
    Location
    Back from Japan in Clover, SC
    Posts
    7,812
    Default
    Go for the 35 and call it a day. Some awesome finds over at audiogon also.
    http://www.audiogon.com/cgi-bin/cls....-27-A/V-Receiv
    Shoot the jumper.....................BALLIN.............!!!! !
    Home Theater Pics in the Showcase
    http://www.polkaudio.com/forums/show...p?userid=73580
  3. #3
    Join Date
    Oct 2008
    Location
    Descending toward the moon in the CLEM (Chinese Lunar Excursion Module), looking for Chang'e
    Posts
    11,448
    Default
    I'm a big Onkyo AVR fan, but in this case the Pioneers are the better unit. If you want an equivalent Onkyo you'd have to step up to a TX-SR 3009 or 5009. In terms of HT dynamic power those higher level Onkyos and the Pioneers are not better or worse necessarily. But if you're going to do "double" duty, that is, if music is as important as HT then I'd give the nod to the ICE amps in the Pioneer!
    Good Luck!
    cnh
    Onkyo TX-SR 805 System #1 HT AVR
    Office Two Channel: LSi-7s (Nakamichi CA-5, NAD 214, Pioneer BDP51fd)
    Vintage Polks: Polk Monitor 5As, Monitor 7Bs [HK 730], Monitor 10As [Marantz 2265], SDA-2Bs [Jolida JD-303, Jolida MV-MK4]
    Headphones: HD600, Q701, ATH-M50s etc. Bravo Audio Ocean amp., Onkyo P-304, Adcom GFA-555, Technics Direct Drive TT
  4. #4
    Join Date
    Jan 2010
    Location
    St. Louis MO.
    Posts
    372
    Default
    Quote Originally Posted by mara5 View Post
    Pioneer Elite SC-35's are nice. You will not be disappointed. If you want seperate crossovers, then go Onkyo. The Pioneer has a single X-over point.
    Should power most 8 ohms but 4 ohm speakers should have something more robust.
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
    Receiver: Pioneer Elite SC-35 (140 watts x 7)
    Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
    Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
    TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
    Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks
  5. #5
    Join Date
    Jan 2011
    Location
    Nebraska
    Posts
    1,613
    Default
    Quote Originally Posted by SRTer View Post
    The Pioneer has a single X-over point. .
    What do you mean? One blanket xo setting for the Left, Center, Right, and Surrounds?
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  6. #6
    Join Date
    Feb 2008
    Posts
    582
    Default
    Where are you getting the 809 for $629? That's a great price assuming it is new.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  7. #7
    Join Date
    Jan 2010
    Location
    St. Louis MO.
    Posts
    372
    Default
    Quote Originally Posted by jbooker82 View Post
    The Pioneer AVRs give several crossover points, but once set, the X-over will be for all speaker set to (SMALL).
    The Onkyo AVRs give several crossover points which can be set individually for each speaker set to (SMALL).
    This only matter if you want to run 80Hz X-over on the center ch and 50Hz on the tower speakers as some people chose to do. I run all my speakers (LARGE) without crossover except the center which is X-overed at 80Hz.
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
  8. #8
    Join Date
    Nov 2011
    Posts
    54
    Default
    NewHTguy
    accessories4less.com had them up till yesterday brand new for 629.99 Today,only refurbished at that price.
  9. #9
    Join Date
    Oct 2003
    Posts
    868
    Default
    I would not consider any Onkyo product... I have two and am having HDMI problems with both... They want $1000 (for the part only) to replace the HDMI boards on each unit (i.e. $2000 total)... This is apparently an endemic problem with most Onkyo AVRs for the past four years.
    They are also having issues when the AVR cycles thru the various inputs on its own after a few months of ownership.
    You can see the lengthy Onkyo threads on avsforum.com and on how poorly Onkyo is responding to these issues. Some users have taken to repair the boards on their own. The problems occur because Onkyo uses substandard caps on the HDMI boards which fail prematurely.
  10. #10
    Join Date
    Jan 2010
    Location
    St. Louis MO.
    Posts
    372
    Default
    Quote Originally Posted by jon s View Post
    Never had any problems with my Pioneer Elites. A VSX-23 and a SC-35. They have been perfect in everyway.
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
  11. #11
    Join Date
    Dec 2010
    Posts
    62
    Default
    Nice price on the Onkyo, but with I like the Pioneer better. Just my opipnion, but to me the build quality of the pioneers has been better over the past few models compared to the Onkyo receivers, and I like the sound of the ICE AMPS.
  12. #12
    Join Date
    May 2010
    Location
    San Mateo, CA
    Posts
    1,581
    Default
    I wouldn't generalize about reliability - I've had Onkyo, Yamaha, and Denon, and never had an issue with any of them. I'd say all things equal, the Pioneers sound better.
    GUI, menu system, and customization-wise, the Pioneers are stuck in 1999. Onkyo and Denon are way ahead there. But that's more about usability than performance. So that's just a call-out.
    ALL BOXED UP for a while until I save up for a new place :(
    Home Theater:
    KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
    2 Channel:
    Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs
  13. #13
    Join Date
    Dec 2010
    Posts
    62
    Default
    I definitely agree with the Pio being stuck in the late 90s as far as GUI goes, but their optimization/setup functions in the SC series are easy to do and work just as well as the Audessey MultiEQ setup (I have done both with my old Denon 999 and my current SC-25) but it doesnt take nearly as long to go through all the steps. And the reliability issues with Onkyo are well documented starting with the 8/705 (HDMI board heat problems) and have only gotten better by using cheaper, lighter, and inferior quality parts. There is a reason why the 809 weighs in around 35 pounds and the 805 weighed in around 50.
    But in the end, we have the same opinion. Go with the Pioneer and save yourself the headache of buying a new receiver in a few years when you find yourself wanting somehting a bit better.
    Also, PrazVT, you a Hokie out in Cali? Richmond, VA Hokie over here.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Pioneer VS Onkyo
    By sageleo in forum Electronics
    Last Post: 03-19-2010, 09:31 PM
  2. pioneer sc-05 or onkyo 905 please help
    By Montoya in forum Electronics
    Last Post: 12-01-2008, 09:51 PM
  3. Pioneer VSX-D811S vs. my Onkyo
    By concealer404 in forum Electronics
    Last Post: 09-10-2008, 06:23 AM
  4. Onkyo SP-502 vs Pioneer Elite DV-45A
    By SolidSqual in forum Electronics
    Last Post: 09-14-2006, 02:47 PM
  5. Pioneer VSX-816-K or Onkyo TX-SR504?
    By frdranger in forum Electronics
    Last Post: 08-21-2006, 04:13 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
