Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 9 of 9
  1. #1
    Member Sales Rating: (0)
    Join Date
    Dec 2011
    Posts
    18
    Default what should i go with RTI A3 OR RTI A5 or tl350
    im new on here and have owned polk for a long time and im wanting to update my rm5400 that said. i like the look of the rtia5 but not sure if they are overkill for my room and my needs. the room is 16x25. should i just go with the rtia3
    or will the blackstone tl350 do just fine.
    this is for mainly home theater but will have music playing from time to time rock that is.
    bottom line my money your help lets see what we come upi with
    thanks jghglofer
  2. #2
    Join Date
    Sep 2011
    Location
    Cleveland
    Posts
    5,112
    Default
    IMO go with the a5's. Better yet the a7's if you can afford them.
  3. #3
    Join Date
    Aug 2011
    Location
    A place called Winnipeg
    Posts
    2,681
    Default
    If its to replace your current setup, The TL350 would probably be a noticable upgrade. This is assuming you have a sub already. If you were buying 5 A5's then I would go that route :p
  4. #4
    Join Date
    Aug 2010
    Location
    Austin, TX
    Posts
    1,278
    Default
    What are you powering them with and what is your total budget? This will help us recommend a good setup for your needs.
    Theater Room: Pioneer Elite SC-35, RTi12's, Csi5, Fxi3's, ED A5-350 sub, Optoma HD20, 92'' Elite Screen, Sony BDPS790, Xbox 360, APC H15, MIT Exp 2 SC's, Pepster PC's
    Living Room: Rotel RSX-1055, Zu Audio Omens (Druid drivers, tweeters and KimberKaps), Zu Mission SC's, Sony SA-WM40 12'' sub, Sharp Aquos 60'', AEX, Pepster PC
    Bedroom: Panasonic AX200U projector, 110" screen
    Outdoor: Polk Atrium 5's, Yamaha Rxv371
  5. #5
    Join Date
    Dec 2011
    Posts
    18
    Default
    B Run my power is from onkyo tx-nr801 nice unit but no hdmi hook ups
    Drenis this would be my set up a5 fronts csi5 and fxia4s
    not sure if my old sub will match its polk psw50 120w
    thanks and yes i have a budget may have to buy in pieces
  6. #6
    Join Date
    Jan 2011
    Location
    Nebraska
    Posts
    1,452
    Default
    I would run RTI a5's. Think of them as a better bookshelf speaker with a built in speaker stand.
  7. #7
    Join Date
    Aug 2010
    Location
    Austin, TX
    Posts
    1,278
    Default
    Quote Originally Posted by jghglofer View Post
    That's a very good start, just run them and decide what your weakest link is and upgrade accordingly.
  8. #8
    Join Date
    Oct 2004
    Location
    North Texas
    Posts
    3,417
    Default
    I've got RT3000P fronts right now in a 14x12 room and love every bit of it. I only have one of the powered subs going right now and can't wait to get the other one back in order. Between those options, I'd be looking at RTi towers in that size room.
  9. #9
    Join Date
    Dec 2011
    Posts
    18
    Default
    do you think my old sub will work its the dsw50 and its 120w but its about 10years old its from thr rm5400 set
    from what they say its the first of the tl350
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Rti line vs tl350
    By burts in forum Speakers
    Last Post: 11-03-2011, 09:45 PM
  2. Blackstone TL350
    By mmarbach in forum Speakers
    Last Post: 08-25-2011, 09:28 PM
  3. Sub to go with TL350 system
    By 1QWK510 in forum Speakers
    Last Post: 07-30-2011, 02:02 AM
  4. BlackStone TL350
    By TouchOfEvil in forum Speakers
    Last Post: 06-18-2011, 06:56 PM
  5. blackstone TL350
    By gregor in forum Speakers
    Last Post: 03-06-2011, 01:57 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
